Weld stud size for leaf spring
Discussion in 'Suspension, Steering and Chassis' started by Hilderbrand1983, Oct 27, 2018.
  1. Hilderbrand1983
    Hilderbrand1983 Well-Known Member
    118
    21
    Jun 6, 2016
    Indiana
    Local Time:
    9:23 AM
    The Dart has struck again! My 1967 Dodge Dart 270, that is. I'm installing new leaf springs from ESPO. The forward mount (which holds the pivot bolt) on both sides of the vehicle had a weld stud snap on me. An either/or dilemma now faces me.
    Either
    (a) it is safe enough to drill out the stud and weld a new one in (in which case, what size am I looking for?),
    or
    (b) I need to buy a new mount (in which case, where can I buy a stock one?)
    Ideas? Thanks ahead of time for your help!
  2. zkx14
    zkx14 Duster De-ruster FABO Gold Member
    17,767
    9798
    Dec 23, 2012
    South Central PA
    Local Time:
    9:23 AM
    They are splined. Pressed in. Should b able to knock it out with a hammer. I may have some good ones in a junk hanger...
  3. Hilderbrand1983
    118
    21
    Jun 6, 2016
    Indiana
    Local Time:
    9:23 AM
    Thanks! I wailed on it a little and the broken studs popped right out.
    Do you know what size of new, splined stud I need to get?
  4. famous bob
    famous bob mopar misfit
    11,017
    2672
    Aug 14, 2011
    okla
    Local Time:
    8:23 AM
    If worse comes to worse, why not get a bolt exactly the same size and thread , and tack weld the head of it and fagetaboudit----
  5. zkx14
    17,767
    9798
    Dec 23, 2012
    South Central PA
    Local Time:
    9:23 AM
    That would certainly get the job done. Not sure what grade they should be, 5 or 8
    3/8-16 x 1-1/4. Don't know anything about the spline sizing. How many do you need? I have a junk hanger with 2 useable studs...
  6. Hilderbrand1983
    118
    21
    Jun 6, 2016
    Indiana
    Local Time:
    9:23 AM
    As luck would have it, I need EXACTLY two studs. Would you PM me a price and we can go from there? Thanks!
  7. zkx14
    17,767
    9798
    Dec 23, 2012
    South Central PA
    Local Time:
    9:23 AM
    OK, I will get them out...
