valves for small block 587 heads
Small Block Mopar Engine
  1. texas360
    texas360 Well-Known Member
    340
    72
    Jan 30, 2016
    TEXAS
    Local Time:
    4:00 AM
    i need 1.88 intake and 1.60 exhaust valves for a pair of 587 heads... this is a stock bottom end motor, with comp xe274H and Weiand intake unless i can find a little smaller cam so i don't have to run double springs... so i dont see a need for expensive valves. i would love nothing more than aluminum heads,but gotta do with what you can afford and already have...
    where is the best place to buy stock small block valves?
  2. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    58,902
    46048
    Jan 18, 2006
    Iowa
    Local Time:
    4:00 AM
    Any parts store, Summit, Jegs or Rockauto.
  3. texas360
    340
    72
    Jan 30, 2016
    TEXAS
    Local Time:
    4:00 AM
    i was looking around on those.. im not sure how well i trust like a local parts store .. shit they want to know if you automatic or manual just for headlight bulbs... would it be worth it trying to clean up valves i already have laying around? what decides whether a valve is good or bad
  4. Tims 66 Cuda
    Tims 66 Cuda Mopar mid life crisis
    323
    163
    May 28, 2018
    Poquoson, Va
    Local Time:
    5:00 AM
    Rock Auto maybe , Summit ,Mancini. Im at the same stage looking at valves and pistons
  5. toolmanmike
    58,902
    46048
    Jan 18, 2006
    Iowa
    Local Time:
    4:00 AM
    That's just how their computer programs are written. Like all the online parts sites, you answer questions about your car to get to the correct application.
  6. perfacar
    perfacar Well-Known Member
    1,092
    285
    Mar 1, 2006
    renton,wa
    Local Time:
    2:00 AM
    ferrea makes good stainless valves for 587 head. 1.88 and 1.60, the 587 heads like those.
    • Like Like x 1
    • Tims 66 Cuda
      323
      163
      May 28, 2018
      Poquoson, Va
      Local Time:
      5:00 AM
      SI Valves look like a good choice and not crazy expensive
    • texas360
      340
      72
      Jan 30, 2016
      TEXAS
      Local Time:
      4:00 AM
      ill have to see where those can be bought
    • texas360
      340
      72
      Jan 30, 2016
      TEXAS
      Local Time:
      4:00 AM
    • toolmanmike
      58,902
      46048
      Jan 18, 2006
      Iowa
      Local Time:
      4:00 AM
      Rockauto has them Melling or Sealed Power are good names.
      • Like Like x 1
      • Thanks! Thanks! x 1
      • toolmanmike
        58,902
        46048
        Jan 18, 2006
        Iowa
        Local Time:
        4:00 AM
        Stainless isn't cheap
      • Tims 66 Cuda
        323
        163
        May 28, 2018
        Poquoson, Va
        Local Time:
        5:00 AM
        I have that same cam and it calls for spring upgrade. Dont go to cheap on the valves
      • texas360
        340
        72
        Jan 30, 2016
        TEXAS
        Local Time:
        4:00 AM
        yeah its double springs and viton seals.. i really want to go a little smaller on the cam so i can just run a single spring and use the comp seals i already have
      • texas360
        340
        72
        Jan 30, 2016
        TEXAS
        Local Time:
        4:00 AM
        so i was looking and they have 2 and 4 groove on both intake and exhaust valves.. sorry im still learning, but how do i know which i need?
      • Tims 66 Cuda
        323
        163
        May 28, 2018
        Poquoson, Va
        Local Time:
        5:00 AM
        I believe your stock valves are multi grooved.Match them up and I think Mancini sells the m multi groove. Check Sealed Power as well
      • texas360
        340
        72
        Jan 30, 2016
        TEXAS
        Local Time:
        4:00 AM
        probably depends on locks too? i got 10 degree locks for my comp cam and comp retainers
      • Tims 66 Cuda
        323
        163
        May 28, 2018
        Poquoson, Va
        Local Time:
        5:00 AM
        Like I said, Ive got the same cam with the complete kit. Got the same 587 heads. Buy the time I machine the heads to accept the springs and seals and install new valves, I could have bought cam , lifters and aluminum heads for about the same$$.
      • Krooser
        Krooser Reform School Graduate
        3,152
        2659
        Jul 19, 2015
        Central Wisconsin
        Local Time:
        4:00 AM
        Cheap aluminum heads maybe.... Quality costs more.
        You can buy SI valves direct from them just call. Ferrara has several distributors that you can find online.
        I bought Magnum valves from them for around $12.00 per valve.
      • 66fs
        66fs FABO Gold Member FABO Gold Member
        5,712
        2251
        Sep 9, 2009
        Greenwood, South Carolina
        Local Time:
        5:00 AM
        Used them all the time. Intake stems usually don't wear much, Exhaust usually need to be replaced. I typically go with Ferrea stainless valves for exhaust. Do you have valves? Intakes can be 2 or 4 groove. Exhaust are 4 groove. Just reuse them.
        • Like Like x 1
        • MOPAROFFICIAL
          MOPAROFFICIAL Well-Known Member
          7,943
          7143
          Jun 1, 2016
          Beach
          Local Time:
          2:00 AM
          I recommend Re use of the stockers you have laying around or change the guides for 11/32 and do some 1.94/1.60 valves that you can get for 98 bucks for 16 stainless elgin pro stock valves on amazon.
          • Like Like x 3
          • 66fs
            5,712
            2251
            Sep 9, 2009
            Local Time:
            5:00 AM
          • QuickDart360
            QuickDart360 Well-Known Member
            1,345
            548
            Apr 5, 2014
            San Antonio
            Local Time:
            4:00 AM
            That cam should not need double springs! I run the 292/508 mopar purple cam and run single springs with damper. Mine are crane valve springs.
            • Agree Agree x 1
            • texas360
              340
              72
              Jan 30, 2016
              TEXAS
              Local Time:
              4:00 AM
              i would love to run a single spring.. would save me on trimming down guides
              • Agree Agree x 1
              • yellow rose
                yellow rose Overnight Sensation FABO Gold Member
                28,537
                24967
                Jun 19, 2015
                Central Washington
                Local Time:
                2:00 AM
                I have a set of 3/8 stem, single groove 2.02/1.60 valves I’d sell you for 65 bucks shipped. These came out of my personal heads and I’ll never use them.
                You will need to grind them. They do have 50 degree faces on them, but you just grind them back to 45 and run them.
                PM me if you are interested.
                YR
                • Like Like x 1
                • George Jets
                  George Jets 1967 Dart 2 Door FABO Gold Member
                  4,755
                  6530
                  Jan 18, 2019
                  Farmington MN
                  Local Time:
                  4:00 AM
                  EngineTech are the brand I use all the time, have had good luck with them. Check the sellers on ebay, search:
                  1976 Dodge 360 Valves
                  '76 era or whatever year your heads are, then you don't get into the magnum engine applications.
                  20200621_153646.jpg This photo happens to be 318 head, but yes EngineTech valves.
                  • Like Like x 2
