1. Scampin
    Scampin Well-Known Member
    251
    14
    Aug 27, 2005
    Local Time:
    11:05 AM
    Hey guys. I picked up a 340 from craigslist on a whim that happens to have a set of W2 heads and a mopar single plane intake. The guy that built the motor unfortunately passed away so I have very little information on it. It appears it was run for a very, very short time, enough to put some color on the pistons but not enough to show any kind of wear pattern on the cam. I bought the motor for the block, and have little interest in the W2 setup. Looking for opinions on what the top end is worth. Appears to have no porting, and the standard adjustable rockers. Any ideas would be appreciated. IMG_41491.jpg IMG_41521.jpg IMG_41521.jpg IMG_41471.jpg IMG_41441.jpg
    • Like Like x 6
    • fishmens67
      fishmens67 Well-Known Member
      9,908
      8440
      Nov 10, 2012
      idaho
      Local Time:
      10:05 AM
      :popcorn:
      • Like Like x 1
      • RustyRatRod
        RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
        71,748
        46935
        Jun 7, 2010
        Georgia
        Local Time:
        11:05 AM
        I would say 1500-2000 but are you mentally ill? That's about the best small block induction money can buy and you have it all.
        • Agree Agree x 4
        • Like Like x 2
        • Thanks! Thanks! x 1
        • vntned
          vntned Well-Known Member
          1,367
          925
          Apr 28, 2012
          Gibsonville NC
          Local Time:
          11:05 AM
          Those are the early style of W2 castings. They are the "Econo" W2 heads that do not require rocker shaft blocks. As well as use regular height valve springs. They don't support the same high lift that the full race heads do. Hell of a set of iron heads though. As cast they flow more than any iron small block Chevy or Chrysler head.
          Prices can vary. Demand isn't very high for those heads, as most guys these days are wanting aluminum heads.
          For example, I scored a fully ported set of early W2 race heads with a port matched intake last year for $400. That was an exceptionally good deal and perhaps not a good reflection of their value.
          Ive seen complete unported W2s go for $600-$800 locally. Online I've seen them similar to yours in the $1200 range.
          • Like Like x 1
          • toolmanmike
            toolmanmike FABO MODERATOR Staff Member FABO Gold Member
            58,709
            46119
            Jan 18, 2006
            Iowa
            Local Time:
            10:05 AM
            Good to find out what the parts are worth before putting them up for sale. Now, you other guys, do not, I repeat DO NOT offer to buy these on this thread. If you do you might find yourself taking a vacation from the site! Understood? Thanks.
            • Like Like x 2
            • Agree Agree x 1
            • RustyRatRod
              71,748
              46935
              Jun 7, 2010
              Georgia
              Local Time:
              11:05 AM
              Yeah but he has the expensive and hard to find rocker gear. ALL of it.
              • Agree Agree x 3
              • RustyRatRod
                71,748
                46935
                Jun 7, 2010
                Georgia
                Local Time:
                11:05 AM
                Can you get a picture of the chambers, please?
                • Like Like x 1
                • Agree Agree x 1
                • vntned
                  1,367
                  925
                  Apr 28, 2012
                  Gibsonville NC
                  Local Time:
                  11:05 AM
                  With the econo W2 heads, only the rockers are unique. The reason they were called "econo" heads, was solely due to the fact that they use the same valves, springs, retainers, and rocker shafts as standard X/J/O/U heads. So it would be way cheaper to put a complete setup together.
                  I'm not 100% sure, but I believe you can even get away with using TA rockers and shafts instead of the W2 specific rockers. I could be wrong on that one though.
                  • Disagree Disagree x 1
                  • vntned
                    1,367
                    925
                    Apr 28, 2012
                    Gibsonville NC
                    Local Time:
                    11:05 AM
                    Oh, and the chambers of the "810" and "810E" casting heads should be open chamber. Same as X/J/O/U heads.
                    • Like Like x 1
                    • SSG_Karg
                      SSG_Karg Heeeeeres Johnny!
                      1,478
                      1414
                      Feb 24, 2010
                      In the pits
                      Local Time:
                      11:05 AM
                      Run ‘em!!!!
                      • Agree Agree x 2
                      • RustyRatRod
                        71,748
                        46935
                        Jun 7, 2010
                        Georgia
                        Local Time:
                        11:05 AM
                        "Should be" but I've seen those same castings with both style chambers. That's why I asked.
                        • Agree Agree x 1
                        • RustyRatRod
                          71,748
                          46935
                          Jun 7, 2010
                          Georgia
                          Local Time:
                          11:05 AM
                          So whose sellin W2 style rockers? Econo or otherwise? They're hard to find and usually missing.
                          • Agree Agree x 1
                          • 70aarcuda
                            70aarcuda Master Hoader of SBM FABO Gold Member
                            16,310
                            4964
                            Jan 16, 2005
                            las vegas
                            Local Time:
                            8:05 AM
                            TA heads have a .550 offset on the intake....W2 have a .770 offset on the intake...also...the the bolts holding the shaft down are 3/8 thread instead of 5/16.....
                            • Agree Agree x 2
                            • 70aarcuda
                              16,310
                              4964
                              Jan 16, 2005
                              las vegas
                              Local Time:
                              8:05 AM
                              Harland Sharpe has both available...and even have aluminum TA rockers...
                              • Like Like x 1
                              • RustyRatRod
                                71,748
                                46935
                                Jun 7, 2010
                                Georgia
                                Local Time:
                                11:05 AM
                                Yeah but dig DEEP! Like they at the southern Baptist churches after they pass the offering plates and lock the doors. lol
                                • Like Like x 1
                                • Agree Agree x 1
                                • RustyRatRod
                                  71,748
                                  46935
                                  Jun 7, 2010
                                  Georgia
                                  Local Time:
                                  11:05 AM
                                  And I knew they did....I was referring to the ductile iron ones.
                                  • Like Like x 1
                                  • yellow rose
                                    yellow rose Overnight Sensation FABO Gold Member
                                    28,158
                                    24453
                                    Jun 19, 2015
                                    Central Washington
                                    Local Time:
                                    8:05 AM
                                    Not sure what you call early style but those certainly aren’t what I call early W2’s. Some of those heads can have the stands milled down and they are the same as the race head, although I’m not sure that head is from that era.
                                    Also, the rocker gear is the same for the Econ and the race head with the exception of the race rockers being bushed. You can put bushings in those rockers and they would be the race rockers.
                                    Still not sure why the OP won’t run them. You have everything. I’d use them in a New York second.
                                    • Agree Agree x 3
                                    • 70aarcuda
                                      16,310
                                      4964
                                      Jan 16, 2005
                                      las vegas
                                      Local Time:
                                      8:05 AM
                                      Dont think anyone is making the old ductile rockers .....bushed or not bushed.......i like bush .....she is a red head...oh...sorry
                                      some people are hoarding them...lol
                                      • Agree Agree x 3
                                      • RustyRatRod
                                        71,748
                                        46935
                                        Jun 7, 2010
                                        Georgia
                                        Local Time:
                                        11:05 AM
                                        Exactly my point.
                                        • Agree Agree x 1
                                        • greymouser7
                                          greymouser7 Vagrant Vagabond “Veni Vidi Vici” FABO Gold Member
                                          3,479
                                          2754
                                          Apr 17, 2010
                                          78002 down the road from Atascosa, Texas
                                          Local Time:
                                          10:05 AM
                                          There are some econo heads that operate with longer valves.
                                          • Agree Agree x 1
                                          • 70aarcuda
                                            16,310
                                            4964
                                            Jan 16, 2005
                                            las vegas
                                            Local Time:
                                            8:05 AM
                                            Correct....there is a long valve and standard length valve econo w2 heads....got a set of each....
                                          • lemondana
                                            lemondana BlackDart
                                            652
                                            406
                                            Dec 7, 2007
                                            Southeast NE
                                            Local Time:
                                            9:05 AM
                                            Jesel and TD both make W2 rockers setups. I have a NOS set of the early 810 casting W2's, they have the milled down shaft stands. When the stands are milled down-that is for the longer valves and offset shafts, right?
                                          • 70aarcuda
                                            16,310
                                            4964
                                            Jan 16, 2005
                                            las vegas
                                            Local Time:
                                            8:05 AM
                                            Yes those are the race head....they need stands and offset shafts........and they take the long valves.....
                                            • Krooser
                                              Krooser Reform School Graduate
                                              3,029
                                              2559
                                              Jul 19, 2015
                                              Central Wisconsin
                                              Local Time:
                                              10:05 AM
                                              Rocker arms are readily available on the used market or new if you buy T&D or Jesel. Yes the best will cost.a little more but when doesn't it?
                                            • Krooser
                                              3,029
                                              2559
                                              Jul 19, 2015
                                              Central Wisconsin
                                              Local Time:
                                              10:05 AM
                                              My econo heads had the built in stands but the original builder milled them off but still used the std. length valves. I replaced the 3/8 valve for 11/32 with longer stems.
                                              The original purple shaft cam was under .500 lift and one of my new cams is .619 so I played it safe with longer valves.
                                              I can't imagine replacing the w2 heads with any popular alloy heads... loose HP to save some weight? Now if you are talking Edelbrock Victor or BA-B1-MC heads that's different but most guys just want to drag along less weight but look the other way when they load up their 275lb. GF....
                                              • Like Like x 1
