What is involved in replacing a 5.2 with a 5.9
Small Block Mopar Engine
  1. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    14,588
    4146
    Dec 7, 2006
    PLANT CITY FL.
    Local Time:
    3:56 AM
    I bought a few trucks recently and one is a 2000 1500 2WD with a knocking 5.2 Automatic.
    A friend of mine has a new 5.9 long block still wrapped up in plastic. So my question is, what needs to be done to make it work where a 5.2 was? Mainly with the electronics. Thanks for your help.
  2. MOPAROFFICIAL
    MOPAROFFICIAL Well-Known Member
    3,671
    2659
    Jun 1, 2016
    breakwater
    Local Time:
    12:56 AM
    Maybe the computer from a 5.9, flex plate/external balance convertor, damper, check on throttle body..but a few searches could clear up if any induction difference.
    • Like Like x 1
    • Thanks! Thanks! x 1
    • 67Dart273
      67Dart273 Well-Known Member
      39,803
      7421
      Oct 14, 2010
      Idaho
      Local Time:
      12:56 AM
      I bet you could do nothing except change the flex plate and it would fit and run just fine. "Might be" that the TB is larger bore, don't know for sure, and computer/ injectors different.
      • Agree Agree x 1
      • pishta
        pishta I know I'm right....
        14,894
        4533
        Oct 13, 2004
        Tustin, CA
        Local Time:
        12:56 AM
        Balance...TB and injectors are the same (part numbers)....Maybe ECU?
        • SGBARRACUDA
          14,588
          4146
          Dec 7, 2006
          PLANT CITY FL.
          Local Time:
          3:56 AM
          Thanks, I'm trying to decide weather I should find a 5.2 or if the 5.9 would be doable without to many headaches.
        • 67Dart273
          39,803
          7421
          Oct 14, 2010
          Idaho
          Local Time:
          12:56 AM
          ^^This is the big difference in the older LA and the Magnums, too bad the LA's weren't done this way. Magnums are balanced with weights on the flex plate, while LA was balanced with weights on the converter. Magnum converter bolt pattern is not indexed, either.
          • Thanks! Thanks! x 2
          • Disagree Disagree x 1
          • SGBARRACUDA
            14,588
            4146
            Dec 7, 2006
            PLANT CITY FL.
            Local Time:
            3:56 AM
            So I guess with the right 5.9 flex plate the original 5.2 converter will work?
            • Agree Agree x 2
            • Jadaharabi
              Jadaharabi FABO Gold Member FABO Gold Member
              5,445
              5273
              Jan 8, 2016
              Peoria, Illinois
              Local Time:
              2:56 AM
              The balance is not the same between a 5.2 and a 5.9.
              You need a 5.9 flex plate. I believe everything else swaps over.
              • Agree Agree x 1
              • Jadaharabi
                5,445
                5273
                Jan 8, 2016
                Peoria, Illinois
                Local Time:
                2:56 AM
                Also Chrysler changed the rear main cap to where a 5.9 oil pan fits on the 5.2. So no problem with the oil pan.
                • Agree Agree x 2
                • MOPAROFFICIAL
                  3,671
                  2659
                  Jun 1, 2016
                  breakwater
                  Local Time:
                  12:56 AM
                  Balancer/dampner is diff, internal vs external.
                  I get different part numbers on the magnum balancer between 5.2 and 5.9. Mine looks nothing like a neutral balancer from a 5.2
                  • Agree Agree x 1
                  • Bobzilla
                    Bobzilla Well-Known Member
                    545
                    360
                    Aug 10, 2017
                    Livonia, Michigan
                    Local Time:
                    3:56 AM
                    Converter should be the same, just need proper 5.9 Magnum flex plate and 5.9 Magnum harmonic balancer. There is two styles; a one piece with integral serpentine pulley, and the two piece that is separate balancer and serpentine pulley. Either setup will work on the same 5.9 Magnum long block, if it doesn't already have one.
                    Everything on the intake manifold works on either engine, so just make sure the plenum plate is sealed up and swap it over.
                    The ECM from either engine will run the other engine size as long as they were equipped the same, meaning same transmission style. I have plugged several different ECMs, both 5.2 and 5.9, into my trucks and they will run and drive normal. The only thing nobody can guarantee, unless they tried it, is if you can run that 5.2 ECM on a larger 5.9 engine while towing under heavy load. The camshafts have only very little difference.
                    The factory ECM tunes were very soft, so I think it would be safe enough, but getting another ECM is cheap and easy. Lots of these trucks in salvage yards. I usually only have to pay $45 bucks for a used ECM, in my area.
                    • Agree Agree x 2
                    • Like Like x 1
                    • krazykuda
                      krazykuda Well-Known Member FABO Gold Member How-To Section Editor
                      48,314
                      13321
                      Aug 20, 2007
                      Orland Park, IL
                      Local Time:
                      2:56 AM
                      THe passenger side motor mount is the same for all small blocks, but the driver's side is different widths between the 273/318 and the 340/360, so you will need to get the proper left side motor mount....
                    • Max1196
                      Max1196 Well-Known Member
                      687
                      391
                      May 12, 2016
                      Swift Current SK
                      Local Time:
                      1:56 AM
                      He's working with a "Magnum" 2000 vintage, the early style mount business should not be applicable for his truck.
                      • Agree Agree x 3
                      • pishta
                        14,894
                        4533
                        Oct 13, 2004
                        Tustin, CA
                        Local Time:
                        12:56 AM
                        Yes, my answer was balance too. Then added the TB and injectors were the same. Maybe didnt come out looking like that but it looks like a viable swap with the right flexplate. I wonder if the 5.2 ECU would figure the added duty cycle of the 5.9 when it saw a lean condition from the o2 sensor? Some ECU's are pretty nailed down while others (EECIV) are dynamic, and learn the motors profile.
                        • Agree Agree x 1
                        • SGBARRACUDA
                          14,588
                          4146
                          Dec 7, 2006
                          PLANT CITY FL.
                          Local Time:
                          3:56 AM
                          I am also buying a truck 5.9 (not sure on the year yet) complete engine with pullies, accessories. mounts.comp, alt, everything. Just don't know the history of it. So I should have everything I may need. Just waiting to get the tittle on it before I buy the two engines. Truck is club cab and is real nice. I also got a 2002 Dakota 4x4 quad cab 4.7 auto that is in nice shape. The other one I will get eventually is a 1996 ext cab Dakota. Bad 3.9.
                        • dusted
                          dusted FABO Gold Member FABO Gold Member
                          362
                          301
                          Sep 24, 2006
                          Creedmoor, NC
                          Local Time:
                          3:56 AM
                          Ecu is the same, program is different but it will run just fine with the 318 computer. We’ve done it before.
                          • Like Like x 1
                          • 67Dart273
                            39,803
                            7421
                            Oct 14, 2010
                            Idaho
                            Local Time:
                            12:56 AM
                            Just a stray "becuz" and I know you have an automatic.......The "White Whale III" an 01 Dodge 2500/ 5.9 gas, auto, I was considering swapping to a 5 speed.......and the crank IS NOT DRILLED AT ALL for a stick pilot!!! Only the converter bore is bored
                          • RustyRatRod
                            RustyRatRod 30 Degrees Outta Whack FABO Gold Member
                            53,008
                            20851
                            Jun 7, 2010
                            Georgia
                            Local Time:
                            3:56 AM
                            @Bighead440 didn't you determine the 360 can run off the 318 electronics? I know somebody I know did.......I thought it was you.
                            • Like Like x 1
                            • Agree Agree x 1
                            • Bighead440
                              Bighead440 Well-Known Member
                              176
                              107
                              Jun 18, 2017
                              Milledgeville, Georgia
                              Local Time:
                              3:56 AM
                              My 1992 D-150 that you found for me in Perry had a blown 5.2 and I replaced the long block with a 5.9, mildly modded even. I just "fooled" the ECM by using higher flow injectors (slightly, like 19.5#hr stock to 22#hr 4-hole units from Five-O Injectors). The cam is 200/206*@.050",112LSA and I used a single plane 2bbl M1 intake and shorty headers. Very peppy with zero driveability issues, sounds better, but drives like bone stock. Gets 15mpg hwy, typical 360-LOL.
                              • Like Like x 3
                              • MileHighDart
                                MileHighDart Well-Known Member
                                3,389
                                2205
                                Jun 3, 2004
                                Lyons, CO
                                Local Time:
                                8:56 AM
                                Just add .7
                              • RustyRatRod
                                53,008
                                20851
                                Jun 7, 2010
                                Georgia
                                Local Time:
                                3:56 AM
                                The Viper Truck. LOL
                                • Like Like x 1
                                • Bighead440
                                  176
                                  107
                                  Jun 18, 2017
                                  Local Time:
                                  3:56 AM
                                  • Like Like x 2
                                  • dartfreak75
                                    dartfreak75 Restore it, Dont part it! FABO Gold Member
                                    5,269
                                    3470
                                    Aug 10, 2011
                                    Virginia
                                    Local Time:
                                    3:56 AM
                                    Thanks for sharing this thread with me roy!
                                    I'm gonna reopen it lol I have a couple questions
                                    1) the swap I'm considering is a 5.2 to a 5.9 as well but my 5.2 is a 5 speed manual the 5.9 is an automatic I am keeping the 5 speed what do I need as far as flywheel goes for the 5.9 to keep the balance ? Will the 5.2 flywheel mess with the balance or does it have to be a 5.9
                                    2) i know the tb and intake are the same but electric wise will the computer have to be changed i have both computers so changing it wont be that big of a deal but if I dont have to I wont!
                                    3) are there any difference in the injectors or are they the same too? I'm thinking about since its gonna be out anyway going ahead and getting the huges tb mod and replacing the plenum gasket I'm sure it needs it. I may even pull the heads and clean the valves and everything really good I'm not sure yet. I'd like to do headers also. What modifications can I make to the engine without messing with the computer at what point will it need to be reprogrammed or whatever has to be done? I'm not real knowledgeable with newer computer controlled engines so this is new to me. Thanks
                                  • 67Dart273
                                    39,803
                                    7421
                                    Oct 14, 2010
                                    Idaho
                                    Local Time:
                                    12:56 AM
                                    You will have to get a 5.9 flywheel for balance. Also THE ENGINE MAY NOT BE DRILLED at all for a pilot if it's out of an auto. One of mine was not. This is not as hard as it sounds. You can drill an "oversize" hole "by hand" to clear the pilot, measure carefully and make it deep enough to clear the pilot as well as large enough. Then use one of the large fat pilot bushing/ bearings that fits the big converter bore.
                                    • Agree Agree x 1
                                    • Bighead440
                                      176
                                      107
                                      Jun 18, 2017
                                      Local Time:
                                      3:56 AM
                                      I did a '92 D-150 swap from 5.2>5.9L and all I did was use fatter injectors recommended by Five-0-Motorsports to supply my mildly modded (200/206*112LSA cam) '97 360 Magnum. The 5.2L PCM works fine!! 5.9mag2.jpg
