What clutch for a 440?
Big Block A body Tech
  1. paulclark
    paulclark Early A fanatic FABO Gold Member
    314
    97
    Apr 9, 2015
    Seattle
    Local Time:
    4:57 AM
    I'm installing a 440 in my 67 Barracuda. Do I need an 11" clutch or is the 10 1/2" adequate for street use?
    Will be a 440 w/mild street cam, HP manifolds, 3.23 gears. Street use, unlikely it will ever see the strip.
    Thanks -
  2. Dartnut
    Dartnut Don't hate me because i'm beautiful
    11,752
    4814
    Apr 19, 2007
    Southern Alberta
    Local Time:
    5:57 AM
    A 10 1/2'' would work fine for your combo and intended use.
    Just make sure you get a good name brand assembly like McLeod.
    • Agree Agree x 1
    • Daves69
      Daves69 Well-Known Member
      6,042
      4575
      Feb 20, 2011
      WestOfChi
      Local Time:
      6:57 AM
      A 10-1/2" or 10.95" (scalloped) and the 130 tooth fly wheel has been fine for 50+ years.
      A real 11" and 143 tooth flywheel works also.
      Which bellhousing are you planning on using?
    • dano
      dano Evil Handy Man
      4,073
      1913
      Aug 22, 2005
      Gresham, Oregon
      Local Time:
      4:57 AM
      Bell and Flywheel need to match. Not sure if the 11" was used in A-bodies?
      Another vote for McLeod.
    • paulclark
      314
      97
      Apr 9, 2015
      Seattle
      Local Time:
      4:57 AM
      Awesome good information I appreciate it.
    • paulclark
      314
      97
      Apr 9, 2015
      Seattle
      Local Time:
      4:57 AM
      That was why I was asking first, to figure out which bell to use.
    • dano
      dano Evil Handy Man
      4,073
      1913
      Aug 22, 2005
      Gresham, Oregon
      Local Time:
      4:57 AM
    • Daves69
      6,042
      4575
      Feb 20, 2011
      WestOfChi
      Local Time:
      6:57 AM
      A Lakewood will handle either flywheel, 143 tooth or 130.
      A stock cast iron or aluminum will take which ever size they are designed for.
      There is a chart here that may help.................
      Mopar Transmission Tech | www.darkside.ca
      • Agree Agree x 1
      • RustyRatRod
        RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
        79,466
        57904
        Jun 7, 2010
        Georgia
        Local Time:
        7:57 AM
        Use the scalloped 10.95". That's a nice trick for the 10.5" flywheel.
      • 67Dart273
        67Dart273 FABO Gold Member FABO Gold Member
        51,498
        20462
        Oct 14, 2010
        Idaho
        Local Time:
        4:57 AM
        I'm not sure I agree. My 70 440-6 RR came with scallop pp and I had trouble with it. It never "really" released "clean" and I'm convinced disk material feathering off the outer edge of the disk would drag on the mounting tabs of the pp
      • Daves69
        6,042
        4575
        Feb 20, 2011
        WestOfChi
        Local Time:
        6:57 AM
      • RustyRatRod
        79,466
        57904
        Jun 7, 2010
        Georgia
        Local Time:
        7:57 AM
        Clutches have come a long way since the Jurassic age. lol
        • Agree Agree x 2
        • Dcuda69
          Dcuda69 Well-Known Member
          216
          43
          Jul 14, 2008
          Local Time:
          6:57 AM
          I use a 10.5" Centerforce Dual Friction behind a 470" low deck stroker in my street 69 B'cuda. Works fine.
