RandyB
I’m going to be getting the Edelbrock 1404 carburetor and want to make sure I purchase the right connections for the fuel line. Unlike the Holley 2300 Which I had a lot of trouble getting one to fit.
I don’t have to worry about the A/C, don’t have it!i bought these. had to modify bend the line to work with A/C but it turned out OK
1967-72 Dodge A-body 340CID 4bbl Carter AVS 5/16
Carter AFB AVS TQ 5/8-20 Brass Fuel Inlet Fitting 5/16" Inverted Flare | eBay
So, the 1158 mates up to fuel line intake of the 1404, correct?the fitting the 1404 comes with is for just pushing a rubber fuel line on it. kinda like this. i didnt want the sloppy look
Edelbrock Carburetor Inlet Fittings 1158
Awesome, thank you for clearing that up for me.the 1158 does not fit. that link is just to show the style fitting an edelbrock 1404 will come with if you bought it new. the female tapped fuel inlet is 5/8-20 on the carb though. you can put any style on there you want as long as your fitting has 5/8-20 male threads on it
That’s what I needed to know, thank you muchyeah you can go 3/8, 5/16, an fitting, inverted flare etc... whatever floats your boat on connecting your fuel line to the carb. but the fitting on the carb side is 5/8-20
Yup, found that out the hard wayi broke out a set of calipers and a thread pitch gage then started searching the web for what i wanted. a lot of companys dont get into specifics like that on their weak descriptions sometimes.
