What is wrong with this picture?
Mopar Performance Issues
  1. IQ52
    IQ52 Well-Known Member
    2,312
    1547
    Jul 30, 2011
    Idaho
    Local Time:
    7:18 AM
    So like the stupid thing just shuts itself off on the dyno?
    • Like Like x 1
    • Daves69
      Daves69 Well-Known Member
      4,167
      2199
      Feb 20, 2011
      WestOfChi
      Local Time:
      8:18 AM
      • Like Like x 1
      • ChrisRomello
        ChrisRomello Well-Known Member
        144
        69
        Apr 7, 2017
        Cocoa, Florida
        Local Time:
        9:18 AM
        Nice crack! Crack kills!
      • d55dave
        d55dave Well-Known Member
        2,361
        840
        May 20, 2010
        Kelowna, British Columbia
        Local Time:
        8:18 AM
        Ouch...... that hurts
        • Agree Agree x 1
        • Dfr360cuda
          Dfr360cuda Well-Known Member
          898
          269
          Aug 30, 2012
          Finleyville, pa
          Local Time:
          9:18 AM
          Cracked block ?
          Or
          Shrapnel ?
        • Bad Sport
          Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
          35,507
          14841
          Jun 12, 2010
          The Wolverine
          Local Time:
          9:18 AM
          I see both.
          Hydroloc??
        • rumblefish360
          rumblefish360 so close yet so far away
          34,808
          6708
          Jun 21, 2005
          New York, on a Island
          Local Time:
          9:18 AM
          OH WOW!
        • IQ52
          2,312
          1547
          Jul 30, 2011
          Idaho
          Local Time:
          7:18 AM
          AND where do you suppose that sneaky little exhaust valve head went to?
        • RAT ROD AL
          RAT ROD AL FABO Gold Member FABO Gold Member
          1,408
          1212
          Jan 18, 2013
          St. James City. FL.
          Local Time:
          9:18 AM
          Shoulda bought the extended warranty I guess. LOL bummer
        • TrailBeast
          TrailBeast Slightly Twisted Member
          19,673
          6185
          Mar 11, 2011
          Arizona
          Local Time:
          6:18 AM
          I'd bet it went over to the pistons house and they both went to visit Mr. oil pan.
          That sucks man.
          Do you suppose all those chunks in the valley came out through that crack?
          Looks like it.
          • Like Like x 2
          • Thanks! Thanks! x 1
          • Max1196
            Max1196 Well-Known Member
            678
            383
            May 12, 2016
            Swift Current SK
            Local Time:
            7:18 AM
            Chev Orange. Does it every time!
            • Like Like x 3
            • Agree Agree x 2
            • IQ52
              2,312
              1547
              Jul 30, 2011
              Idaho
              Local Time:
              7:18 AM
              The valve head didn't make it all the way to Mr. oil pan like the piston.
              Those chunks? They did come through the crack. Before the head was pulled you could see the cam and lifters through the exhaust port.
              This is sorta what happens if you put big valves in a 915 head, put them on a 361 block, and don't check carefully enough to see if the valves are going to hit the cylinder walls. There were divots at the tops of the deck of every bore where the valves were hitting.
              I'm trying to remember correctly but it seems like it was still making well over 500 HP when it let go.
              • Agree Agree x 1
              • IQ52
                2,312
                1547
                Jul 30, 2011
                Idaho
                Local Time:
                7:18 AM
                The valve head? They found it down in that hole into the water jacket.
                There wasn't any cylinder wall remaining on the cam valley side of the engine.
              • Mopar Tim
                Mopar Tim FABO Gold Member FABO Gold Member
                15,370
                8122
                Nov 29, 2014
                vista CA.
                Local Time:
                6:18 AM
                It'll buff out! JB weld to the rescue!!! Damn...bummer.
              • TrailBeast
                19,673
                6185
                Mar 11, 2011
                Arizona
                Local Time:
                6:18 AM
                Yeow, that sucks.
                I hate to ask because I don't want to come across like I never screw up:D but how did it not occur to you that the valves might hit?
              • IQ52
                2,312
                1547
                Jul 30, 2011
                Idaho
                Local Time:
                7:18 AM
                Sah good question! It's kinda like this, I didn't build that engine.
                We were over fiddle-farting with our engine.........
                ..............and we hear a WHUMP over from Comp Cam's dyno room. I took those pictures as they tore the engine down.
                With ours, the only problem we had was they forgot to turn the water into the engine before they fired it. I was looking at the dyno control panel thinking something is wrong, when the engine made some weird noises and the operator shut it down. Eight exhaust valves stuck to the bronze guides and the guides were moving up and down in the 906 heads with the valves.
                My boys on the left and their cousin on the right in Comp's dyno room. After some repairs it made 730 HP.
              • toolmanmike
                toolmanmike FABO Staff Staff Member FABO Gold Member
                38,694
                20990
                Jan 18, 2006
                Iowa
                Local Time:
                8:18 AM
                Looks like a clear case of "Unscheduled Engine Disassembly" ! Yep, I'll bet that's what it is.
                • Like Like x 1
                • famous bob
                  famous bob mopar misfit
                  12,549
                  3500
                  Aug 14, 2011
                  okla
                  Local Time:
                  8:18 AM
                  Interesting on the h.p. Whats the engine got in it? would like to compare it to mine. Thinking 723 here. Really sucks on the small block !!
                • DFX 340 Duster
                  DFX 340 Duster FABO Gold Member FABO Gold Member
                  1,646
                  411
                  May 14, 2009
                  Orange County CA
                  Local Time:
                  6:18 AM
                  Interesting!
                  My first Mopar had a 361 motor in it. I did everything to it that most people did to their 383s in those days (484 purple cam, Edelbrock DP4B intake, Carter AVS from a 440, windage tray, headers, open element air filter, Accel dual point distributor) and it really woke up. My Mopar buddies told me about the potential valve clearance issues if I went to the 915 or 906 heads and tried to run big valves.
                  I ended up rebuilding the original heads with the same size valves.
                • WoodenNickle
                  WoodenNickle Just Damn.....
                  205
                  43
                  Sep 8, 2013
                  Gray, GA
                  Local Time:
                  9:18 AM
                  A little JB Weld will fix you right up.
                • cuda620
                  cuda620 Well-Known Member
                  1,523
                  137
                  Oct 26, 2014
                  indiana
                  Local Time:
                  8:18 AM
                  451 or 470?
                • IQ52
                  2,312
                  1547
                  Jul 30, 2011
                  Idaho
                  Local Time:
                  7:18 AM
                  Aside from what you see on the outside? Lesse, 56% leakdown with 15 bent valves. Cranking over it would spit back through the carburetor and we couldn't throw enough ignition advance in it to keep the exhaust pipes from glowing red. Nothing much else, 93 octane Sunoco, 11.9:1, our ported 906 heads, Erson solid roller around 278/280 @ .050 and about .800' lift or 280/288 and .780" (probably the later, hard to remember for sure, it was 2011 and I had both cams in my possession), Harland Sharp rockers, Ford blue paint.
                  It made 748 HP at home on 91 octane, with so much blowby it pegged the meter. We changed the ring pack and were breaking the engine in on Comps dyno when the valve guides seized.
                  Two votes for JB weld I see.
                  • Like Like x 1
                  • IQ52
                    2,312
                    1547
                    Jul 30, 2011
                    Idaho
                    Local Time:
                    7:18 AM
                    The 451 made 723 on Comp's dyno and 787 a few weeks later. We felt like this 500 could make close to 800 before it got toasted. The short block still sets in an AREngineering engine dolly beneath the shops electrical fuse panel. One just never knows, does one?
                  • cuda620
                    1,523
                    137
                    Oct 26, 2014
                    indiana
                    Local Time:
                    8:18 AM
                    We all learn from what you do or see...
                  • dukeboy_318
                    dukeboy_318 Our Lives, Our Fortunes and Our Sacred Honor. FABO Gold Member
                    32,002
                    10907
                    Jan 19, 2007
                    la la land
                    Local Time:
                    9:18 AM
                    I thought you'd given up the engine building gig?
