1. barcat
    barcat Member
    5
    1
    Nov 11, 2018
    Dike, Ia
    Local Time:
    3:29 PM
    I have a 68 Barracuda, w/power steering. Complete rebuild about 4 yrs ago, all new front end parts and reman steering box, only 600 miles since done. Drove great first 3 yrs. This year it wanders bad just driving down road. What happened?
  2. Alaskan_TA
    Alaskan_TA Well-Known Member
    4,166
    1936
    Nov 12, 2004
    PA
    Local Time:
    4:29 PM
    Lots of possibilities.
    Loose lug nuts.
    Bent rim.
    Failed tire chord or sidewall.
    Something in the linkage came loose, etc., etc.
  3. Lee Robinson
    Lee Robinson FABO Gold Member FABO Gold Member
    5,728
    179
    Aug 23, 2009
    El Dorado Hills, Ca.
    Local Time:
    3:29 PM
    How old are your tires? I have a 64 Fairlane that had a bad wandering problem. New suspension components,
    tightened box, aligned for old car with radial tires. Tires had little wear but were 10 -11 years old. New tires
    vastly improved handling.
  4. AJ/FormS
    AJ/FormS 367 FormS clone 3.09-1.92-1.40-1.09-.78od 3.55s FABO Gold Member
    15,004
    4148
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    3:29 PM
    Put it on the alignment rack with new tires. Tell the tech to go find the root cause.
    It could just be the tires or how the tires are wearing. or it could be due to toe-change or camber-change, scrub-radius,worn parts, a bad steering box, or a shock gone bad.
    It could even be rear-steer from springs, shackles, mounts, or a thrust angle.
    It could even be in the unibody.
    So your tech-guy needs to be sharp.
  5. Alaskan_TA
    4,166
    1936
    Nov 12, 2004
    PA
    Local Time:
    4:29 PM
    Another situation from years ago, the steering box bolts would come loose every few months.
    The threads were good & so were the lock washers, so I just got in the habit of snugging the bolts down about once a month to be safe.
    • Agree Agree x 1
    • 65 Dartman
      65 Dartman FABO Gold Member FABO Gold Member
      9,575
      1597
      Sep 24, 2006
      Strasburg, VA
      Local Time:
      4:29 PM
      Unless it were done by Steer and Gear or Firm Feel, I’d be looking at that especially if a mass rebuildeer like Cardone did it. A friend got a rebuilt unit from Rock Auto and less that a thousand miles it was doing the wander. A rebuilt from Steer and Gear in their Stage II solved the problem.
      • Agree Agree x 2
      • Mattax
        Mattax Just the facts, ma'am FABO Gold Member
        4,934
        2590
        Feb 7, 2013
        Phila. Pa
        Local Time:
        4:29 PM
        Methodiclly check for the culprits.
        Steering play. There's often a little play in the box when the car isn't moving and wheels are straight. That said..
        First - check the wheel bearings aren't loose. If there is in/out movement when you hold the wheel top and bottom (12 and 6),tighten to specs.
        Second - With one wheel on the ground move the wheel off the ground as the steering wheel would (hands at 3 and 9 oclock). Watch each link and joint in the steering linkage until you see the movement.
        Then do it from the other side. Get a helper if you need. I prefer to do it myself even though it was awkward because I can feel the movement if there is any and match it with what I'm seeing. Even though there's no steering lock, you'll see the pitman arm rock if there's wear or slop in the steering gear's bearings.
        Finding nothing in the front, check the rear springs at both the hangers and shackels. Bet you find something in the front though.
        One more tip. Look at each tire for clues in the wear patterns.
      • barcat
        barcat Member
        5
        1
        Nov 11, 2018
        Dike, Ia
        Local Time:
        3:29 PM
      • barcat
        barcat Member
        5
        1
        Nov 11, 2018
        Dike, Ia
        Local Time:
        3:29 PM
        Sorry it took me so long. Everything is tight and checks out fine. BUT. A lot of slop in steering wheel, 3 inches, seems to be in coupling spline.
      • furyus2
        furyus2 FABO Gold Member FABO Gold Member
        1,850
        431
        Oct 30, 2010
        weeki wachee fl
        Local Time:
        4:29 PM
        If you turn the wheel with the engine off, and you see the part of the shaft coming from the box is rotating with the steering wheel, it's the box. If the shaft from the box stays still, and the shaft from the column rotates, it's in the coupler. Sometimes they are installed wrong, with the two blocks on the end of the column turned the wrong way.
      • barcat
        barcat Member
        5
        1
        Nov 11, 2018
        Dike, Ia
        Local Time:
        3:29 PM
        The steering shaft is turning, not the box. I pulled the shaft, spline in coupler looks worn. Looked for coupling to replace, can't find one for power steering. Not sure if anything else will work, other couplings?
      • toolmanmike
        toolmanmike FABO Staff Staff Member FABO Gold Member
        35,217
        17194
        Jan 18, 2006
        Iowa
        Local Time:
        3:29 PM
        Welcome Denny? You can usually rebuild the couplers.
        Mega Parts USA - Reproduction, NOS and Used Mopar Muscle Car Parts
      • toolmanmike
        35,217
        17194
        Jan 18, 2006
        Iowa
        Local Time:
        3:29 PM
      • replicaracer43
        replicaracer43 Old school member
        3,749
        2187
        Oct 10, 2008
        Local Time:
        3:29 PM
        In my experience, MOST of the times the coupler is assembled wrong, not worn.....refer to the service manual.
        • Like Like x 1
        • Agree Agree x 1
        • barcat
          barcat Member
          5
          1
          Nov 11, 2018
          Dike, Ia
          Local Time:
          3:29 PM
          Coupler was right, it drove great till recently. Thanks for info.
          • Like Like x 1
