what bolt lube to use
Lubed.
Heck, ARP even includes lube in their head & main bolt kits just to make sure you do it.
Always a good idea to chase & clean the block threads too before installation.
And not just on the threads, put a couple drops under the bolt head to prevent binding and give a more consistent torque reading.
What does the factory service manual say?
Mymopar.com
Free download
I just looked 67 Dodge FSM and the FSM does not say anything about lub on the bolt threads.
Note the torque on a dry bolt vs a lubed bolt are typically different.
The same torque on a lubed bolt might stretch the bolt more than the same torque on a dry bolt. Meteorology of the bolt will be the deciding factor and what the bolt manufacturer says.
Just my 2 cents
Mymopar.com
Free download
I just looked and the FSM does not say anything about lub on the bolt threads.
Just my 2 cents
Exactly. You can't use a dry torque number on a lubed fastener as it will end up being overstretched.
I have rebuilt quite a few engines over the years. I have never lubed the bolts, and none of my engines have ever failed.
rod bolts main cap bolts head bolts. clean/dry or use lube?
I would do them wet with ARP lube. You'll just have to look on there website to get the fastener torque specs based on using there lube.
ARP is always giving those lube packets away at the trade shows and I always come home with some.
If you need a couple packets send me a PM and I'll send you some.
Tom
Machine shop
ARP? use ARP lube
Stock bolts in a blind hole? a drop of 50 weight oil under the bolt head and on the threads
Stock bolts in a open hole leading to water jacket ? Sealer on the threads and a drop of 50 weight oil under the bolt head.
Machine shop
ARP? use ARP lube
This is the best response, and 100% correct
I think having clean threads is most important, sometimes I remember to brush on some engine oil sometimes not.
I've never noticed any difference installing dry.
I always use the ARP lube on everything since there is plenty in the package, when running their bolts.
Stock just gets a drop out of the fresh oil can and cheap Dollar General brushes off the excess.
Standard bolts, motor oil dip then wiped off before install, thats wiped , not cleaned.
Arp chrome moly bolts/studs, the lube they supply, or the same procedure as above, but with store-bought moly grease.
Mymopar.com
Free download
Just my 2 cents
Shoot, I want to check my 1970 Plymouth FSM now, I could've sworn it called for motor oil on threads for main and rod cap bolts. I'd check your link but I'm on my phone, don't want to deal with downloading and unzipping a large file.
The '66 factory service manual doesn't mention oiling any of the head or bearing cap bolts.
My 2 cents,
I always change rod bolts to DC, or ARP.
And I always use ARP lube, they pull down so nice.
And then I sleep at night, or when I destroy my transmission and bounce off the rev limiter.
