[WANTED] Wanted 6-1/4" Midland Brake Booster 69 A-Body
dpalsmeier
Active Member
Goddard,Ks
Rating - 0%
0   0   0
Looking for 6-1/4" Midland Brake Booster. 67 to 69 A-Body front disc application.
For size reference, photo of seven inch with measurement has been added.
Can you get a pic that shows diameter?
Perhaps lay a framing square along bolt pattern surface?
Thanks
Here is what I have . The booster was restored my the Ram Man. It was for a 1968 GTS dart with front disks brakes. Original. 383 4- speed . I don’t think the diameter is 6 1/4 closer to 7”
If you are looking for a factory Midland unit for 67-69, which matches your listing pics, it would be the Midland 7” 1967-1972 application unit.
The second pic you included in your wanted post reflects a 3.5” Radius measurement, which also matches the 7” diameter referenced. Midland does/did not make a 6 1/4” unit installed in 67-69 MOPARS. Booster Steve could confirm this.
The 6" suggestion came from my Friday phone call with Booster Steve.
Also, 6-1/4" Midland (small photo) appears on the website for Harmon Classic Brakes.
Got you, sounds like you are going with a non-factory/MOPAR set-up, best of luck.
Restoration shop put on a GM KIT Booster & MC. I have factory correct discs and spindles for 65 Dart. Looking to clear the 273 Charger valve covers with something closer to factory.
thanks for the feedback.
