Vintage Air SB bracket
Heating / Cooling / AC
  1. Avispa
    Avispa FABO Gold Member FABO Gold Member
    1,241
    662
    Feb 26, 2007
    Georgia
    Local Time:
    4:21 PM
    I thought someone would like to see the bracket from Vintage Air, this will mount the Sanden 508 compressor, alternator, and the PS pump, it mounts to the water pump and they give You all the hardware/spacers to mount it. It comes in bare metal.
    • Like Like x 3
    • Paul King
      Paul King MrPJK
      130
      55
      Jul 2, 2019
      Ontario Canada
      Local Time:
      4:21 PM
      Will this work with my 1966 273 Engine,and also how about the original lines.Thanks
    • Avispa
      1,241
      662
      Feb 26, 2007
      Georgia
      Local Time:
      4:21 PM
      not sure, the early WP is different, i'll set my old pump back up there and see, bear with me, might be tomorrow.
      • Like Like x 1
      • lemondana
        lemondana BlackDart
        352
        151
        Dec 7, 2007
        Southeast NE
        Local Time:
        3:21 PM
        This mount kit will not fit the 66. They have one for 69 and earlier, I'll get the number tomorrow. It looks like it will work fairly well but moves the alternator to the driver's side, if that might be a problem.
        • Thanks! Thanks! x 1
        • Paul King
          Paul King MrPJK
          130
          55
          Jul 2, 2019
          Ontario Canada
          Local Time:
          4:21 PM
          Thanks so much ,I have factory air but the ,bracket tensioner is missing and very hard to find,Thanks again
        • Avispa
          1,241
          662
          Feb 26, 2007
          Georgia
          Local Time:
          4:21 PM
          Guess he answer your question, thanks leemon
          • oldkimmer
            oldkimmer FABO Gold Member FABO Gold Member
            13,640
            3211
            Nov 11, 2006
            Kindersley, Saskatchewan,
            Local Time:
            3:21 PM
            I think oldmanmopar will have what u need. Kim
            • Paul King
              Paul King MrPJK
              130
              55
              Jul 2, 2019
              Ontario Canada
              Local Time:
              4:21 PM
              How do I contact him.Thanks
            • oldkimmer
              13,640
              3211
              Nov 11, 2006
              Local Time:
              3:21 PM
              Look him up in the members. He reply’s to wanted ads. Kim
            • Paul King
              Paul King MrPJK
              130
              55
              Jul 2, 2019
              Ontario Canada
              Local Time:
              4:21 PM
              Thanks Kim.
            • oldkimmer
              13,640
              3211
              Nov 11, 2006
              Local Time:
              3:21 PM
              Under. Mopar General discussions. Went to work on the duster and seen this. His thread
            • toolmanmike
              toolmanmike FABO Staff Staff Member FABO Gold Member
              45,770
              29858
              Jan 18, 2006
              Iowa
              Local Time:
              3:21 PM
              Start a want ad is the way to do it.
              • lemondana
                lemondana BlackDart
                352
                151
                Dec 7, 2007
                Southeast NE
                Local Time:
                3:21 PM
                Sorry it took so long to get back. The Vintage Air bracket kit for 69 and earlier is 161004. You have to download the installation instructions to see what it looks like. I saw one installed on a 68 Barracuda and he had the alternator mounted in the stock location. Take a look.
                • jefflock
                  jefflock 69 Dart 408 10.008 best pass so far
                  3,623
                  34
                  May 18, 2006
                  Kansas
                  Local Time:
                  3:21 PM
                  Thanks for sharing the bracket. It doesn't appear that you have to PS to make it work
                • rumblefish360
                  rumblefish360 So close, yet so far away
                  36,952
                  8778
                  Jun 21, 2005
                  New York, on a Island
                  Local Time:
                  4:21 PM
                  What did it cost? I also wonder if the compressor is available with a serpentine belt to match the March pullies? That would be cool!
                • 64 Sportfury
                  64 Sportfury FABO Gold Member FABO Gold Member
                  51
                  8
                  Nov 1, 2014
                  New York
                  Local Time:
                  4:21 PM
                  I will add that my Vintage Air Sure-fit kit for 1968 B body and LA small block with EQ heads, came with a 1970 and up LA engine bracket kit (162774) that fit my early water pump (fabbed 2 spacers) and cleared the Pro Flo 4. I haven't lined up the pulleys but they can be shimmed if necessary.
                  This is the Vintage Air Kit 162774 on a 318/390 stroker for my 68 Coronet wagon. The wagon is a factory A/C car and uses the cast iron water pump. I had to make 2 spacers out of some stock to fill the gaps on 2 bolts. Hope this helps.
                • 64 Sportfury
                  51
                  8
                  Nov 1, 2014
                  New York
                  Local Time:
                  4:21 PM
                  Paul King If you still need a bracket tensioner I have the pieces from my 68 Coronet wagon w/318, a/c and p/s.
                • oldkimmer
                  13,640
                  3211
                  Nov 11, 2006
                  Local Time:
                  3:21 PM
                  So what r u doing for the bottom bracket at the T stat housing? Kim
                • Paul King
                  Paul King MrPJK
                  130
                  55
                  Jul 2, 2019
                  Ontario Canada
                  Local Time:
                  4:21 PM
                  That would be great ,could you send a pic please
                • Paul King
                  Paul King MrPJK
                  130
                  55
                  Jul 2, 2019
                  Ontario Canada
                  Local Time:
                  4:21 PM
                  64 looks like a really nice job your doing
                  • 64 Sportfury
                    51
                    8
                    Nov 1, 2014
                    New York
                    Local Time:
                    4:21 PM
                    The kit is as you see it. Only 3 of 4 compressor holes are bolted to the main bracket.
                  • 64 Sportfury
                    51
                    8
                    Nov 1, 2014
                    New York
                    Local Time:
                    4:21 PM
                    I tried to PM you but your box is full. Don't want to hijack this thread.
                  • 64 Sportfury
                    51
                    8
                    Nov 1, 2014
                    New York
                    Local Time:
                    4:21 PM
                    Ok. I need to clarify, again. Of the 8 mounting holes on the compressor 3 are bolted to the main bracket. 2 lower front and 1 lower rear holes are bolted.
                  • Paul King
                    Paul King MrPJK
                    130
                    55
                    Jul 2, 2019
                    Ontario Canada
                    Local Time:
                    4:21 PM
                    Hi 64 .I emptied some of my inbox if you can send the pic now ,I will send u a pick of the bracket.Thanks
                  • 64 Sportfury
                    51
                    8
                    Nov 1, 2014
                    New York
                    Local Time:
                    4:21 PM
                    PM sent
