What color is my 1970 duster
Mopar Body and Trim
  1. Toqwik
    Toqwik Well-Known Member
    66
    25
    Nov 1, 2019
    Florida
    Local Time:
    9:45 AM
    My car has one crappy repaint but it matches the original well. I think it is b5 but want other opinion. Does anyone sell this in a rattle can so I can do some touch up? Thanks! image.jpg
  2. 1969383S
    1969383S FABO Gold Member FABO Gold Member
    5,634
    2654
    Jan 8, 2012
    Cumming, GA.
    Local Time:
    9:45 AM
    Looks B5 is the fender tag there?
  3. MileHighDart
    MileHighDart Well-Known Member
    4,218
    3702
    Jun 3, 2004
    Lyons, CO
    Local Time:
    2:45 PM
    Yep, I'd say B5 for sure. My interior is B5.
    If you have an automotive paint supply store anywhere near you, they can mix up some and put it in spray cans for you.
    That's how I redid my interior.
    Place I use to get mine had a two can minimum.
  4. Princess Valiant
    Princess Valiant Duster specialist FABO Gold Member
    22,215
    13886
    Dec 14, 2011
    Colorado
    Local Time:
    7:45 AM
    It's the color "pretty" because regardless of the paint code, that color looks pretty good :D
    • Agree Agree x 1
    • 72bluNblu
      72bluNblu FABO Gold Member FABO Gold Member
      10,846
      5274
      Nov 28, 2008
      NorCal
      Local Time:
      6:45 AM
      And regardless of the paint code, that color will be VERY hard to match. B5 has metal flake in it, and I agree that looks like it could be B5. Although B5 also looks very different depending on the light it's in, partly because of the flake. Also partly because there was more than one formulation for B5, it was different in different model years.
      Anyway, touching up any large sections will be very difficult. Even sprayed out of the same bucket colors like B5 can look different if they're sprayed at different temperatures or air pressure settings, because it changes how the flake is distributed. You can't even hang a run and sand it out, the metal flake leaves a "ghost" run in the paint even once it's been sanded flat.
      I do not envy anyone given the task of matching that paint.
      • Agree Agree x 3
      • a12
        a12 Well-Known Member
        196
        162
        Nov 19, 2014
        maryland
        Local Time:
        8:45 AM
        I'm thinkin B2
      • Oldmanmopar
        Oldmanmopar Going left turning right FABO Gold Member
        8,402
        4566
        Jan 8, 2009
        Danielsville Pa. 18038
        Local Time:
        9:45 AM
        69 and 70 is a different B5 then 71 and newer. I had a 69 dart and a 71 Denon at the same time in the early 80's the 69 was lighter and seamed the same color as your car. The 71 was a darker color.
      • YY1
        YY1 Well-Known Member
        6,790
        2579
        Oct 11, 2011
        FL
        Local Time:
        9:45 AM
        EB5- 1969
        GB5- 1971
        KB5- 1974
        Take it to the paint store and have them photo match it.
        I've had 100% success with hard to match YY1 and JY3.
        • Like Like x 1
        • Agree Agree x 1
        • A56
          A56 MoParAffliction FABO Gold Member
          1,204
          1136
          Jun 24, 2014
          White Oak, N.C.
          Local Time:
          7:45 AM
          Don't know about the other colors on that chart but the B7 for 1971 is nowhere near the B7 of 1969.
        • Craig Burriss
          Craig Burriss Well-Known Member
          298
          192
          Aug 30, 2017
          Statesboro Georgia
          Local Time:
          9:45 AM
          Looks a lot like my car that has been resprayed, I’m pretty sure it’s B5
          • Like Like x 1
          • Toqwik
            66
            25
            Nov 1, 2019
            Florida
            Local Time:
            9:45 AM
            I see yours is an early 70 with the v eight emblems on the fender. Mines is as well.
            • Agree Agree x 1
            • Thomas Dennis
              Thomas Dennis Well-Known Member
              170
              88
              Oct 31, 2019
              Hudson FL
              Local Time:
              9:45 AM
