metallidart
member me?
I'll be running a Lunati Voodoo 60433 solid roller cam in my 422. Specs are Solid roller, rough idle. Excellent cam for street/strip applications with explosive mid range and upper RPM torque and horsepower. Works well in 340-360 cubic inch engines. Needs 3000-3500 RPM stall speed converter or 4-speed transmission, 10.25:1 or better compression ratio, aftermarket performance exhaust and 4.10 rear gears.
- Advertised Duration (Int/Exh): 279/285
- Duration @ .050 (Int/Exh): 249/255
- Gross Valve Lift (Int/Exh): .585/.600
- LSA/ICL: 110/106
- Valve Lash (Int/Exh): 016/016
- RPM Range: 3000-7000
