What’s everyone using to fuse between the alternator and starter relay
Discussion in 'Electrical and Ignition' started by Barnes, Jun 10, 2018.
  1. Barnes
    Barnes Member
    5
    0
    Jul 23, 2016
    Colorado
    Local Time:
    10:10 AM
    I did the ammeter bypass on my 68 and currently have 6 gauge wire from the 60 amp alternator, to a 80 amp circuit breaker, then to the starter relay. My problem is the circuit breaker is tripping on hot days (I believe the breaker is faulty, tested with another alternator). I would like to try another way of fusing the charge wire and would like to know your ideas. Fuseable link, another brand circuit breaker, mega fuse, none?
    Thanks!
  2. 67Dart273
    67Dart273 Well-Known Member
    38,310
    5898
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    9:10 AM
    1...How large is the alternator (output rating?)
    2...WHERE is the breaker mounted? Engine heat will de-rate the trip amperage
  3. Barnes
    Barnes Member
    5
    0
    Jul 23, 2016
    Colorado
    Local Time:
    10:10 AM
    The alternator is a 60 amp square back and the breaker is mounted next to the battery, in the engine bay.
  4. 512Stroker
    512Stroker We are all here because we are not all there.
    310
    84
    May 30, 2016
    Freedom, MO
    Local Time:
    11:10 AM
    I have a 60 amp alternator and a 70 amp CB mounted next to the battery, has never tripped.
    Even with the factory A/C on.
  5. Barnes
    Barnes Member
    5
    0
    Jul 23, 2016
    Colorado
    Local Time:
    10:10 AM
    What brand CB are you running?
  6. 512Stroker
    310
    84
    May 30, 2016
    Freedom, MO
    Local Time:
    11:10 AM
    Dont let the name foul ya, got it at Oreily's
    Littlefuse 0185070.X Type lll 70A
    • Like Like x 2
    • Barnes
      Barnes Member
      5
      0
      Jul 23, 2016
      Colorado
      Local Time:
      10:10 AM
      Awesome, thank you.
    • 67Dart273
      38,310
      5898
      Oct 14, 2010
      Idaho
      View My Photos
      Local Time:
      9:10 AM
      It IS possible you have a weak / faulty breaker.
    • swifty
      swifty Well-Known Member
      261
      78
      Feb 27, 2013
      Bismarck, ND
      Local Time:
      11:10 AM
      Make sure connections are tight and clean. Look for signs of heat from high current. A bad crimp or connection can draw a lot of current.
    • billccm
      billccm Well-Known Member
      78
      46
      May 13, 2018
      Tucson
      Local Time:
      10:10 AM
    • Barnes
      Barnes Member
      5
      0
      Jul 23, 2016
      Colorado
      Local Time:
      10:10 AM
      Update: I have been using the breaker 512Stoker recommended. So far so good. Has not tripped once. I must have had a bad/cheap breaker. Thanks again for the help.
    • 512Stroker
      310
      84
      May 30, 2016
      Freedom, MO
      Local Time:
      11:10 AM
      Every once in awhile a blind Hog finds an acorn. LOL
      Glad it work out for ya
    • rednesss
      rednesss FABO Gold Member FABO Gold Member
      1,413
      114
      Mar 4, 2006
      Eugene, OR
      Local Time:
      9:10 AM
      Why run a breaker at all?? The fusible link was to protect all the wiring under the dash, bypass that, and there's really no need on the run from the alternator to battery post/starter sol. Just make sure and size the wire right.
    • 67Dart273
      38,310
      5898
      Oct 14, 2010
      Idaho
      View My Photos
      Local Time:
      9:10 AM
      "I have news".............a story from the old days
      "Back in the day", not long after buying my 440-6 RR from a friend (who I saw last summer) some girls were "window shopping" in National City S of San Diego and REALLY A-holed it. Not knowing better, McCune Chrysler Plymouth got it "to fix" and I got a junk loaner car, Valiant /6 with bald tires and rock hard heater hoses. One of them broke, later.................
      ANYWAY my Chief PO came in one morning and it was "cool" out. I had fired up the thing about 5 min. earlier and was in the shop, getting "off duty." He gave me the "Columbo" bit and says "is that supposed to be screeching and smoking?
      SO I went out and shut it off, THE ALTERNATOR WAS NOT ROTATING. I took a rag and wrench and investigated, when I moved the pulley, THE DIODE THAT HAD FALLEN DOWN INSIDE SHORTED
      I got to sit there and watch THE ENTIRE ENGINE HARNESS go pppppsppsppsssssshhhhhssssppphhhhtttttt...........ssssssssss........ttt!!!
      AND THEN THE FUSE LINK BLEW
      So it shorted and melted the underhood harness into a huge stinking mess AND THEN popped the fuse!!!
      Called the dealer and told them to send a tow truck and a different loaner car. They sent the wetback with the booster cables instead. I went out and he looked at me and said "YOU NEED A TOW TRUCK!!!"
      This old photo is from either '73 or 74
