Voltage regs and Amps?
General Discussion
  1. Ironracer
    Ironracer Gearhead
    7,018
    5719
    May 8, 2020
    Tampa Bay Florida
    Local Time:
    8:07 PM
    Had to buy the wrong alt for my 74 Duster. It's a 60 or 65 Amp from a van. Only one in (85 bucks? Don't remember if that was before or after core.) Damn thing took a dump, good thing it had a lifetime warranty ( how the hell can they send our parts to China to be re-manned?
    OK rant over, question is: will the extra amps fry my stuff, no extra electric, but roll at nite sometimes, or does the volt reg limit amps too?
    Thanks, and I hope Everyone is doing good
    • Like Like x 1
    • MOPARMAGA
      MOPARMAGA FABO Gold Member FABO Gold Member
      4,603
      4362
      Aug 20, 2019
      Yakima Wa
      Local Time:
      5:07 PM
      Weren't stock alternators 80 or 100 amp ?
      Sorry, I wish I knew electrical better.
      China=puke emoji
      • Agree Agree x 1
      • Ironracer
        Ironracer Gearhead
        7,018
        5719
        May 8, 2020
        Tampa Bay Florida
        Local Time:
        8:07 PM
        I think the older ones were 30 or 35? I dunno... I remember reading enough about it to be concerned
      • Phreakish
        Phreakish Well-Known Member
        1,834
        1449
        May 28, 2015
        N. Idaho
        Local Time:
        5:07 PM
        Extra amps are no issue. The regulator prevents excess current (amps).
        • Like Like x 1
        • flingdingo
          flingdingo Well-Known Member
          429
          380
          Apr 26, 2017
          El Lay
          Local Time:
          5:07 PM
          You'll be fine. The car only uses the amps it needs.
          The regulator controls volts, not amps. Too much voltage will fry stuff.
          • Thanks! Thanks! x 1
          • 67Dart273
            67Dart273 FABO Gold Member FABO Gold Member
            55,320
            25547
            Oct 14, 2010
            Idaho
            Local Time:
            5:07 PM
            Well it IS an issue "sometimes." The later cars had the big white connector under the hood to separate the engine harness (Thanks Redfish) This thing deteriorates and needs repaired, so inspect it THE MAIN alternator output wire goes throught hat. Also the bulkhead connector/ ammeter circuit is an issue. Inspect the bulkhead connector by separating the connector halves and look carefully. READ the "MAD" article for insight
            Catalog
            Also CHECK charging voltage when you get it all running. With engine warm and battery charged "and normalized" check charging voltage with accessories off and engine on fast idle. If it is much over 14.5, look for problems in the circuits above as well as the ignition circuit. VOLTAGE DROP through the ignition "run" circuit causes over-voltage/ over-charging
            These girls varied from 37--65 BUT FACTORY 65 alternators HAD A MODIFIED CHARGING CIRCUIT known as "fleet/ police/ taxi" which partially bypassed the bulkhead connector
            • Ironracer
              Ironracer Gearhead
              7,018
              5719
              May 8, 2020
              Tampa Bay Florida
              Local Time:
              8:07 PM
              Thanks Del!
              OK. I don't recall a white connector. I'll double check in a few. Just checked voltage on batt ( on trickle). Would even a stock ( van app) from the 80s have the same protection?
            • Ironracer
              Ironracer Gearhead
              7,018
              5719
              May 8, 2020
              Tampa Bay Florida
              Local Time:
              8:07 PM
              Yes. I know from My household electric, that volts is the amount, but amps r the speed. If you get bit, it's the amps that'll hurt I was told many years ago. I think..... lol
            • 67Dart273
              55,320
              25547
              Oct 14, 2010
              Idaho
              Local Time:
              5:07 PM
              I'm not really familiar with the van wiring. That could go either way. About all I can advise is "trace it" and see if the charge wire goes through the bulkhead, AND if the ammeter has large wires like the older cars
              SOME of the newer cars used "external shunt" ammeters --the clue is that the ammeter wires are very small like 18 or 16 or so because they no longer carry much current due to the shunt--which in reality is part of the wire harness itself
              • Ironracer
                Ironracer Gearhead
                7,018
                5719
                May 8, 2020
                Tampa Bay Florida
                Local Time:
                8:07 PM
                It's my 74 Duster. Redfish ( Thanks!) Sent me the right gauge at no cost,after I bought one off e bay ( seller claimed to work, for my app) from a 75. That's the one I sent you
              • 67Dart273
                55,320
                25547
                Oct 14, 2010
                Idaho
                Local Time:
                5:07 PM
                OH GEEZ OK I'm with you now.
                • Bewy
                  Bewy Well-Known Member
                  2,422
                  1542
                  Jan 1, 2021
                  Australia
                  Local Time:
                  10:07 AM
                  If this is a race car, you only want an alt that is big enough [ 35 amp? ] to keep the battery charged. Any thing bigger than reqd saps hp. You are probably aware that some racers remove the fan belt when racing to reduce hp loss. Not always wise with some ign systems.
                  • Ironracer
                    Ironracer Gearhead
                    7,018
                    5719
                    May 8, 2020
                    Tampa Bay Florida
                    Local Time:
                    8:07 PM
                    It built her on the fine line, that I determined, would handle daily driving in Tampa ( and she did, for almost 2 years, in my 66 Sat!) So it needed to run, without issues, in heavy traffic, if required. And yes, and old Mopar Bro told me to drop that, and the p/s belt at the track! Lol
                  • mderoy340
                    mderoy340 Well-Known Member
                    2,547
                    1370
                    Aug 2, 2012
                    Melbourne FL
                    Local Time:
                    8:07 PM
                    just add a switch to turn the field off during the pass.
                    • Agree Agree x 1
