What’s with all these washers?
Slant 6 Engines
  1. Troub
    Troub 67 Dart 270, 225 slant six
    347
    67
    Jul 25, 2018
    Florida
    Local Time:
    9:13 PM
    A shot of the pully in front of the damper from a few months ago after pulling the engine....(pic)
    Currently back from a rebuild and I’m putting pieces back on her. There’s no way all the washers on that bolt are a good thing. Why would someone do that and how do I correct? As simple as a longer bolt?
  2. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    15,425
    4711
    Dec 7, 2006
    PLANT CITY FL. and PERRY GA.
    Local Time:
    10:13 PM
    What washers?
    • Agree Agree x 1
    • Troub
      347
      67
      Jul 25, 2018
      Florida
      Local Time:
      9:13 PM
      The washers on the bolt on the front pully. The second pic shows them better. There are 4 or 5 behind the bolt.
    • SGBARRACUDA
      15,425
      4711
      Dec 7, 2006
      Local Time:
      10:13 PM
      Crank bolt is obviously to long. Find a shorter one or shorten that one.
      • Agree Agree x 2
      • pishta
        pishta I know I'm right....
        15,918
        5662
        Oct 13, 2004
        Tustin, CA
        Local Time:
        7:13 PM
        F it, just pull it and dont use a bolt. Many never got them.....
        • Like Like x 1
        • TrailBeast
          TrailBeast Slightly Twisted Member
          20,427
          7339
          Mar 11, 2011
          Arizona
          Local Time:
          8:13 PM
          Betcha they had to use a longer bolt for that extra pulley on there.
        • zkx14
          zkx14 Duster De-ruster FABO Gold Member
          22,339
          15392
          Dec 23, 2012
          South Central PA
          Local Time:
          10:13 PM
          Probably used that bolt and washers to put it back on. Start with one washer. Crank it down. Add more, tighten more. Etc, till its all the way on and left them all there.
        • RustyRatRod
          RustyRatRod 30 Degrees Outta Whack FABO Gold Member
          57,326
          26760
          Jun 7, 2010
          Georgia
          Local Time:
          10:13 PM
          None of them ever got them I don't believe. Someone probably put it there thinking it needed one. Lets find out. @slantsixdan will hook us up on the truth. How bout it Dan, did any slant ever come with a harmonic balancer bolt that you know of? I've never seen one.
        • Troub
          347
          67
          Jul 25, 2018
          Florida
          Local Time:
          9:13 PM
          Thanks for the replies. Would def like to know Slantsixdans thoughts on it as well. Timing cover and water pump back on today. Can't believe I forgot to paint the front of the block. Not like I wasn't staring right at it or anything! Pics...
        • slantsixdan
          slantsixdan =..=
          6,398
          1491
          Jan 7, 2007
          Vancouver BC
          Local Time:
          7:13 PM
          Some early-production 1960-model Slant-6s came with a bolt, but it was eliminated soon after SOP (with no other related changes) because it is not at all necessary. The vibration damper is an interference fit (press fit) on the crankshaft; it won't be any more secure with a bolt or less secure without one. Sometimes it's convenient to have a bolt there for easy hand-rotation of the engine, but other than that, no reason to have it.
          • Like Like x 1
          • Thanks! Thanks! x 1
          • RustyRatRod
            57,326
            26760
            Jun 7, 2010
            Georgia
            Local Time:
            10:13 PM
            Looks good. If it was mine, I'd run the balancer bolt since you have it. I just got one for mine yesterday at the hardware store. Grade 8 3/4 fine thread x 2" for 3.49. All over ebay as "balancer bolt" for 19.99 and up. lol
            • RustyRatRod
              57,326
              26760
              Jun 7, 2010
              Georgia
              Local Time:
              10:13 PM
              Thank you sir!
            • Troub
              347
              67
              Jul 25, 2018
              Florida
              Local Time:
              9:13 PM
              Thanks Dan!
            • Troub
              347
              67
              Jul 25, 2018
              Florida
              Local Time:
              9:13 PM
              Ahhh The wonderful world of eBay!
            • Troub
              347
              67
              Jul 25, 2018
              Florida
              Local Time:
              9:13 PM
              Another question.....the hose connection at the base of the thermostat housing area is threaded. Is that actually removable or would it have done the old metal meld thing after all these years? Anyone ever thread one out?
              My top connection looks like hell as well.
            • RustyRatRod
              57,326
              26760
              Jun 7, 2010
              Georgia
              Local Time:
              10:13 PM
              Yup they are threaded. Soak them down good with Sea Foam Deep Creep for a few days then try to get them out. They do look like hell.
              • Agree Agree x 1
              • my68barracuda
                my68barracuda Well-Known Member
                975
                627
                Dec 6, 2009
                Indianapolis IN
                Local Time:
                10:13 PM
                Agree, the heater hose nipples are threaded. Soak them inside and out with penetrating oil for days, and with persuasion they will thread out. Usually it takes a small pipe wrench and you will crush them during the removal process. Dorman has replacements.
                • krazykuda
                  krazykuda Well-Known Member FABO Gold Member How-To Section Editor
                  50,195
                  15001
                  Aug 20, 2007
                  Orland Park, IL
                  Local Time:
                  9:13 PM
                  Have you tried to heat the head where it screws in with propane torch??? Heat is good for loosening stuck threads... If the propane torch can't heat it enough, try acetylene torch, just be careful not to get it too hot and melt anything... Heat the metal around the base of the nipple to be orange, then put some vise grips on it and crank it out... Keep in mind that you want to heat the hole, not the nipple... If you heat the nipple, it will expand and be tighter, focus the heat around the hole when heating it up to loosen it... The theory is to make the threaded part smaller and the hole bigger to loosen it... If you can hit the inside of the nipple with some penetrating oil to cool the nipple down after heating the hole, that will also help loosen it up... Open the hole and shrink the plug is the theory for success here...
                  As far as a replacement nipple, I like the ones with a hex drive... You can order them from Grainger.... This one has the correct 3/8" pipe thread with a 3/4" hex to drive it in with a 3/4" deep well socket or open end wrench... I like this nipple as you will not have to use any bushings to adapt it...
                  GRAINGER APPROVED Brass Beaded Hose Barb with Straight Fitting Style, 3/8" Thread Size - 6AFH7|6AFH7 - Grainger
                  The original ones had slots at the top of the nipple to drive it in... PIA for us home mechanics... Hex drive is much easier...
                  • Tooljunkie
                    Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
                    11,962
                    10490
                    Jul 22, 2017
                    Manitoba
                    Local Time:
                    9:13 PM
                    I have used a hacksaw blade inside the pipe fitting to cut a slot to the threads. Have to watch as you go and quit when the points of the threads show.
                    Two cuts and out it comes.
                    A pipe tap to touch up the threads and you are good to go.
                    • petty437
                      petty437 FABO Gold Member FABO Gold Member
                      122
                      57
                      Feb 5, 2014
                      Kent, Ohio
                      Local Time:
                      10:13 PM
                      I was able to get mine out soaking it with PB Blaster for a couple days & a little heat from a torch. Came right out. Layson's has replacements.
                    • Jadaharabi
                      Jadaharabi FABO Gold Member FABO Gold Member
                      6,504
                      6750
                      Jan 8, 2016
                      Peoria, Illinois
                      Local Time:
                      9:13 PM
                      • SGBARRACUDA
                        15,425
                        4711
                        Dec 7, 2006
                        Local Time:
                        10:13 PM
                        Thought I would mention a trick taught to me years ago. When you put vise grips on a fitting, they usually crush before coming out. Drop the largest diameter bolt down the inside of the fitting before you clamp down on it. Works pretty good on getting then to break loose.
                        • Like Like x 4
                        • 69a100
                          69a100 Well-Known Member
                          97
                          43
                          Jun 29, 2009
                          Local Time:
                          7:13 PM
                          I didn't have a crank bolt on mine, I installed one anyway not knowing the difference at the time. I will say that it helps a lot to have one when it's time to adjust the valves!
