Welder recommendations
Shop, Garage and Tools
  1. Pascamp
    Pascamp Well-Known Member
    854
    727
    Feb 27, 2016
    USA
    Local Time:
    11:11 PM
    C25 will do almost anything steel. Argon is for aluminum. I use tri for stainless. Straight CO2 burns hot and dirty, is cheap, but has it's uses. That's a gross over simplification, but it'll do 99% of the time.
    • Like Like x 1
    • MoparMike1974
      MoparMike1974 FABO Gold Member FABO Gold Member
      2,751
      1999
      Jun 16, 2017
      Maryland
      Local Time:
      11:11 PM
      I upgraded from an old L-TEC (made by esab I think). It was about 20 years old and I was having trouble getting parts for it.
      Bought a Miller Matic 211 and love it. Its all transistor based so no transformer to add a bunch of weight. Super light and portable and a great performing machine.
      I just bought a spool gun for it to do aluminum. Hope to get some time to test it out soon.
      Plasma cutter is nice to have but you cant replace a torch, its a must have shop tool. Another must is a milwaukee porta-band. The new cordless ones are awesome.
      • Like Like x 1
      • Pascamp
        854
        727
        Feb 27, 2016
        USA
        Local Time:
        11:11 PM
        I have the spoolmate 150 and have had zero problems with it. If they sold a hip holster for the portaband, I'd wear it like a cowboy. My Milwaukee impact would be on my other hip. I use those two tools daily and mercilessly.
        • Like Like x 1
        • 71GSSDemon
          71GSSDemon Well-Known Member
          2,160
          2908
          Jul 27, 2018
          Oshkosh, WI
          Local Time:
          10:11 PM
          I have a Miller XMT304 MIG/TIG/stick inverter welder at home. Extremely versatile and can weld anything I could ever need, minus aluminum as the AC conversion alone was $1200. Nope, will weld that stuff at work and save the money.
          • Like Like x 1
          • MoparMike1974
            2,751
            1999
            Jun 16, 2017
            Maryland
            Local Time:
            11:11 PM
            I have a dozen or more of the M18 milwaukee tools, they are all great.
            I use the cordless porta band most of the time but also have a corded one on the milwaukee table.
            • Like Like x 1
            • red67gts
              red67gts FABO Gold Member FABO Gold Member
              2,104
              865
              Apr 14, 2009
              Coker,Al
              Local Time:
              10:11 PM
              I have chop saws, port a band, torches but my go to most of the time is Metabo grinder. I can use cutting disc and have it cut before I can get the others out or quick change to grinding disc.
              • Like Like x 1
              • nm9stheham
                nm9stheham Well-Known Member
                12,090
                3943
                Dec 20, 2013
                Waynesboro, VA
                Local Time:
                11:11 PM
                I'd encourage you to read and not just take word of mouth... here is a start:
                Common Shielding Gases Used for Arc Welding | Lincoln Electric
                • Thanks! Thanks! x 1
                • Penstarpurist
                  Penstarpurist Well-Known Member
                  1,277
                  602
                  Oct 28, 2016
                  Salem
                  Local Time:
                  8:11 PM
                  Sounds like I have been denying myself some pretty good tools. I definitely want a cordless handheld porta saw now. And thanks for the link nm9stheham, I'm going to do some reading of it now. I need to check out a metabo grinder. Sounds like a beast.
                • Garry in AZ
                  Garry in AZ Building a 9 second Valiant
                  367
                  460
                  Jul 13, 2017
                  Mesa, AZ
                  Local Time:
                  9:11 PM
                  For a good all round MIG welder the Miller 211 is hard to beat. Use a 75/25 gas mix for best results.
                  On the plasma cutter issue, I put off buying one for over 15 years. When it came time to back half the Valiant, I finally pulled the trigger on a Hypertherm 45XP. Couldn't be happier with it, and I think it was money well spent. Sure, I could have used a cutoff wheel... but look at the cut the plasma made through a 3/8" thick weld. This cut took maybe 20 seconds. I like having the plasma around for jobs like this where the alternative would be a lot more time and effort.
                  • Like Like x 1
                  • Penstarpurist
                    1,277
                    602
                    Oct 28, 2016
                    Salem
                    Local Time:
                    8:11 PM
                    That is impressive. Would definitely be a chore with a cut off wheel.
                  • george joseph reid
                    george joseph reid Well-Known Member
                    101
                    39
                    Aug 22, 2018
                    Elmira Oregon
                    Local Time:
                    8:11 PM
                    One option is the Lincoln Easy Mig 140. Got one last year from Blains Farm supply shipped for under $500. Dose all I need it to do.
                    • Penstarpurist
                      1,277
                      602
                      Oct 28, 2016
                      Salem
                      Local Time:
                      8:11 PM
                      I'll definitely check out the lincoln easy mig 140. Sounds like a great price .
                    • RustyRatRod
                      RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
                      65,915
                      39261
                      Jun 7, 2010
                      Georgia
                      Local Time:
                      11:11 PM
                      I have a small 115V Craftsman made by Clarke. It's nice. Done everything I have tried to do. It's convenient for me because I don't need a huge one.
                    • justinp61
                      justinp61 Well-Known Member
                      1,748
                      1198
                      May 15, 2009
                      Local Time:
                      10:11 PM
                      I have Millers, a Millermatic 210 with a spool gun and a Syncrowave 250DX stick tig. Most of the time the mig welder gets used but I do use the stick and tig too. At some point I will have a plasma cutter, I borrowed my buddies when I mini tubbed my Dart, its a great versatile tool. I also have band saws, a cutting torch, bench grinders, porta band and angle grinders. They all have a purpose.
                      • Like Like x 1
                      • Penstarpurist
                        1,277
                        602
                        Oct 28, 2016
                        Salem
                        Local Time:
                        8:11 PM
                        Yeah I have been doing some research and tool shopping on several pieces. I am going to go all in to get my shop up to date and stocked with good quality tools. Not that I wont buy h.f tools, as they have stuff that is good to use. But some stuff like welders, compressors, heavy style usage stuff. It's time to go with the best on those things. I've shorted myself long enough, kids got jobs and are starting to support themselves. The money saved is going into stuff we can all enjoy and make money with in the future.
                      • 383Duster
                        383Duster Well-Known Member
                        1,866
                        512
                        Jan 11, 2009
                        Dallas, TX.
                        Local Time:
                        10:11 PM
                        Can’t complain about my Hobart 140 amp 110volt welder....
                        • Like Like x 1
                        • gzig5
                          gzig5 Well-Known Member
                          1,385
                          1361
                          May 3, 2018
                          Mequon, WI
                          Local Time:
                          10:11 PM
                          I got the Hobart 190 MIG welder last year with the aluminum spool gun option from Fleet Farm. It has performed perfectly so far. Haven't tried the spool gun yet but I have a job for it coming up. Nice part was the cheaper price than a comparable Miller, and it still uses the good quality and easily available consumables. I probably could get by with the 140 for all the work needed on the car, but the extra power is nice for thicker structural work.
                          • Like Like x 1
