water pump rebuild?
4spdragtop
Ontario Parts Unknown
Anyone have a part # for seal and for a bearing for sb water pump? I would like to clean it up while its out.
For a 67 273 with ac.
Thanks
Steve
Let me check the trash, I just threw out a cast iron water pump for a 68 318. It worked fine, no leaks. If the trash guy hasn't come by yet, you can have it for shipping from 95409. I think it's around 10 pounds.
Thanks OM. Don't go dumpster diving,mine is fine. While mine is removed I planned on sandblasting and painting. Would be nice to replace bearing n seal while its off.
Thanks for the part offer.
Oh yours might be worth hanging onto if its for ac?
No a/c, just power steering
Here's a couple numbers. Hope this helps 66 273 with AC. Dustin
The rebuilders want that core. There isn't ample supply of cast iron water pump cores. If new are available they are surely Chinese.
Yes I agree Ben. Thats why I want to rebuild mine. I found a seal number from National/ Federal #7013s. $20 I didnt want to order yet as I need to find a bearing # yet.
Anyone with a bearing number?
If you'll google images, water pump parts or water pump kits, you'll find there are more than a couple of pieces req'd to rebuild one. 50 bucks average for a complete kit, plus what tools you might need to do it right, versus buying a reman'd pump with a warranty.
