What puller are you using on the crank damper?
New Hemi Engine Swaps
  1. Krooser
    Krooser Reform School Graduate
    2,057
    1627
    Jul 19, 2015
    Land of Cheese
    Local Time:
    7:41 PM
    I have a few pre-'09 engines i need to diassemble. I need to know what damper puller you guys are using...
    I have used the one from O-Reilly's loaner program... no dice.
    Then I bought one on Amazon that was guarateed to work... that didn't do it. I tried to modify the arms to give it more clearance around the damper sides... still no good.
    My friend has a professionsl one he bought from the matco guy. I'm going to try that maybe tonite...
    Pix would be great.
  2. toolmanmike
    toolmanmike FABO Staff Staff Member FABO Gold Member
    46,917
    31207
    Jan 18, 2006
    Iowa
    Local Time:
    7:41 PM
    I sold many when I was a MAC dealer. It was a short legged puller with long rods for the forcing screw..
  3. SLOPAR72
    SLOPAR72 Well-Known Member
    1,839
    1202
    Jan 5, 2016
    Richmond, VA.
    Local Time:
    8:41 PM
    Lisle. Going on 30 years and works like day 1..... It all about the bolts, lubed threads, and a little patience. For extremely minimal use HF would get my money...
    JW
  4. toolmanmike
    46,917
    31207
    Jan 18, 2006
    Iowa
    Local Time:
    7:41 PM
    This is designed for the new balancers. There are no bolt holes for the old pullers.
    • Agree Agree x 1
    • JoePole1
      JoePole1 A dude in a B body FABO Gold Member
      300
      254
      Mar 3, 2018
      Hudson Valley, NY. NOT NYC!!
      Local Time:
      8:41 PM
    • 408 swinger
      408 swinger FABO Gold Member FABO Gold Member
      1,453
      1212
      Nov 12, 2010
      Iowa
      Local Time:
      7:41 PM
      Works great!!
    • Krooser
      2,057
      1627
      Jul 19, 2015
      Land of Cheese
      Local Time:
      7:41 PM
      IMG_20190908_194935078.jpg Well O'Reillys loaner did not work....nor did the one I bought on Amazon that supposed to be for the Hemi.
      None of the new style worked.
      So I dug deep in one of my tool chests and came up with the kind that's not supposed to work....and it worked!
      • Like Like x 1
      • 66 CUDA
        66 CUDA Well-Known Member
        1,695
        490
        Aug 20, 2009
        Clarkston Michigan
        Local Time:
        7:41 PM
        I always go over to Oreilys auto parts and use there's, leave a deposit to make sure you bring it back and it's free to use.
        • Agree Agree x 1
        • toolmanmike
          46,917
          31207
          Jan 18, 2006
          Iowa
          Local Time:
          7:41 PM
          Works as long as you don't pull the balancer apart.
          • Agree Agree x 3
          • Krooser
            2,057
            1627
            Jul 19, 2015
            Land of Cheese
            Local Time:
            7:41 PM
            Darn near 190K on it so that is a chance I can take.
            I have the exact same puller O'Reilly loans out...and I had theirs, too. DID NOT WORK. These early danpers, at least the two truck ones and the one Durango one I have are different than the newer ones. The 2014 5.7 I have out of a Challenger is different and I think that the new style would work OK. But not on these old ones.
            I spent about an hour grinding a relief in the puller arms on the one I bought in hope they would clear the wide part of the damper but that was a lost cause...
            Anyway I finally got the engine disassembled... learned a bit as this was the first Gen III I've pulled apart. The amazing thing was the main bearings still look new... you may have seen what the rods looked like. Good cross hatch in the cylinders, too...likely due to the low tension rings. Cam looks good. Lifters, too.
            I like the timing chain tensioner deal...
            The goofy thing was I could not get the crank to turn even after I had all the main caps off... must have had a hydraulic lock going on with the oil on the bearings. Once I tapped the crank with a hammer it broke free and turned fairly EZ.
            Now it's off to one of the shops I deal with... going to see if the crank can be saved. I want it turned down to 1.888 so I can use the Pankl rods I have in stock. This guy has done a few for me and always gets the work done on time and budget. Might have the block washed and mag'd, too.
            Yeah, Yeah I know it's a nodular iron crank but that doesn't bother me. Never had any issues with those in the 351-C's I raced for years.
            • Like Like x 1
            • Krooser
              2,057
              1627
              Jul 19, 2015
              Land of Cheese
              Local Time:
              7:41 PM
              Here's the puller I got from Amazon... identical to the one from O'Reilly's. NO soup for you!
              • Agree Agree x 1
              • famous bob
                famous bob mopar misfit FABO Gold Member
                15,366
                5545
                Aug 14, 2011
                okla
                Local Time:
                7:41 PM
                I use a simple cheap steering wheel puller , bolts into the pulley holes , no arms to distort or screw up the damper ----
                • Like Like x 1
                • Krooser
                  2,057
                  1627
                  Jul 19, 2015
                  Land of Cheese
                  Local Time:
                  7:41 PM
                  No holes in these new dampers. I tried the five different pullers I had handy until I remembered my stash of seldom used tools in one roll cab...that's why we never throw anything away!!!!
                  AND IT'S APART... and really looks good. The main bearings could be reused...I'm saving them in case I need a real cheap rebuild down the line.
                  While there was a big disaster inside that motor it all looks good... no sludge to speak of...washed up great with super clean. The cooling system is clean, too. I noticed that the coolant passages don't go very far down around the cylinders... it's like a hard filled block. Pretty strong IMHO.
                  I called my valve supplier... tried to order new stuff but the blanks are on order...60 days out for sure. That's OK. Going to send the cam out for a grind... looks good, too.
                  All in all I'm pleasantly surprised at this engine.
                  • Like Like x 2
                  • dusted
                    dusted FABO Gold Member FABO Gold Member
                    475
                    429
                    Sep 24, 2006
                    Creedmoor, NC
                    Local Time:
                    8:41 PM
                    Amazon special also. Has pulled 4 LS and I Hemi balancer so far.
                    • Like Like x 1
                    • Krooser
                      2,057
                      1627
                      Jul 19, 2015
                      Land of Cheese
                      Local Time:
                      7:41 PM
                    • famous bob
                      15,366
                      5545
                      Aug 14, 2011
                      okla
                      Local Time:
                      7:41 PM
                      How does one bolt the pulley on w/ no holes in it ??
                    • 69_340_GTS
                      69_340_GTS Well-Known Member
                      3,785
                      1678
                      Jul 11, 2014
                      Torrington, CT
                      Local Time:
                      8:41 PM
                      The crank pulley and the dampener are one integrated unit. Uses a serpentine belt.
                    • toolmanmike
                      46,917
                      31207
                      Jan 18, 2006
                      Iowa
                      Local Time:
                      7:41 PM
                      Exactly. No threaded holes for the puller to bolt to. You need a 3 jaw puller with short jaws to pull off the 3 webs on the balancer. The rods in the kit go in the crank bolt hole and push off the bottom of the drilled passage in the crank snout. Some cranks are drilled a few inches. You don't want to push against the front of the hole because it can damage the threads in the end of the crank. Proper tool, proper use!
                      • Agree Agree x 3
                      • toolmanmike
                        46,917
                        31207
                        Jan 18, 2006
                        Iowa
                        Local Time:
                        7:41 PM
                        Oh by the way, when you re-install the balancer, use a installer tool and not a hammer and a block of wood or worse yet, a impact wrench and the balancer bolt.
                        • Agree Agree x 1
                        • dusted
                          475
                          429
                          Sep 24, 2006
                          Creedmoor, NC
                          Local Time:
                          8:41 PM
                          I’ve used all the methods mentioned but by far the easiest is a little heat helps it slide completely on.
                        • famous bob
                          15,366
                          5545
                          Aug 14, 2011
                          okla
                          Local Time:
                          7:41 PM
                          GOTCHA >
                        • Krooser
                          2,057
                          1627
                          Jul 19, 2015
                          Land of Cheese
                          Local Time:
                          7:41 PM
                          Geez...I have a factory Miller 2X4 just for that purpose....
                          • Like Like x 1
                          • Kiddart1
                            Kiddart1 Well-Known Member
                            126
                            36
                            Aug 27, 2008
                            Macomb Michigan
                            Local Time:
                            8:41 PM
                            guys the picture above tells you the answer. invert the prongs they catch the dimples on the back side(69 340 gts #17 above) and the pully walks right off with a long rod. I made a long rod out of threaded rod and then used the bolt provided with the kit. you will damage the pully if you try to grab from the outside edge. I wish I had a picture of what I had for mine. I googled it and found I was doing it wrong.
                            • Like Like x 1
                            • Krooser
                              2,057
                              1627
                              Jul 19, 2015
                              Land of Cheese
                              Local Time:
                              7:41 PM
                              None of my pullers would grab the backside.... I'm not worried about wrecking a 13 year old pulley with almost 200,000 miles.
                              This deal was a real head scratcher. 60 years of engine work and I never had such grief.
