67Dart273
T' other day the little Farmall 100 started sounding more like a 3 whanger Johnny popper Deere than a smoooooooooooooth running 4..................
So pulled plugs, compression check, no4 is a big fat ZEro.........and soon the rocker cover is off and theres a ???WHUT??? a DISPLACED PUSH ROD??? DEL DEL DEL, HOW many RPMs?
Anyhow the valve was STUCK. They all look "oily" and I ended up flooding it with some WD, freed right up, popped the push rod in, and away we go.
Do de do dooo Do de do dooo as they used to play on "The twilight zone"
