What gear ratio for a street car w/occasional track use?
Transmission and Drivetrain Tech
What Gear Ratio for Street with 3-4 time a year track use?
  1. 3.55- Keep what you have
    44.3%
  2. 3.73
    20.0%
  3. 3.91
    18.6%
  4. 4.10
    17.1%
  1. 68Dart500
    68Dart500 Well-Known Member
    360
    235
    Oct 24, 2017
    USA
    Local Time:
    7:50 AM
    I've decided that I think I want to swap out my 3.55 gears in my 68 Dart 408 stroker. It's a 4 speed manual with the 2.44 (I believe that's what it was?) 1st gear. After this last tuning session its making roughly 500 hp and 540 ft/lbs torque. I'm running a 28x12.5-15 Bias ply wrinkle wall tire.
    I'm just not as happy with the 3.55's as I thought I would be. Thinking I should have gone 3.73 or 3.91's.
    It will spend 95% of its time on the street with spirited stoplight to stoplight driving and some highway to get to shows within a half hour or so. Probably 3-4 times a summer I'll take it to the track. Am I crazy wanting to change the gearing being its not a track car?
    Currently it cruises at about 3000 rpm at 70.
  2. Mopar Tim
    Mopar Tim FABO Gold Member FABO Gold Member
    18,521
    11116
    Nov 29, 2014
    vista CA.
    Local Time:
    5:50 AM
    I swapped the gears in my 408 Dart to 3:23 from 3:55. It is not as quick out of the hole, but a 408 has tons of torque, so it recover quickly and is lots more fun to drive on the freeways of So Cal.
    • Like Like x 2
    • Agree Agree x 2
    • 451Cuda
      451Cuda Well-Known Member
      1,912
      694
      Nov 19, 2008
      Port-aux-Français, TF
      Local Time:
      7:50 AM
      I like 3.91 for a street/strip 440, probably the same results for your 408.
      • Like Like x 1
      • mbaird
        mbaird mbaird FABO Gold Member
        5,784
        2718
        Dec 10, 2005
        boise, Id
        Local Time:
        6:50 AM
        since you mentioned the rpms at 70 I have to assume you have occasion to use it on the highway. You might grow tired of the 3.91s in short order. 3.55s are a sweet gear for Torque monster motors.
        • Like Like x 2
        • Agree Agree x 2
        • mderoy340
          mderoy340 Well-Known Member
          2,203
          958
          Aug 2, 2012
          Melbourne FL
          Local Time:
          8:50 AM
          You have the data of highway rpm now, what can you live with? Go drive the highway in 3rd gear and do math to calc current final drive with the 3.55. More gear will drop et if your car hooks. I run a 3.91 but got lucky and picked up a used GVOD. Driving 50 miles to the track gets old and the GV knocked off 400 rpm at cruise.
          Are you disappointed in track performance? More to good et than horsepower. Post up your combo, more ways to get a car quicker than just gears. Do you have a baseline time slip you can post.
          • Like Like x 2
          • Alaskan_TA
            Alaskan_TA Well-Known Member
            5,349
            3553
            Nov 12, 2004
            PA
            Local Time:
            8:50 AM
            The center sections are easy to swap in & out, so buy a second set in your ratio of choice & install it for your race season.
            3.55s with 15" tires is optimal for street use to me.
            With lots of highway, I like a 3.23
            • Agree Agree x 7
            • 68Dart500
              360
              235
              Oct 24, 2017
              USA
              Local Time:
              7:50 AM
              You're right, the highway driving is good right now so maybe I just live with it. I could always get a 2nd set of rims/tires with some 26 or 27's for the track. Just run the 28's on the street.
              I am actually going to be racing (for fun) at the Mopar Nationals for the first time with this combo in 2 weeks so that I've got a baseline. Currently I'm running new XHD Mopar leaf springs, adjustable pinion snubber, springs moved into frame and mini tubbed with custom 15x10 steel dog dish rims with 28x12.5-15 Mickey Thompson Sportsman Pro Bias ply tires. 23 Spline 4 speed with a centerforce dual friction clutch. Chromoly driveshaft w/1350 joints. 489 case w/crush sleeve eliminator, 3.55 Yukon Gears, Auburn Pro LSD, Moser Axles. Subframe connectors and a full interior with all steel body. Also has a Quicktime bellhousing, steel stock flywheel, and driveshaft loop also so I'm sure its fairly heavy.
              Speaking of track performance. What RPM would people suggest launching at with that combo? Obviously this is a for fun car so I'm not looking to blow stuff up with a 6k rpm launch. On the street it seems to spin minimally if I only rev to 3k rpm. But 3500 or 4k it will spin for 20-30 feet. I realize the track will be much stickier so I'm just trying to not have it bog but also not break stuff.
            • mderoy340
              2,203
              958
              Aug 2, 2012
              Melbourne FL
              Local Time:
              8:50 AM
              IMO this is the way to go. 26" Launch rpm is test at several rpms. Get up and stage the car and don't worry about RT. Make sure you are at 1500, 2000, etc and see what is best.
              • Agree Agree x 1
              • MOPAROFFICIAL
                MOPAROFFICIAL Well-Known Member
                4,981
                3965
                Jun 1, 2016
                Beach
                Local Time:
                5:50 AM
                For me...3.55 gears just don't have it for the strip... And 391 gears ,though still mild, are too much for the highway for most people.
                Imo 3.73's are it when it comes to a REAL dual purpose car with a 1+1 final drive.
                I ran a 340 with 3.23, 3.55, 3.91, 3.73 and out of all of them the 3.73 was the most versatile gear. 3.91 hauled ass 3.55 was slouchy in the midrange and low. 3.23 was a dog...till you got to 70 mph.
                Doesnt seem like much diff between the 3.55 & 3.73... but there is.
                • Like Like x 4
                • Agree Agree x 2
                • yellow rose
                  yellow rose Doctor of Thinkology.
                  20,377
                  16460
                  Jun 19, 2015
                  Living on the razors edge
                  Local Time:
                  5:50 AM
                  You didn't have an option for 4.56 gears.
                  That's what I'd use.
                  • Like Like x 1
                  • Agree Agree x 1
                  • mbaird
                    5,784
                    2718
                    Dec 10, 2005
                    boise, Id
                    Local Time:
                    6:50 AM
                    Well hell... you have enough in driveline components to support a wheelstander !
                    launch it at 6k...lol
                    But really your rpms will be dictated by your engine build / gears and chassis setup.
                  • Alaskan_TA
                    5,349
                    3553
                    Nov 12, 2004
                    PA
                    Local Time:
                    8:50 AM
                    Just as high as you are willing to go that will still allow the rear tires to hook. ;-)
                    • Agree Agree x 1
                    • sireland67
                      sireland67 Well-Known Member
                      8,799
                      2960
                      Oct 27, 2010
                      WV
                      Local Time:
                      8:50 AM
                      Stock flywheel, I would not trust that.
                      I would spend money on a quality SFI one before gears.
                    • mbaird
                      5,784
                      2718
                      Dec 10, 2005
                      boise, Id
                      Local Time:
                      6:50 AM
                      That occured to me as well ...
                      I am using a 20 lb Mcleod SFI flywheel for my stroker... a little less weight (10 lbs) for quick revving and peace of mind for around 299.00
                      with all the trick driveline stuff you have it seems ashame to run a factory iron unit.
                      • Agree Agree x 1
                      • abodyjoe
                        abodyjoe Well-Known Member
                        20,342
                        5254
                        May 22, 2004
                        Berlin,N.J. 08009
                        Local Time:
                        8:50 AM
                        Shit 95% street I’d go to a 3.23. :)
                        • Agree Agree x 4
                        • Abodybomber
                          Abodybomber Breaking street machines , since 1983.....:) Legendary Member
                          31,707
                          10468
                          May 21, 2011
                          Arroyo grande ca
                          Local Time:
                          5:50 AM
                          Rear and front suspension setup?....
                          • Like Like x 1
                          • cpearce
                            cpearce Well-Known Member
                            774
                            329
                            Sep 1, 2010
                            Edson
                            Local Time:
                            7:50 AM
                            I run that one also and love it.
                          • mbaird
                            5,784
                            2718
                            Dec 10, 2005
                            boise, Id
                            Local Time:
                            6:50 AM
                            my car is still in build mode. how does that fly wheel feel on street ? quick revving but doesnt stall out from stoplights I hope ....
                          • 68Dart500
                            360
                            235
                            Oct 24, 2017
                            USA
                            Local Time:
                            7:50 AM
                            I went with the quicktime explosion proof bellhousing so I was protected from a clutch explosion too. If it's a good idea I'll get the flywheel too I guess. What causes a flywheel to blow typically?
                            I think I'll start off with a 2500 launch at the track. Then go up 500 rpm at a time.
                          • RustyRatRod
                            RustyRatRod Weenie idiot loser. FABO Gold Member
                            58,476
                            28864
                            Jun 7, 2010
                            Georgia
                            Local Time:
                            8:50 AM
                            Use a 27" tall tire (275 60 15) and a 4.30 gear. You'll never look back.
                            • Agree Agree x 2
                            • Like Like x 1
                            • fishmens67
                              fishmens67 Well-Known Member
                              7,016
                              4193
                              Nov 10, 2012
                              idaho
                              Local Time:
                              7:50 AM
                              Street? Strip? 4.10 a true grocery getter with a 26" tire. 4.56 if ya can get 28" under it.
                              My car hasn't seen the highway in decades. it's idling along or full 1/8 or 1/4 mile blasts.
                              I prefer our Taurus for all highway driving. comfy !
                            • 68383GTS
                              68383GTS Well-Known Member
                              7,358
                              848
                              Nov 15, 2007
                              East Peoria,IL
                              Local Time:
                              7:50 AM
                              I have a 489 410 with a locker that I would trade for a 355 suregrip or locker....
                            • mopardude318
                              mopardude318 Well-Known Member
                              9,659
                              808
                              Jan 7, 2005
                              Gilroy, Ca
                              Local Time:
                              5:50 AM
                              I'd say 3.73 gears!
                            • AJ/FormS
                              AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
                              17,550
                              5949
                              Jan 19, 2014
                              South-Central Manitoba,Canada, 900ftelevation
                              Local Time:
                              7:50 AM
                              With what 28" street tires? I want those!!
                              If I had a 408, and that's all it would do with a starter gear of 3.55x2.44= 8.66, on street tires, I'd be disappointed too.
                              That 2.44 only came in the Hemi-boX. If you have a 1x23 input then you have either a 2.66low, or the waaaay less common 2.47low, T/A box. There was a third box, in the first-gen Barracudas with a 3.09 low. You shouldn't be needing that one,lol.
                              The 2.66 box has a 9% better low gear and slightly wider ratios than the 2.47.. And the 3.09 box has a 16% better low gear than he 2.66, and the rest are the same. Here are the ratios;
                              2.47-1.77-1.34-1.00 and splits of .72-.76-.75 Close ratio 70 T/A
                              2.66-1.91-1.39-1.00 and splits of .72-.73-.72 Common
                              3.09-1.92-1.40-1.00 and splits of .62-.73-.71 1st-gen Barracuda deep-low
                              • Like Like x 1
                              • Thanks! Thanks! x 1
                              • yellow rose
                                20,377
                                16460
                                Jun 19, 2015
                                Local Time:
                                5:50 AM
                                I thought after 1970 all 4 speeds were the 2.47 low gear? My 72 Demon was a 2.47 low, interlocking lever side cover box.
