voltage regulator
New Hemi Engine Swaps
  1. Black 69 Dart
    Black 69 Dart Well-Known Member
    394
    8
    May 19, 2009
    Edmonton, Ab Canada
    Local Time:
    3:12 AM
    What are guys using for voltage regulator? I just ordered one for a 69 dart but I am second guessing that now..
  2. 1969383S
    1969383S FABO Gold Member FABO Gold Member
    5,297
    2370
    Jan 8, 2012
    Cumming, GA.
    Local Time:
    5:12 AM
    Using the newer electronic that looks like the original. I have the blue mopar unit for 69 and earlier but like the look of the original style. I have not started it up yet but got my fingers crossed!!
  3. mcat
    mcat Well-Known Member
    278
    16
    Jun 28, 2009
    cincinnati ohio 45251
    Local Time:
    4:12 AM
    As long as it's an updated version you'll be fine
  4. Black 69 Dart
    394
    8
    May 19, 2009
    Edmonton, Ab Canada
    Local Time:
    3:12 AM
    What is the updated version and how should it be wired? I seen the diagrams but seems everyone that did it like that had problems
  5. 1969383S
    5,297
    2370
    Jan 8, 2012
    Cumming, GA.
    Local Time:
    5:12 AM
    Looks like this only it has electronic guts instead of the old point contacts.
  6. 1969383S
    5,297
    2370
    Jan 8, 2012
    Cumming, GA.
    Local Time:
    5:12 AM
    The newer mopar performance unit for 69 and earlier looks like this
  7. Black 69 Dart
    394
    8
    May 19, 2009
    Edmonton, Ab Canada
    Local Time:
    3:12 AM
    Do you have a part number?
  8. Uhcoog1
    Uhcoog1 Well-Known Member
    889
    24
    Feb 7, 2011
    Houston
    Local Time:
    4:12 AM
    Transpo c8313
    I fried 3-4 of a lesser quality before going with this one. Adjustable voltage as well.
  9. Black 69 Dart
    394
    8
    May 19, 2009
    Edmonton, Ab Canada
    Local Time:
    3:12 AM
    Did some reading on the mopar voltage regulator and people are saying not to use it on a street car. Is this true?
  10. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    41,840
    9502
    Oct 14, 2010
    Idaho
    Local Time:
    2:12 AM
    I keep hearing that. I think it's bull. But you can get the 'same" regulator from standard / Blue streak NAPA NAPA is VR1001, Blue Streak is VR128
  11. GEO
    GEO Sarcasm Inc.
    1,932
    228
    Feb 12, 2012
    Irvington ,Indiana
    Local Time:
    4:12 AM
    Had one for over 20+ years on my dart with thousands of street miles
  12. 1969383S
    5,297
    2370
    Jan 8, 2012
    Cumming, GA.
    Local Time:
    5:12 AM
    Same here and it has moved to mutliple cars with the electronic ignition set-up... The Blue unit works fine for the street...
  13. 67Dart273
    41,840
    9502
    Oct 14, 2010
    Idaho
    Local Time:
    2:12 AM
    Dan the irritant had a big rant on here one time about how they don't regulate because they are not grounded. I'm not sure I got the point. If that is REALLY all that is different with the "race only" units, then all you need to do is scrape the paint off for the bolts
    After all a regulator that does not regulate is "hardly a regulator"
    That IS the job of a "voltage regulator"-------to regulate voltage!!!! They have not changed lead acid batteries just because they are in a race car
  14. Uhcoog1
    889
    24
    Feb 7, 2011
    Houston
    Local Time:
    4:12 AM
    You need a heavy duty one with the Hemi alternator. The field draw is up to 7 amps.
  15. Black 69 Dart
    394
    8
    May 19, 2009
    Edmonton, Ab Canada
    Local Time:
    3:12 AM
    Called napa today and they had a vr 32. Pocket it up but now having second thoughts on it. Will it work or did I get the wrong one?
  16. 67Dart273
    41,840
    9502
    Oct 14, 2010
    Idaho
    Local Time:
    2:12 AM
    VR32 is the bottom line, and certainly not made if you need one for a heavy amp draw field
  17. Black 69 Dart
    394
    8
    May 19, 2009
    Edmonton, Ab Canada
    Local Time:
    3:12 AM
    That sucks for me. Hope Napa will let me return it. I did find one in my garage part number acre-2604 9222.
  18. Rat Patrol
    Rat Patrol Well-Known Member
    1,240
    158
    Oct 30, 2010
    On the outskirts
    Local Time:
    2:12 AM
    Bosch RE55 solid state...works fine.
  19. toolmanmike
    toolmanmike FABO Staff Staff Member FABO Gold Member
    47,001
    31307
    Jan 18, 2006
    Iowa
    Local Time:
    4:12 AM
    Which ever one you use make sure it is well grounded.
  20. Buschi340
    Buschi340 Well-Known Member
    1,263
    25
    Feb 19, 2005
    Wilhelmshaven, GERMANY
    Local Time:
    10:12 AM
    BOSCH? Cool.... danke! :)
  21. Black 69 Dart
    394
    8
    May 19, 2009
    Edmonton, Ab Canada
    Local Time:
    3:12 AM
    Bosch part number comes up with nothing is that the correct number? For some reason no one has any of these regulators locally and can not cross reference them with others.
  22. 67Dart273
    41,840
    9502
    Oct 14, 2010
    Idaho
    Local Time:
    2:12 AM
    • Like Like x 1
    • KitCarlson
      KitCarlson Well-Known Member
      2,486
      379
      Jan 17, 2008
      Middle Tennessee
      Local Time:
      4:12 AM
      The Bosch units used on Porsche, BMW, and Volvo I am familiar with have internal regulator that is part part of the module for the field brush assembly. It is easily changed out with a couple screws. Bosch units also need a warning indicator bulb energized by the ignition switch, for them to regulate.
    • Buschi340
      1,263
      25
      Feb 19, 2005
      Local Time:
      10:12 AM
      true, I swapped always Bosch into my US cars. There are pretty small Nippon Denso's on the market as well. All with internal regulators.
      I have a buddy in Auto parts supply here. Will search for an external Bosch regulator since i have this HEMI Alternator to use....
    • tekslk
      tekslk Well-Known Member
      3,132
      39
      Dec 13, 2009
      McClure, Pa
      Local Time:
      5:12 AM
      I got one like the original off ebay 5 years ago, its electronic no problems with it, also Im running a hundred amp alternator.
