Hey guys looking for a little help on a set of valve springs for my engine.
I have an older grind Hughes HE3038AL that I installed when I built the engine. I am happy with the cam but somehow I misplaced the inner springs that I should have installed after break in. Long story but I actually installed the engine about 12 years ago.. it has a massive 350 miles on it since.. I have a set of their LA stageII iron heads installed. CC'd w//62cc chambers, 2.05/1.625 valves and the guides have been milled for positive seals.
I really want a beehive style spring so I can have a wider choice of rockers.
Hughes uses PAC springs which are probably a good product but I am looking for a little assistance locating some alternatives. Does anyone have any suggestions?
Hughes recommends this spring from their website
145# @ 1.800" / 358# @ .550" LIFT (PAC SPRING)
Installed Height/Pressure: 1.800"--145#
Pressure @ .550" lift: 358#
Pressure @ .600" lift: 375#
Pressure @ .650" lift: 400#
Pressure @ .700" lift : 425#
Coil Bind: @ .750" lift
Outer Spring ID/OD: 1.075" /1.459"
Inner Spring ID/OD: 1.078" / .794"
Type of Spring: Dual
Retainers: 5/16" -1278 : 11/32" - 1201
Spring Rate 391
Spring Rate 391
