What Ignition Wire's are you using with your TTI headers?
Another question to ask is what valve covers are you using???
I like the 67 - 68 covers because they have a bracket for the individual wires to route through and help keep #5 & #7 wires from hitting each other and the exhaust...
Taylor Spiral Core wires with TTI Headers. I will be changing to Cal Custom covers, so I'll be interested what looms to use.
Msd. Red because they were new from a FE ford motor and friend gave them to me. Shortened them up and put new ends on them. You don’t need the little heat booties on 5 & 7 I just already had them on there when the car had hooker headers on it before (which got cut off with a Sawzall)
I use msd 8841 clips. Available pretty much everywhere
Y07_A66
Do you happen to know what part number these are?
Thanks
PLY478
I do not have the actual part number since as I have had these on this engine for many years. I was told that these were one of the original sets with the grey high temperature boots. FC also sold me a coil wire at the length that I needed when I moved my coil off the engine and over under the MC.
Contact Us - FireCore Performance
You may try emailing them and asking what their newest part number would be for your setup.
I did find a picture from 2016 new in the box, but not sure if the picture part number (PF1003) was correct or not.
