1. darepairman
    darepairman Well-Known Member
    152
    16
    Sep 18, 2009
    Pewaukee Wisconsin
    Local Time:
    5:23 PM
    nowI have a 72 Dart with a 318 headers and 2.250 duels that exit each side just in front of the tires. I had glass packs on it and they had too much of a crack to them so I went to Flomaster super 44s. now when I run it I get fluid spraying out of the exhaust. it don't smell like gas or feel like oil. could this be a condensate problem or is the timing just a coincidence and I need to look somewhere else?
    Thanks in advance
    Ed/
  2. DesertRat
    DesertRat FABO Gold Member FABO Gold Member
    2,571
    1447
    Jan 22, 2005
    Moses Lake, Washington
    Local Time:
    3:23 PM
    For me step one would be determining what it is.
    • Like Like x 1
    • Alaskan_TA
      Alaskan_TA Well-Known Member
      4,243
      2028
      Nov 12, 2004
      PA
      Local Time:
      6:23 PM
      Condensation in exhaust systems is common.
      Some factory systems even had drain holes.
      • Like Like x 1
      • Tooljunkie
        Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
        8,166
        6693
        Jul 22, 2017
        Manitoba
        Local Time:
        5:23 PM
        For every gallon of gas you burn a gallon of water is produced.
        It only does it during warm up i imagine,once exhaust heats up, the condensed water is cooked out of exhaust system.
        • Like Like x 1
        • darepairman
          152
          16
          Sep 18, 2009
          Pewaukee Wisconsin
          Local Time:
          5:23 PM
          thanks for the replies, ya its water I am sure, I just didn't have this with the glass packs. I will have to warm it up and see. Ill post what happened tomorrow
        • Plymouth 65
          Plymouth 65 Floorable Deplorable
          649
          442
          Jun 27, 2016
          Mich
          Local Time:
          6:23 PM
          H2O is a byproduct of complete combustion. My 340 exhaust tips have drain holes. Gone soon as she warms up, all good! 65'
          • Like Like x 1
          • Agree Agree x 1
          • YY1
            YY1 Well-Known Member
            5,541
            1345
            Oct 11, 2011
            FL
            Local Time:
            6:23 PM
            Yes, theoretically a gas combustion engine should only produce carbon dioxide and water (IIRC).
            The more clean water you have dripping out of your exhaust, the cleaner and more efficient your engine is running.
            My 67 Coronet 318 dripped a significant amount of water, ran so smooth you could balance a pen on the air cleaner lid at 600 RPM and rev it, and got over 22 MPG highway.
            • Like Like x 1
            • AJ/FormS
              AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
              15,221
              4335
              Jan 19, 2014
              South-Central Manitoba,Canada, 900ftelevation
              Local Time:
              5:23 PM
              The glasspacks held the water in the packing, it was still there. Then it cooked out after the muffler warmed up.That's why cheap glasspacks usually rust out pdq.
              Your 44s IIRC are empty boxes, so there is nothing in them to prevent the incoming exhaust to blow across the water pooled inside them, and carry it the short distance to your dumps, as still a liquid.
              I drilled 1/8th" drain-holes at the lowest points of the mufflers, and also at the lowest points of my over-the-axle tailpipes, just for this reason. I'd rather have a bit of water on the floor, than blowing onto whatever is behind .
              My exhaust system is coming 19 years old and has no visible rust on it.Good thing! because that TTI stuff was not cheap; it's down to under $29 per year now.
              • Like Like x 2
              • darepairman
                152
                16
                Sep 18, 2009
                Pewaukee Wisconsin
                Local Time:
                5:23 PM
                All good responces, I guess I have no problem. I was just kind of freaked at the situation I have never had this before, maybe I just pay closer attention to this car. Thanks
              • j par
                j par Well-hung Member
                11,914
                4842
                Jul 2, 2014
                Portland Oregon
                Local Time:
                3:23 PM
                yes if the water keeps flowing out after it's completely warmed up then you have problems! I was over at a friend's house and his kid was pouring water in his radiator and it was steadily coming out of his tail pipe! THAT'S A PROBLEM!
              • YY1
                5,541
                1345
                Oct 11, 2011
                FL
                Local Time:
                6:23 PM
                Not necessarily.
                That Coronet dripped about 6-8 drops per minute after being warmed up.
                It did NOT drip until it got warm.
