What Radiator, Shroud and electric fan should I use for my 360?
Heating / Cooling / AC
  1. 67DodgeDart360
    67DodgeDart360 Well-Known Member
    299
    61
    Nov 8, 2015
    Maryland
    Local Time:
    2:51 AM
  2. Dana67Dart
    Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
    6,313
    4138
    Jul 16, 2017
    Northern Colorado
    Local Time:
    1:51 AM
    Look for 70 up radiators. They should have the in and out on the correct side for your 360
    IMHO stick with oem style stock copper brass HP/AC radiator, and an OEM shroud and a fixed 7 blade OEM fan. No need for a clutch fan, they do nothing for cooling.
    Electric fans seem cool but so many people put them in and have issues.
    • Agree Agree x 1
    • CRUZE 418
      CRUZE 418 FABO Gold Member FABO Gold Member
      660
      274
      Mar 11, 2019
      Illinois
      Local Time:
      2:51 AM
      '70 and up aluminum pump, inlet pass side.
      '69 and down cast iron pump inlet on drivers side. Forgot to say, the cast iron pump is 3/4"" shorter. If you go with an aluminum radiator, and the Hayden 2947 fan clutch, you will probably want that 3/4" of space, may need it anyway.
    • Dana67Dart
      6,313
      4138
      Jul 16, 2017
      Northern Colorado
      Local Time:
      1:51 AM
      Thanks for the clarification, I edited my post
    • 67DodgeDart360
      299
      61
      Nov 8, 2015
      Maryland
      Local Time:
      2:51 AM
    • CRUZE 418
      660
      274
      Mar 11, 2019
      Illinois
      Local Time:
      2:51 AM
      Your inlet is on the bottom, outlet on top.
      That's the aluminum pump, '70 and up. Have no idea what that radiator is for.
      • Agree Agree x 1
      • TrailBeast
        TrailBeast AKA Mopars4us on Youtube
        21,672
        9474
        Mar 11, 2011
        Arizona
        Local Time:
        12:51 AM
        That depends on whether you are talking about the radiator or the water pump. :D
        • Agree Agree x 1
