1. InItSwingIt
    InItSwingIt Well-Known Member
    89
    34
    Nov 24, 2014
    santacruz
    Local Time:
    12:59 AM
    Anybody ever weld up the spiders on a 7.25 cus thier a chepo like me... whatd you put it behind, how hard you drive it, and how long did it last, and what breaks next... thanks in advance...
  2. chryslerfat
    chryslerfat Well-Known Member
    11,716
    3122
    Aug 23, 2008
    Monroe,Michigan
    Local Time:
    1:59 AM
    I have done it for mud in a demo derby the next weak spot is the shafts.
    • Agree Agree x 1
    • TrailBeast
      TrailBeast Slightly Twisted Member
      19,781
      6299
      Mar 11, 2011
      Arizona
      Local Time:
      10:59 PM
      Ok, who did what here?
      I posted this in the "heater smokes up the interior" thread.:D
    • chryslerfat
      11,716
      3122
      Aug 23, 2008
      Monroe,Michigan
      Local Time:
      1:59 AM
      lol somehow my quotes were not as fast as I was posting lmao
    • InItSwingIt
      89
      34
      Nov 24, 2014
      santacruz
      Local Time:
      12:59 AM
      Kinda what i thought... less it was a bearing or sum... how much abuse did ot take before it went... i take it you abused it pretty good behind a 318 or 360?...
    • InItSwingIt
      89
      34
      Nov 24, 2014
      santacruz
      Local Time:
      12:59 AM
      Lol... no akin off my back
    • InItSwingIt
      89
      34
      Nov 24, 2014
      santacruz
      Local Time:
      12:59 AM
      So i can just assume itll be fine for driving around town and doing burnouts? Untill it decides it isint ok anymore and snaps an axle... yea?
    • chryslerfat
      11,716
      3122
      Aug 23, 2008
      Monroe,Michigan
      Local Time:
      1:59 AM
      What is going to make it break a shaft is on turns both shafts do not turn the same speed. Slow on turns and it may make a few burnouts. lol
      • Agree Agree x 1
      • mbaird
        mbaird mbaird FABO Gold Member
        4,581
        1700
        Dec 10, 2005
        boise, Id
        Local Time:
        11:59 PM
        Sure you did Beast.... Sure you did....
        Now go take a short nap and everything will be ok when you wake up.
        Getting old is tuff.... Lol
        • Agree Agree x 1
        • InItSwingIt
          89
          34
          Nov 24, 2014
          santacruz
          Local Time:
          12:59 AM
          If i weld it theyll go the same speed, which is the prob... lol... i get what ur sayin tho... straight line burn outs and try and stay out of it around hard turns...
          • Agree Agree x 1
          • TrailBeast
            19,781
            6299
            Mar 11, 2011
            Arizona
            Local Time:
            10:59 PM
            Ok, so I went and took a nap and it didn't help. :D
            Something got crossed with another thread somewhere, and I'm not EVEN going to try and figure out where.
            I even have proof.:D
          • InItSwingIt
            89
            34
            Nov 24, 2014
            santacruz
            Local Time:
            12:59 AM
            Hahah... well... now that ypu had a nap, and since your here, how long you think an welded 7.25 will last?...
          • TrailBeast
            19,781
            6299
            Mar 11, 2011
            Arizona
            Local Time:
            10:59 PM
            It's hard to say really, since the wear on it already and how much grip the roads average, along with how many tight turns on those roads are done.
            Personally, even though I almost did it myself I think it's kind of a once done it's on it's way to being over.
            You just never know when.:D
            • Agree Agree x 2
            • pishta
              pishta I know I'm right....
              14,605
              4261
              Oct 13, 2004
              Tustin, CA
              Local Time:
              10:59 PM
              I broke a 3.55 7 1/4 SG behind a 340 in my '65. The pinion took a chunk out of the ring gear and the pinion then turned into a barrel. Now it may have ingested a piece of broken spider gear or something but it was a stinky mess in there. That was on 10" wide tires so there was some 'stress' on this rear end. Replaced it over the weekend with a Junk yard 2.76 one legger so I could get to school and that car was never the same.
              • Agree Agree x 1
              • InItSwingIt
                89
                34
                Nov 24, 2014
                santacruz
                Local Time:
                12:59 AM
                I feel it... your kind of sign its death warrent from the start....on the other hand, people practically give em away, even if i go thru a couple it probly wont cost me close to anything... itll probly give out if i ever get that 360 in there though...
                • Thanks! Thanks! x 1
                • 69conv
                  69conv leaky gasket FABO Gold Member
                  2,231
                  1419
                  Jan 27, 2013
                  Motor City
                  Local Time:
                  12:59 AM
                  7 1/4 are practically falling out of the trees, so if you don't mind the labor...
                  • Agree Agree x 2
                  • TrailBeast
                    19,781
                    6299
                    Mar 11, 2011
                    Arizona
                    Local Time:
                    10:59 PM
                    I don't know as I have layed into mine pretty hard with a mild built 5.9 Magnum, but it's always been just throttle and no harsh shocks on it.
                    When I was considering it was because I am going to put an 8.25 anyway, but then I realized the Wife's 72 is going to be needing the large bolt pattern, so I decided to spare it the certain death.
                    • 67Dart273
                      67Dart273 Well-Known Member
                      39,519
                      7169
                      Oct 14, 2010
                      Idaho
                      Local Time:
                      10:59 PM
                      You might keep in mind that breaking a shit rear end can ruin the sprag in the automatic, "if that's what you have."
                      Actually, "in the old days" a friend of mine broke the 10 bolt in his 65 Chevelle, and after we got the axle replaced, we discovered THE MUNCIE 4 SPEED INPUT SHAFT HAD SNAPPED
                      This is the guy who later was the first owner of my 70 440-6 RR. When I arrived at Navy Electronics "A" school at Treasure Island in the fall of 68, and eventually made my way to the then fantastic amateur radio club, K6NCG,
                      (Some photos of the club here:)
                      K6NCG - Treasure Island Radio Amateur Club 1969-1970
                      here sits George's 65 Chevelle. "It turns out" that he had bought and junked out a low miles wrecked 67 350, 4 speed Camaro. So now the 350/ 4 speed and Rally wheels were on the Chevelle
                      "Sometime later" after we had become friends, he was (as usual) building up the muscles in his right (throttle) foot, his left (clutch) foot, and his "shifting arm" ..........getting onto the San Francisco Bay Bridge leaving "the Island" and broke the rear axle going into second gear off the on ramp.
                      We coasted for awhile, "dived" into a turnout on the bridge just as the rear end locked up. There were 3 or 4 of us in the car, I don't remember. Two of use jacked up the car and got one rear wheel setting on the spare tire. I crawled under and removed the rear cover. The C clips fell out as we tried to gut the thing and get it to turn, and neither of us!!! knew what the C clips were for!!!
                      So here comes the tow truck, who decides to PUSH US down off the bridge. As we went down the ramp, an horrible rubbing of the tires insued!!!! Of course there ARE NO BRAKES because this is before dual master cylinders!!!
                      But George is a pretty smart guy, and already had a "line lock" on the car. He pushed the button, and "stabbed" the brakes a couple of times to build a bit of pressure in the fronts..........and we rolled to a gentle stop at the bottom of the bridge!!!
                      Tow truck went around, hoisted the rear, and towed us all back to the island!!! LMAFAO!!!!
                      We bought a used 10 bolt at a junk yard, and put the thing in. Started 'er up and IT WENT NOWHERE!!!
                      NOTICE this photo of a Muncie shaft I found on the www
                      NOTICE the groove around the shaft splines........I know not what they are for, but that shaft BROKE RIGHT THERE in that groove just as clean as could be, and !!!POOF!!! we have a 'free' alignment tool for putting the clutch in!!!
                    • InItSwingIt
                      89
                      34
                      Nov 24, 2014
                      santacruz
                      Local Time:
                      12:59 AM
                      Hahhah... the c clip thing got me. I had not thought about the sprag. Its just a 904. If i recall, bad sprags can lead to exploding torqflight syndrome... but a 7.25 on tired old springs shouldent be too dramatic if it snaps an axel... it wont do the chevy "pull out" thing if it snaps will it? (Like with C clips, lol).... my wheels not falling off or anything crazy?
                    • Kern Dog
                      Kern Dog Well-Known Member
                      2,977
                      2902
                      May 23, 2010
                      Granite bay CA
                      Local Time:
                      10:59 PM
                      Have you noticed that nobody likes this idea? Get some money together and do it right.
                      • Agree Agree x 1
                      • chryslerfat
                        11,716
                        3122
                        Aug 23, 2008
                        Monroe,Michigan
                        Local Time:
                        1:59 AM
                        Yes when an axle shaft snaps it comes out on its own with a 7 1/4
                        • Like Like x 1
                        • 67Dart273
                          39,519
                          7169
                          Oct 14, 2010
                          Idaho
                          Local Time:
                          10:59 PM
                          Yup. ANY C clip axle. You either break an axle or break something that "removes" the clip it will come right out.
                          • Like Like x 1
                          • InItSwingIt
                            89
                            34
                            Nov 24, 2014
                            santacruz
                            Local Time:
                            12:59 AM
                            I never opend up a 7.25 before... i didint realized it was a C clip deal... that kinda blows... i might still do it anyways...
                          • whitepunkonnitro
                            whitepunkonnitro FABO Gold Member FABO Gold Member
                            14,804
                            928
                            Dec 6, 2011
                            Murfreesboro Tn
                            Local Time:
                            12:59 AM
                            7.25s are NOT C clip rears...and welding one up will increase its strength tremendously.
                            Moderate weight car...less than 3500 wet, less than 300 horsepower and auto trans, it should last a good, long time.
                            • Like Like x 1
                            • 67Dart273
                              39,519
                              7169
                              Oct 14, 2010
                              Idaho
                              Local Time:
                              10:59 PM
                              I agree with the first, but not necessarily the last. I know a couple guys who broke them with 318s. Just depends on "how big" your foot is LOL
                              Since this is winter, when I was really young, long about the winter of 67-68---I drove a 57 Chev clear through winter with "weld-a-lock." "It was interesting."
                              Just the other day I had fun kicking the (limited slip) Dakota around a corner in 2 WD. The local PD would have not been impressed LOL
                              • Like Like x 1
