Very high temp paint???
dustoff440
central fl
After I bead blast my 340 exhaust manifolds I would like to paint them with something that will hopefully stick There are a lot of products out there that claim they will do the job. Has anyone had any experience with a product that really works??? Getting a good product the first time around will save me a lot of time and money, both of which I am in short supply of right now. LOL
I used VHT paint on my new headers and followed all the instructions on the can and after 2 months it still looks great. We'll see what a little more time will do.
Although I haven't installed my engine yet. I painted mine with Eastwood high temp manifold paint. http://www.eastwood.com/ew-factory-gray-hi-temp-coating-11-75oz-aer.html
They should last 2-3 years. toolmanmike
I know a guy who used wood stove paint. Its for cast iron, black, high temp, and appears to be working well.
My mother has a Vermont Castings wood stove and that son of a b would get darn hot, and the spray paint they gave her is still on it after 30 years.
The VHT paint works well. There is a cast iron color that looks like a brand new, bare manifold. Me likey!
I just switched to Rustoleum header paint availible at autozone and so far so good. I'll let you know what I find out after a 2K trip I'll be making shortly.
I've used the Eastwood stuff several times. It goes on easily, dries quickly does not flake off and does not change color. It's a good product.
3k miles on the Jeep through a few major rain storms at 80 mph, 100+F days and a few gravel roads and no flaking or bubbling. The new Rustoleum stuff has made me a believer. This goes for thier 500 F plus engine paint as well as thier header paint.
In 6 months we'll see how it does in the snow, gravel, sand and mag chloride they spread on the roads here.
I disagree. Used it following directions to the letter on the exhaust manifold and pipe for the '64 Ford 2000 series 4 cylinder tractor over a year ago. It looks great at first but within a couple of months, it was blistering and then started peeling off. The tractor gets used maybe once/twice a month and lives in my shop, not outside. For about $30 a pint (if I remember right), I think the stuff is crap.
I can get pictures.
really? it worked well for me. what would you recommend?
has amyone tried this? http://www.por15.com/High-Temperature-Paints/products/8/
the directions say paint it on, let it dry to the touch and then heat it up to over 300 degrees to fully cure it. then it will withstand 1200-1400 degrees. thats what i plan on using on my build when i get to that point.
I used it (applied it just as the directions said) on my headers but didn't have a way to cure it (no oven). I thought maybe I could install the headers and fire it up for a little at a time keeping an eye on the temp with a digital temp gun making sure to not go over 300 degrees. Problem was it scratched off so easy I had half of it scratched off installing the headers. I went ahead and fired it up and within seconds it was peeling off. I've used POR-15 chassis paint with great success but the header paint didn't work good at all for me.
intresting. I'm going to try it and see how it goes. It's a bummer you did not have any luck with it.
On a buddy's headers; Read the directions, hung them up and sprayed. THEN, got a big weed killing torch that would smoke anything you own, used a digital therm, heated headers to proper temp, per instructions, cool, heat, cool ,heat, etc (different temps). Installed the engine, then gator wrestled the headers in- (a lot of banging and scraping), no scratches. We stood there in awe; something we read actually worked.
