1. CFD244
    CFD244 FABO Gold Member FABO Gold Member
    990
    926
    Sep 7, 2017
    Northern Ontario, Canada
    Local Time:
    7:12 PM
    Hi Folks
    Does anyone recognize this by chance? I ordered a right rear cable for my '71 Demon and this is what came. The box was numbered correctly......
    Sheath is 60 inches long.
    unsheathed cable is 27 1/2 inches long.
    Regular cable and spring at the wheel end.
    Early A maybe?
    Let me know what you think.
    Thanks
  2. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    50,281
    18829
    Oct 14, 2010
    Idaho
    Local Time:
    4:12 PM
    That does not look like "underneath" to me. More like the cable that fits up into the car, in the handle assembly.
    • Agree Agree x 2
    • 4spdragtop
      4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
      32,321
      12984
      Aug 28, 2009
      Wasting time here
      Local Time:
      6:12 PM
      End pics and box with # ?
    • pishta
      pishta I know I'm right....
      20,694
      10005
      Oct 13, 2004
      Tustin, CA
      Local Time:
      4:12 PM
      That's a long ass tail for a cable. maybe a heater box control? Ball ends...E-brake?
    • dano
      dano Evil Handy Man
      3,977
      1809
      Aug 22, 2005
      Gresham, Oregon
      Local Time:
      4:12 PM
      A bodies have two brake cable routings, one where the main cable goes down the drivers frame rail to the equalizer then there is a short driver, long passenger cable. The main cable goes to the center of the car and I think the passenger and driver axle cables are the same length. Which do you have.
    • MOPAROFFICIAL
      MOPAROFFICIAL FABO Gold Member FABO Gold Member
      8,616
      7869
      Jun 1, 2016
      Beach
      Local Time:
      4:12 PM
      Maybe a ebake, hood latch cable oooor heater door cable?
      Hit the X if you're a bum.
      • Like Like x 1
      • Disagree Disagree x 1
      • Demonic
        Demonic Well-Known Member
        1,580
        1268
        Mar 21, 2015
        Maryland
        Local Time:
        7:12 PM
        There was a different park brake cable setup where the right side to the backing plate was longer than the left, there was one cable from the handle down the left side. I'm not sure what years had it.
      • CFD244
        990
        926
        Sep 7, 2017
        Local Time:
        7:12 PM
        My car has the left side set-up, last year for it. This cable is definitely an E brake unit with the way the sheath ends and spring end are designed. I had to re-order the right rear because of it, and the same number came with the correct cable arrived. This one must be mis-boxed. I was hoping that someone would recognize the long open end.
      • moparmat2000
        moparmat2000 FABO Gold Member FABO Gold Member
        19,845
        8801
        May 13, 2010
        Grand Tetons
        Local Time:
        6:12 PM
        Front cable from handle to crossmember
      • CFD244
        990
        926
        Sep 7, 2017
        Local Time:
        7:12 PM
        Hmm. One of the ends has the spring on it that looks like it goes inside the backing plate, and there is no adjuster rod.
      • AJ/FormS
        AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
        21,382
        8628
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        Local Time:
        6:12 PM
        that sorta looks like what is on my 68 Barracuda.
      • 4spdragtop
        32,321
        12984
        Aug 28, 2009
        Wasting time here
        Local Time:
        6:12 PM
        There is an orig one still attached to our 69 cuda. Got end pics for comparison?
