What mods for my 904 when using the BPE 408?
BluePrint Engines
  1. Mopar Vince
    Mopar Vince I'd rather push my Mopar than drive any Ford FABO Gold Member
    124
    298
    Dec 10, 2018
    Santa Cruz, ca
    Local Time:
    8:17 AM
    I will be replacing the tired, smokey, original 273 in my 1967 Barracuda #projectvertfish with a fresh BPE 408.
    Since it wont ship until mid October 2020, I have some time to freshen up, build up, and modify my 904 TF transmission to hopefully handle the 500-ish HP.
    What mods can you recommend and what torque converter should I get?
    Thanks in advance.
  2. Johnny Mac
    Johnny Mac www.blueprintengines.com FABO Vendor
    3,880
    3151
    Jul 10, 2010
    OHIO
    Local Time:
    11:17 AM
    Hey buddy, tagged you in our trans package post. Or, if you are going local rebuild, and sourcing your converter elsewhere, I have an ATI in mine. There are lots of good converter companies out there. Used Hughes in the past. I hear good things about PTC also. Usually get what ya pay for in a converter.
  3. rumblefish360
    rumblefish360 So close, yet so far away FABO Gold Member
    41,553
    13046
    Jun 21, 2005
    New York, on a Island
    Local Time:
    11:17 AM
    What flex plate should be used? Neutral or weighted?
    Thanks
  4. Phreakish
    Phreakish Well-Known Member
    1,274
    868
    May 28, 2015
    N. Idaho
    Local Time:
    8:17 AM
    • Thanks! Thanks! x 1
    • Johnny Mac
      3,880
      3151
      Jul 10, 2010
      OHIO
      Local Time:
      11:17 AM
      Assuming the converter is neutral, as most aftermarket ones are, then Yes, you use an LA 360 balanced flexplate.
      The Balancer (which we sell for under $90, and include on most dressed engines) uses the magnum weight for our engines)
      Mopar Small Block Harmonic Balancer | 273 | 318 | 340 | 360 | 408 |
      if its purchases on its own, it comes with various weights for all SB balances.
      • Like Like x 1
      • kursplat
        kursplat FABO Gold Member FABO Gold Member
        3,989
        2925
        Aug 24, 2010
        so cal
        Local Time:
        8:17 AM
        call Cope Racing and talk to John. i'm loving my new MRVB with the 273. planning to order the 408 from JM early next year. what gears are you running?
        also, don't know if your planning to stay full auto or not, but if not... -
        • Like Like x 2
        • rumblefish360
          41,553
          13046
          Jun 21, 2005
          Local Time:
          11:17 AM
          OK cool, so, IF I don’t have a flexplate, I use a B&M 360 flexplate designer for neutral balance converters.
          Correct? And a front harmonic balancer like yours or one for the listed years on the Blue Print site.
        • Johnny Mac
          3,880
          3151
          Jul 10, 2010
          OHIO
          Local Time:
          11:17 AM
          You got it!!!!
          Both of our current 408 engines need the magnum weighted damper. thats as of today. the 4085 and 4082 based PN's
          For the flexplate 95% of the time, you order one for a LA360 balanced engine. BECAUSE most aftermarket torque converter are neutral. so the imbalance is made up at the flexplate.
          Chrysler in their infinite wisdom from the factory, used NON weighted flexplates, and put the weight on the converter. not many aftermarket companies weight the converter. but i have seen it.
          so the only reason to buy a neutral flexplate for our 408, is if your converter was built with the weight on it. which is rare....or stock....and stock doesn't jive well with a cam anyways.
        • Mopar Vince
          124
          298
          Dec 10, 2018
          Santa Cruz, ca
          Local Time:
          8:17 AM
          • Like Like x 7
          • rumblefish360
            41,553
            13046
            Jun 21, 2005
            Local Time:
            11:17 AM
            @Mopar Vince It is in my opinion that the 904 will serve you well without issues while allowing more HP & Tq. to the wheels since it takes less lower to turn. The lighter weight is also a plus.
            • Agree Agree x 3
            • kursplat
              3,989
              2925
              Aug 24, 2010
              so cal
              Local Time:
              8:17 AM
              and a little more room to hook things up is nice too. what gears in the rear?
            • Mopar Vince
              124
              298
              Dec 10, 2018
              Santa Cruz, ca
              Local Time:
              8:17 AM
              It has the super rare, a-body 8.75 with a 3.23 sure grip center section. It originally had a 7.25 peg-leg. I was lucky enough to pick one up for just $550 from a local Mopar guy. He even threw in a just right rear disc kit with it and a set of large bolt pattern Yukon axles.
              • Like Like x 3
              • Krooser
                Krooser Reform School Graduate
                3,192
                2744
                Jul 19, 2015
                Central Wisconsin
                Local Time:
                10:17 AM
                A 904 will suit you well.
              • oldkimmer
                oldkimmer FABO Gold Member FABO Gold Member
                19,836
                6846
                Nov 11, 2006
                Kindersley, Saskatchewan,
                Local Time:
                10:17 AM
                Am I reading this right? A Magnum weighted dampner and a LA weighted flexplate. Kim. @Johnny Mac
                • Agree Agree x 1
                • Mopar Vince
                  124
                  298
                  Dec 10, 2018
                  Santa Cruz, ca
                  Local Time:
                  8:17 AM
                • Johnny Mac
                  3,880
                  3151
                  Jul 10, 2010
                  OHIO
                  Local Time:
                  11:17 AM
                  For all.
                  Trans i recommend(same 30 month warranty as the engine)
                  MOPAR SB 727 PACKAGE | 3 SPEED AUTO KIT FOR SB MOPAR | 2200-2600 STALL CONVERTER
                  Damper I recommend (magnum weight)
                  And a LA 360 flexplate, assuming you have an aftermarket, non weighted, converter.
                  We DO sell complete engine/trans packages
                  And we can work together on options
                  BLUEPRINT ENGINES BUILDER SERIES Mopar 408CI Stroker Crate Engine and 727 Auto Transmission | Small Block Chrysler | Roller Cam | Polished Front Accessory Drive
                • Johnny Mac
                  3,880
                  3151
                  Jul 10, 2010
                  OHIO
                  Local Time:
                  11:17 AM
                  Correct, the assemblies balance best with the la 360 flexplate, and mag 360 damper.
                  Most of our aluminum headed engines ship with with damper pre installed.
                • oldkimmer
                  19,836
                  6846
                  Nov 11, 2006
                  Local Time:
                  10:17 AM
                  So is this a magnum or LA engine? Or do they all balance like that? Kim
                  • Agree Agree x 1
                  • 66fyssh
                    66fyssh Don't Stop Believin' FABO Gold Member
                    6,381
                    5946
                    Jun 22, 2013
                    Northwest GA
                    Local Time:
                    11:17 AM
                    Agree Kim, I'm confused.
                  • Johnny Mac
                    3,880
                    3151
                    Jul 10, 2010
                    OHIO
                    Local Time:
                    11:17 AM
                    @oldkimmer @66fyssh
                    Its a Magnum block. It can easily bolt in place of any LA engine.
                    A. It uses a Magnum weighted damper
                    B. It uses an LA 360 flexplate / flywheel.
                    Its an aftermarket rotating assembly, it requires less weight to balance than a stock 360, so the nose gets the slightly smaller, Magnum weight when we spin it up and balance it.
                    Any confusion is kind of a mute point as the aluminum headed engines come with the proper damper already on them, and we sell the damper outright also.
                    • Like Like x 1
                    • oldkimmer
                      19,836
                      6846
                      Nov 11, 2006
                      Local Time:
                      10:17 AM
                      I would then think it would be a good idea to include the dampner and flex plate so there would be no balance issues for no one. Just my observation. Kim
                    • Johnny Mac
                      3,880
                      3151
                      Jul 10, 2010
                      OHIO
                      Local Time:
                      11:17 AM
                      Damper is included on most configurations. Shouldn't be any issues for those that read the included documentation, or look at our website.
                    • oldkimmer
                      19,836
                      6846
                      Nov 11, 2006
                      Local Time:
                      10:17 AM
                      Thanks
                    • 12many
                      12many Well-Known Member
                      2,043
                      2458
                      Dec 14, 2016
                      South Car
                      Local Time:
                      10:17 AM
                      One thing not often mentioned about flex plates is the fact that the B&M flex plate (or other race HD style) is a much thicker and more rigid type vs. the oem style that actually flexes. It’s less forgiving/ doesn’t really flex compared to the oem. If the block has ever been line bored you might run into a scenario where the crank is on a different centerline than the trans input shaft and pump hub bushing etc and the converter being on a less flexing plate could wear the bushing in the pump, possibly more so than using oem. Just something to consider when deciding going with an oem or more race oriented piece that would require checking things and possibly using offset dowels on the block.
                      • Like Like x 1
