What power steering pump was factory for a 68 Barracuda Formula S-340
Mopar General Discussions
  1. My68FormulaS
    My68FormulaS Active Member
    44
    4
    Mar 8, 2014
    Round Rock, Texas
    Local Time:
    6:34 AM
    I have a 68 Barracuda Formula S-340 and I need to replace the power steering pump, but am not sure the best place to get a new one. I am not sure if it is the Federal pump, which looks to be the one in my car. Was it a Federal pump or a Saginaw?
    The pump currently in my car looks to be a Federal, but the pulley is off and I could never get it moved in correctly. Thanks
  2. Vertex_Jeff
    Vertex_Jeff Undocumented Mopar Guy
    156
    263
    Nov 10, 2019
    Richmond IN 47374
    Local Time:
    7:34 AM
    That is a Federal. I needed a new pulley for a Federal years ago, and had trouble sourcing a used one that wasn't bent.
  3. xLURKxDOGx
    xLURKxDOGx "An angel fat, at satan's feast"
    4,344
    1680
    Dec 27, 2013
    PHX
    Local Time:
    4:34 AM
    If you're handicapable the best option is to rebuild it yourself. I think a kit is 20$?
    J.
  4. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    20,522
    7443
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    6:34 AM
    I think it may be possible it is a TRW pump. The way to tell them apart is looking at the back. A small notch where the bracket bolts into is a Federal. If it has a bigger/ longer notch it is a TRW. Kim
    • Agree Agree x 2
    • My68FormulaS
      44
      4
      Mar 8, 2014
      Round Rock, Texas
      Local Time:
      6:34 AM
      The other issue I have is that the pulley is too far out from the pump, so the belt is offset. You can see it better on the first picture. I don't see anyway to adjust it.
    • autoxcuda
      autoxcuda Well-Known Member
      7,450
      1724
      Apr 6, 2007
      Local Time:
      4:34 AM
      Was this an A/C originally
      Was it a car that was optioned for 3.55 or 3.91 gears?
      Was it originally a automatic or 4-speed ?
      those are factors what pump it came with originally
      • Agree Agree x 1
      • oldkimmer
        20,522
        7443
        Nov 11, 2006
        Local Time:
        6:34 AM
        The other thing may be that u have a big block or slant 6 pump swapped on to ur brackets. Kim
      • My68FormulaS
        44
        4
        Mar 8, 2014
        Round Rock, Texas
        Local Time:
        6:34 AM
        It has factory AC, it is an automatic. It currently has 3.23 gears in it.
      • My68FormulaS
        44
        4
        Mar 8, 2014
        Round Rock, Texas
        Local Time:
        6:34 AM
        I have the numbers matching trans and engine for my P-Code car, so it is original.
      • 4spdragtop
        4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
        32,476
        13582
        Aug 28, 2009
        Wasting time here
        Local Time:
        6:34 AM
        • Like Like x 1
        • Thanks! Thanks! x 1
        • Agree Agree x 1
        • autoxcuda
          7,450
          1724
          Apr 6, 2007
          Local Time:
          4:34 AM
          the factory 68 small blocks with a/c have the tire/federal pump originally. There’s big 2 pc pulley on the vibration damper that I now see in the picture.
          looks like the ac pump is removed now.
          You can switch that to a Saginaw pump with proper brackets they repro new. The Saginaw’s are better pumps and easier and cheaper to find rebuilt. My 68 dart conv was originally a 273 A/C car and had that trw/federal pump. When it went bad I swapped it with the brackets to a Saginaw pump.
        • My68FormulaS
          44
          4
          Mar 8, 2014
          Round Rock, Texas
          Local Time:
          6:34 AM
          It looks like it is a Federal pump, so that is good to find out. Any ideas on where to get a replacement? I really don't want to send it off for a rebuild and have the car down. Any ideas would be greatly appreciated. Thanks again
        • autoxcuda
          7,450
          1724
          Apr 6, 2007
          Local Time:
          4:34 AM
        • drewmac
          drewmac Well-Known Member
          353
          116
          Jun 7, 2012
          Lacey, Wa
          Local Time:
          4:34 AM
          Autoxcuda do you know where I can get just the pulley for the saginaw set up? Do they repro them? I am going from manual steering to power and have everything but the pump pulley.
        • autoxcuda
          7,450
          1724
          Apr 6, 2007
          Local Time:
          4:34 AM
          i don’t have one. But is your setup for Aluminum water pump or Cast Iron. They seem to take different pulleys
        • drewmac
          353
          116
          Jun 7, 2012
          Lacey, Wa
          Local Time:
          4:34 AM
          Cast Iron. Doing the Borgeson conversion and need the pulley.
        • 1969383S
          1969383S FABO Gold Member FABO Gold Member
          6,723
          3715
          Jan 8, 2012
          Cumming, GA.
          Local Time:
          7:34 AM
          The pulley alignment depth is easily adjusted with the correct tools on Federal or TRW pumps.
          Based on the first photo though, something is mismatched, likely the pulley! That pulley diameter looks very small in my eye!
        • SGBARRACUDA
          SGBARRACUDA ROY FABO Gold Member
          21,537
          10036
          Dec 7, 2006
          PLANT CITY FL. and PERRY GA.
          Local Time:
          7:34 AM
          On my 68 273. It had a Saginaw.
        • 1969383S
          6,723
          3715
          Jan 8, 2012
          Cumming, GA.
          Local Time:
          7:34 AM
          Looking through some reference photos of multiple SB original cars from 8/9 I see the same!
        • autoxcuda
          7,450
          1724
          Apr 6, 2007
          Local Time:
          4:34 AM
          Where both cars non air conditioning ?
        • oldkimmer
          20,522
          7443
          Nov 11, 2006
          Local Time:
          6:34 AM
          Any 69/9 A or. B body with small block had a Saginaw pump Kim
        • autoxcuda
          7,450
          1724
          Apr 6, 2007
          Local Time:
          4:34 AM
          Not on my 68 Dart Gt conv with A/C
          Not on OP’s 68 340–S w/ A/C
        • oldkimmer
          20,522
          7443
          Nov 11, 2006
          Local Time:
          6:34 AM
          I should clarify the cars I had no a/c. Kim
        • autoxcuda
          7,450
          1724
          Apr 6, 2007
          Local Time:
          4:34 AM
          it seems that way on non A/C cars
          Would like to see original 340 non-A/C 3.55 or 3.91 gear cars. Many times Mopar put TRW or Federal pumps on those geared cars.
        • oldkimmer
          20,522
          7443
          Nov 11, 2006
          Local Time:
          6:34 AM
          I know my 70/71/72 340 swingers and 71 340 demon had federal pumps. But that could be a 70 up thing for 340s only. Kim
