What EDM lifters do you like?
Small Block Mopar Engine
  1. midnight340
    midnight340 Well-Known Member
    140
    32
    Mar 19, 2014
    Lawrence, KS
    Local Time:
    8:03 AM
    I decided to start a new thread since the old one had to do with cam and compression questions on my 340.
    I ordered the Lunati 740 "baby Voodoo Solid" which will be way more lift than I've had before and should be fun for sure. Also a set of Lunati beehive springs. My Mopar machinist gave my valve guides a thumbs up which is financially a bit relief!! Picked up new seals, and have the valves cleaned up, working on the heads.
    I am looking at the Howards EDM liftersI do want to ask if you guys have rec
  2. mderoy340
    mderoy340 Well-Known Member
    2,013
    727
    Aug 2, 2012
    Melbourne FL
    Local Time:
    9:03 AM
    I'm running howards EDMs and like them.
    • Like Like x 2
    • brian6pac
      brian6pac Well-Known Member
      3,462
      1971
      Nov 15, 2016
      N.E.Ohio
      Local Time:
      9:03 AM
      I have used crower cool face mechanical lifters and they worked fine, no problems.
      • Like Like x 1
      • Krooser
        Krooser Reform School Graduate
        996
        659
        Jul 19, 2015
        Land of Cheese
        Local Time:
        8:03 AM
        Only two or three making flat tappet lifters... Likely Howard's come from Hylift-Johnson which is good.
        • Like Like x 1
        • midnight340
          140
          32
          Mar 19, 2014
          Lawrence, KS
          Local Time:
          8:03 AM
          Maybe it's overkill, but insurance it seems. Should extend the life of the life of the cam I'd think.
          • Like Like x 1
          • mderoy340
            2,013
            727
            Aug 2, 2012
            Melbourne FL
            Local Time:
            9:03 AM
            Agree. I bought the Howards since they were the lower cost.
            • Like Like x 1
            • pittsburghracer
              pittsburghracer Well-Known Member
              926
              1515
              Apr 20, 2016
              Freeport, PA.
              Local Time:
              9:03 AM
              I’m thinking I got mine from Hugh’s and all is good after 3 years with a .650 lift cam. Coming apart for rebuild soon. Ran 5.98@113mph on its last pass in the 1/8.
            • krazykuda
              krazykuda FABO Gold Member FABO Gold Member
              46,859
              11859
              Aug 20, 2007
              Orland Park, IL
              Local Time:
              8:03 AM
            • Krooser
              996
              659
              Jul 19, 2015
              Land of Cheese
              Local Time:
              8:03 AM
              Since I already have ft solids and don't expect to win the lottery my SBM is getting old fashioned lifters sans edm holes...I ain't skeered.
              • Like Like x 2
              • Agree Agree x 1
              • 70aarcuda
                70aarcuda Master Hoader of SBM FABO Gold Member
                14,134
                2192
                Jan 16, 2005
                las vegas
                Local Time:
                6:03 AM
                Howards
              • Kern Dog
                Kern Dog Well-Known Member
                2,671
                2233
                May 23, 2010
                Granite bay CA
                Local Time:
                6:03 AM
                Same here. I'm on my second cam, second set of the Howard's.
                • Like Like x 2
                • RustyRatRod
                  RustyRatRod 30 Degrees Outta Whack FABO Gold Member
                  49,145
                  15332
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  9:03 AM
                  I chose the Crower for my Ford 400 build. Plan to put it in the truck this summer.
                • dogbreath
                  dogbreath Well-Known Member
                  229
                  43
                  Nov 29, 2009
                  Local Time:
                  8:03 AM
                  Howards
                • Krooser
                  996
                  659
                  Jul 19, 2015
                  Land of Cheese
                  Local Time:
                  8:03 AM
                  I think my solids are from Crower... not sure who made them. No oil band.
                  No EDM back in '93 when this was originally built. I've never flattened a cam during break-in always run a break in spring or just run one spring then break in the cam and reinstall the inners and damper if so equipped. Most stock spec cams have soft springs so breakin is pretty easy.
                  But you guys already know that.
                • midnight340
                  140
                  32
                  Mar 19, 2014
                  Lawrence, KS
                  Local Time:
                  8:03 AM
                  I’m pretty sure with proper break-in that regular solids would be fine, but the EDMs can’t hurt, so will probably go with them. (Howard’s)
                  Thanks for the responses!!
                  • Agree Agree x 1
                  • Kern Dog
                    2,671
                    2233
                    May 23, 2010
                    Granite bay CA
                    Local Time:
                    6:03 AM
                    I wonder about that tiny oil hole. I may be over-thinking it but you'd probably want to keep the oil thinner and cleaner to keep from blocking that passage.
                  • midnight340
                    140
                    32
                    Mar 19, 2014
                    Lawrence, KS
                    Local Time:
                    8:03 AM
                    Thanks all! Ordered some Howard’s EDMs today. The new Lunati cam and a set of beehive springs arrived today also. A set of Mr Gasket .028 head gaskets and some Felpro timing cover,intake gaskets on the way as well.
                    Getting past some worry over which parts to order, and on to the fun part!!!
                    I’m slow but will get it back together. Cleaning ports with wire brush on a Dremel and may lap the valves a bit before assembly.
                    • Like Like x 1
                    • Wyrmrider
                      Wyrmrider Well-Known Member
                      1,139
                      410
                      Sep 5, 2016
                      los angeles
                      Local Time:
                      6:03 AM
                      Krooser
                      your motors never get to idle so you always get plenty of splash
                      two thumbs up on the solid -no dumbell - lifters
                      If I WAS ON THE STREET i'D GO edm
                      • Like Like x 1
                      • jos51700
                        jos51700 Well-Known Member
                        4,514
                        1244
                        May 24, 2009
                        Bel-Ray
                        Local Time:
                        8:03 AM
                        My EDM's have a little wheel on the bottom. It's cool because the cam profile can be get much bigger for the same specs.
                        • Like Like x 1
                        • Krooser
                          996
                          659
                          Jul 19, 2015
                          Land of Cheese
                          Local Time:
                          8:03 AM
                          That's the common thought on that BUT I read a few months ago of how a very reputable dirt modified engine builder sez he really sees very little performance differences between a flat tappet vs. roller in his engine builds.
                          I was surprised, too.
                          This guy builds $30,000 SBC motors.
                        • jos51700
                          4,514
                          1244
                          May 24, 2009
                          Bel-Ray
                          Local Time:
                          8:03 AM
                          Did he say it was a negative difference? Are you building dirt track race engines?
                          These are questions one has to ask before making a decision.
                        • B3422w5
                          B3422w5 Well-Known Member
                          645
                          454
                          Feb 9, 2017
                          Portage michigan
                          Local Time:
                          9:03 AM
                          Me too love them
                        • Wyrmrider
                          1,139
                          410
                          Sep 5, 2016
                          los angeles
                          Local Time:
                          6:03 AM
                          a small wheel/ small base circle roller cannot match a FT- physically impossible
                          Flat flank on the roller and all that
                          now one of Mike Jones Inverse radius profiles...
                        • Krooser
                          996
                          659
                          Jul 19, 2015
                          Land of Cheese
                          Local Time:
                          8:03 AM
                          Wish I could find the article...
                          Simply put he said he found little to no difference in power between the two.
                          Usable? Dyno? Don't know the answer.
                          Dirt track stuff is what I do... Only for myself using trusted machine shops.
                          • Like Like x 1
                          • furrystump
                            furrystump Well-Known Member
                            621
                            345
                            Nov 13, 2004
                            Local Time:
                            2:03 PM
                            I was concerned about the holes getting plugged, but have had them for 7 years. Have had them out of the motor about 3-4 times since. Check each one and they were clear. I don’t remember who made them, but I would go EDM again in the future.
                            • Thanks! Thanks! x 1
