Bill Crowell
I want to lift the body off the frame of my '22 Dodge Bros. tourer in order to do a proper restoration. I plan to jack the body up off the frame, put two 2x4s under it, and attach 4 cables to the ends of the 2x4s, running the cables over pulleys attached to lift points in my ceiling.
Should I use hand crank gear winches like this on the cables, and attach them to the shop walls?
Haul Master 1/2 Ton Capacity Hand Crank Gear Winch, Portable hand winch for sale online
Seems like it might be overkill; what do you think? Is there another, more suitable cable winch that I am not aware of?
Thanks, guys. And I'm sure John and Horace would thank you, too, if they could.
