VOLTAGE REGULATOR.
Electrical and Ignition
  1. Snake
    Snake Mopar Nut
    9,274
    308
    May 22, 2006
    Belleville Canada
    Local Time:
    9:22 PM
    I have bean surcharging for a voltage regulator for my 71 but don't know what best on line, i have electronic ing now no points now.thanks again.
  2. furyus2
    furyus2 Well-Known Member
    2,266
    750
    Oct 30, 2010
    weeki wachee fl
    Local Time:
    10:22 PM
    Just get one for the 71. Most parts are off the same boat from china.
    • Agree Agree x 1
    • Dana67Dart
      Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
      7,812
      5426
      Jul 16, 2017
      Northern Colorado
      Local Time:
      8:22 PM
      I assume you are talking about the voltage regulator that keeps the charging voltage to the battery in the 13 to 14 volt range.
      This is the earlier single wire field (non isolated field) voltage regulator
      This is the later electronic voltage regulator 2 Field wires (isolated field)
      Which do you have now?
      electronic vs point ignition system is irrelevant to the voltage regulator
    • Snake
      Snake Mopar Nut
      9,274
      308
      May 22, 2006
      Belleville Canada
      Local Time:
      9:22 PM
      i have the bottom 1
    • Dana67Dart
      7,812
      5426
      Jul 16, 2017
      Northern Colorado
      Local Time:
      8:22 PM
      Then most any year/car specific auto parts store one will do. You could look for NOS and pay a premium but with the ease of replacement and the cheap price buy 2 at the parts store and keep one in the trunk as a spare.
      • Like Like x 1
      • Daves69
        Daves69 Well-Known Member
        6,034
        4555
        Feb 20, 2011
        WestOfChi
        Local Time:
        9:22 PM
      • furyus2
        2,266
        750
        Oct 30, 2010
        weeki wachee fl
        Local Time:
        10:22 PM
      • Daves69
        6,034
        4555
        Feb 20, 2011
        WestOfChi
        Local Time:
        9:22 PM
      • Dana67Dart
        7,812
        5426
        Jul 16, 2017
        Northern Colorado
        Local Time:
        8:22 PM
        Interesting...
        I would bet that the "high" performance unit has more filters to reduce the chance of a rouge ignition firing from noise it might produce.
        Or it was a way to sell a more expensive VR to hot rodders.
        I would love to see a stock and higher end unit opened up side by side.
      • Daves69
        6,034
        4555
        Feb 20, 2011
        WestOfChi
        Local Time:
        9:22 PM
        Lol, I installed the 732 VR on my '69 when I converted to elec. ign. way back. Seems to work just F & D even with a standard coil / ballast. I kinda' like the color too!:D
        • Like Like x 1
        • winky
          winky Wake me when I'm a famous Member
          45
          55
          Jul 27, 2014
          Calgary
          Local Time:
          8:22 PM
          Not sure where they get them from but National Mo-Parts in Beaverton, Ontario sells the fancy blue one and a correct looking black one for decent prices, yes, Canadian Dollar prices shown.
          National Moparts
          The black one does not have the 70/71 dimple and the date code may not be exact for your car but if you're worried about those details you probably would have mentioned it.
        • Snake
          Snake Mopar Nut
          9,274
          308
          May 22, 2006
          Belleville Canada
          Local Time:
          9:22 PM
          i got 1 on order 57 canadaian blue streak thanks gents.
        • QuickDart360
          QuickDart360 Well-Known Member
          1,438
          613
          Apr 5, 2014
          San Antonio
          Local Time:
          9:22 PM
          Blue Streak? Haven't from that brand in a while. Who sells that? If you don't mind.
        • Snake
          Snake Mopar Nut
          9,274
          308
          May 22, 2006
          Belleville Canada
          Local Time:
          9:22 PM
          local parts store.
