what is the difference ?
lol
how many differences are there usually in these things?
should we try to get to 12?
1 extra cylinders (on the wrong side)
2 removed the ballast resistor
3 new radiator
4 new coil
5 different air breather
lol
3 new radiator
4 new coil
6 ran out of washer fluid
7 disconnected the AC compressor
8 bypassed the heater core (funny story on that one, when I removed the heater core lines I found an allen head bolt pounded into the outlet molded to the waterpump so I figured the heater core must have been leaking and the previous owner decided to fix it like that)
9 installed headers
lol
3 new radiator
4 new coil
9 installed headers
10 moved positive battery cable 30 degrees
11 added a 4 barrel carb
12 moved the PCV valve to the drivers side
13 added a second AC belt
matt, the aircleaner was already mentioned
