What is this and do I need it?
Electrical and Ignition
  1. Cope
    Cope Fusing with fire
    2,445
    1838
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    1:41 AM
    This thing..
    It has a Chrysler part number 3656076 on it.
    [​IMG]
    It looks to share wiring with this plug.
    Edit- the plug has 2 blue wires and one black.
    [​IMG]
    I cant trace the rest of it wriring.
    What is the box an do I need it?
    what was that plug for and do I need it?
  2. 67Dart273
    67Dart273 Well-Known Member
    38,642
    6247
    Oct 14, 2010
    Idaho
    Local Time:
    11:41 PM
    Like all such posts, you need to post what in the #### you are working on.
    I suspect at least a 73? Something?
    I forget, might be EGR timer or NOx control
  3. MOPARMITCH
    MOPARMITCH Mekong Gold Member FABO Gold Member
    17,970
    6982
    May 15, 2013
    Maryland
    Local Time:
    2:41 AM
    x2
  4. Cope
    2,445
    1838
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    1:41 AM
    Sorry brother.
    Car is a 1971 Dodge dart swinger with a 318.
    part number on "thing" looks like 8-5?cant read firts number.
    5656076
  5. straightlinespeed
    straightlinespeed Sometimes I pretend to be normal Staff Member FABO Gold Member
    9,294
    2294
    Oct 21, 2012
    Oakdale, MN
    Local Time:
    1:41 AM
    That is for the NOX control.
  6. Cope
    2,445
    1838
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    1:41 AM
    I would bet on Flux capacitor chargeing point over 1971 factory squirters..
  7. Cope
    2,445
    1838
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    1:41 AM
    one black wire hookst.to this thing..
    [​IMG]
    Two blue wires go into this plug.
    [​IMG]
    Heres the unit removed.
    [​IMG]
    plug ends.goint.to ballast resistor.
    [​IMG]
  8. straightlinespeed
    9,294
    2294
    Oct 21, 2012
    Oakdale, MN
    Local Time:
    1:41 AM
    NOX , was a emmisions control device. That is part of the circuit that warned you when you were stepping on the gas to hard. It would flash the drivers side fender mount turn signal to warn you, your heavy on the throttle. It tied into multiple things. Look at your speedo cable there will be a large cylinder just below your brake booster with a single wire going into it as well. That was part of the system also.
    My suggestion remove it all. Its just not worth the hassle to get it to all work properly.
  9. grumpuscreature
    grumpuscreature Resident Curmudgeon
    3,029
    32
    Mar 11, 2006
    inabox
    Local Time:
    2:41 AM
    Good rule of thumb. If it's disconnected, the car runs, and everything you need still works, it can go in the s**t can....
  10. 67Dart273
    38,642
    6247
    Oct 14, 2010
    Idaho
    Local Time:
    11:41 PM
    Not familiar with "smog" regs in your area. Make sure you do not need smog equipment to maintain registration. This varies greatly from state to state and sometimes, areas within states
    AZ, example, has some of the most preposterous smog regs, consisidering how "open" the state is.
  11. Serj22
    Serj22 Well-Known Member
    1,232
    41
    Feb 14, 2013
    Benicia, CA East Bay
    Local Time:
    1:41 AM
    Looks like he's in South Lake, if you have it registered in CA, you can ditch it, and even put a v10 in the car, because you're pre 1975 and CA has no smog for pre75. If it's registered in Nevada, I have no idea.
  12. roadrunnerh
    roadrunnerh Well-Known Member
    2,867
    157
    Jul 11, 2011
    Pittsburgh, PA
    Local Time:
    2:41 AM
    That's not the "Fuel Pacer" switch. They first came out in '75 and were mounted on the top of the left inner fender.
  13. straightlinespeed
    9,294
    2294
    Oct 21, 2012
    Oakdale, MN
    Local Time:
    1:41 AM
    Wrong my 71 had it as well. I believe it was a n96 on the tag
  14. Cope
    2,445
    1838
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    1:41 AM
    Cool thanks guys.
    In my zip code smog is only.required.upon transfer,.witch is strange as we have so manny othe BS restrictions here...
    An this car is pre smog any way so that sucker is gone, 9 more crappy wires Ill never have to look at again.
    So now where the hell do I charge the flux capacitor?
