W100 4 speed 360 to 68 Cuda?
Small Block Mopar Engine
  1. tooslow
    tooslow Well-Known Member
    639
    26
    Mar 8, 2011
    lockport, Il
    Local Time:
    4:34 PM
    I have a 1976 W100 4x4 with a 4 speed and a 360 engine . The W100 cab is rusted out , shot , too far gone .
    I was thinking of putting the W100 360 and 4 speed in my 68 small block automatic Barracuda
    Would the combo work coming from a 4x4 W100 ??
    Any thoughts appreciated
  2. 66fs
    66fs FABO Gold Member FABO Gold Member
    5,999
    2550
    Sep 9, 2009
    Greenwood, South Carolina
    Local Time:
    5:34 PM
    Not sure the trans or bellhousing will work. Picture?
  3. RustyRatRod
    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
    77,845
    55313
    Jun 7, 2010
    Georgia
    Local Time:
    5:34 PM
    No. The W100 likely has the NP435 and that won't fit in the A body transmission tunnel.
    • Agree Agree x 2
    • Garethw
      Garethw Mopar. Because rocket science is too easy. FABO Gold Member
      573
      507
      Mar 10, 2015
      Georgia
      Local Time:
      4:34 PM
      What trans is in the Cuda now? Maybe just mate that up to the 360?
    • mopardude318
      mopardude318 Well-Known Member
      10,295
      1671
      Jan 7, 2005
      Gilroy, Ca
      Local Time:
      2:34 PM
      Yea that 435 is a heavy son of a gun. That ain’t no joke.
      • Agree Agree x 1
      • Unconventional
        Unconventional Well-Known Member
        15,385
        18026
        Apr 17, 2017
        Santa Maria, Ca.
        Local Time:
        2:34 PM
        If that trans is like most 4 spds in pickups of that era it's probably the un-synchronized 1st gear variety. Over weight 3 spd that can be used to pull stumps on occasion :lol:
        • Agree Agree x 2
        • RustyRatRod
          77,845
          55313
          Jun 7, 2010
          Georgia
          Local Time:
          5:34 PM
          The NP435 "just won't fit" in an A body. I can think of zero reason why you'd want it to anyway. Maybe doing a 4x4 conversion. lol
          • Agree Agree x 1
          • tooslow
            639
            26
            Mar 8, 2011
            lockport, Il
            Local Time:
            4:34 PM
            All I need to know and thanks
            I have a 383 and trans for the 68 Cuda . Stick with original Plan
            I was curious and now I Know
          • sireland67
            sireland67 FABO Gold Member FABO Gold Member
            9,833
            4118
            Oct 27, 2010
            WV
            Local Time:
            5:34 PM
            I will not fit, plus to actually use the trans, you would also have to use the transfer case.
          • cudamark
            cudamark FABO Gold Member FABO Gold Member
            8,946
            1422
            Mar 14, 2009
            San Diego
            Local Time:
            2:34 PM
            and a two piece driveshaft.....
          • cudamark
            8,946
            1422
            Mar 14, 2009
            San Diego
            Local Time:
            2:34 PM
            The 360 will fit, of course, but, you'd need to get all the small block car parts to make it work. Pan, pickup, dip stick and tube, engine mounts, brackets, exhaust manifolds, transmission, etc.....
          • sireland67
            9,833
            4118
            Oct 27, 2010
            WV
            Local Time:
            5:34 PM
            Alot of W-series had one piece rear drive shafts, but they did use a slip yoke.
            • Agree Agree x 1
            • cudamark
              8,946
              1422
              Mar 14, 2009
              San Diego
              Local Time:
              2:34 PM
              A 435 or 445 with a slip yoke? Never seen that setup. All the ones I've ever seen had a flanged output and 2 piece splined shaft. Do you have a photo of one with a slip yoke?
            • sireland67
              9,833
              4118
              Oct 27, 2010
              WV
              Local Time:
              5:34 PM
              I could take one, I would have to crawl under my dads W150 he bought new, next time I go up to his pace. His is all stock 360/435/203.
            • Dartswinger70
              Dartswinger70 Catch a wave youll be sittin on top of the world
              3,334
              1780
              Sep 20, 2005
              Southeastern Pa.
              Local Time:
              5:34 PM
              Its alot of work but couldn't you swap the out put shaft and tail housing to the truck unit and then it would go in the a body...? In other words, the truck trans would work with an A body output shaft and tail housing ...
            • Jadaharabi
              Jadaharabi FABO Gold Member FABO Gold Member
              8,984
              10254
              Jan 8, 2016
              Peoria, Illinois
              Local Time:
              4:34 PM
              A bodies never came with a truck transmission so where would you find an output shaft and housing? The other thing is the 360 in the truck probably has the 11 in flywheel and bigger bellhousing than what the cars came with.
              • Agree Agree x 1
              • mopardude318
                10,295
                1671
                Jan 7, 2005
                Gilroy, Ca
                Local Time:
                2:34 PM
                For any of y’all who are curious, here’s a 2 wheel drive/ divorced transfer case version I have I just dropped off to get rebuilt.
                It would be totally useless in a car. It’s almost worthless in my ‘74 4x4 to a point where I’m lookin to move my transfer case & crossmember back, and remove the under bed fuel tank and place a fuel cell in the bed, to make room for a standard A833.
              • cudamark
                8,946
                1422
                Mar 14, 2009
                San Diego
                Local Time:
                2:34 PM
                Yup, those are like the 2WD transmissions. They married them to the transfer case in '75. I actually liked the divorced setup better as they came stock with locking front locking hubs instead of the full time setup.
                • Agree Agree x 2
                • sireland67
                  9,833
                  4118
                  Oct 27, 2010
                  WV
                  Local Time:
                  5:34 PM
                  X2 a way better set up. I hate changing those full time wheel bearings.
                • RustyRatRod
                  77,845
                  55313
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  5:34 PM
                  Damn right! Let's do it!
                • RustyRatRod
                  77,845
                  55313
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  5:34 PM
                  Then send that big old sumbitch to me when you do. I'll give it a good home.
                  • Like Like x 1
                  • RustyRatRod
                    77,845
                    55313
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    5:34 PM
                    One more time. It won't fit.
                  • Dartswinger70
                    3,334
                    1780
                    Sep 20, 2005
                    Southeastern Pa.
                    Local Time:
                    5:34 PM
                    we'll make it fit...:lol:
                    • Thanks! Thanks! x 1
                    • Jadaharabi
                      8,984
                      10254
                      Jan 8, 2016
                      Peoria, Illinois
                      Local Time:
                      4:34 PM
                      With a torch and a welder anything can be made to fit.
                    • sireland67
                      9,833
                      4118
                      Oct 27, 2010
                      WV
                      Local Time:
                      5:34 PM
                      What about the lift kit for the car to keep that big old trans and transfer from dragging the ground.
