What should be my temp?
Small Block Mopar Engine
  1. tony20110
    tony20110 Well-Known Member
    218
    16
    May 14, 2013
    Manassas Va
    Local Time:
    5:13 PM
    I have a 1973 360la in a 66 cuda. Bored .30 and zero decked. Stock crank, KB pistons, comp high energy 268 cam, ported polished heads, air gap with a 2 inch riser, holley 750, hedman fenderwall headers. 9.5-1 compression. I have a 22 inch champion radiator with dual fans. I'm guessing I'm around 385hp. I idle in park at 1100 rpm and in drive at 900-800. What should be my max temp? Thanks in advance.
  2. mopowers
    mopowers Well-Known Member
    5,580
    2662
    Feb 15, 2006
    West Sacramento, CA
    Local Time:
    2:13 PM
    Anything over 230 makes me pucker.
    Why such a high idle and large rpm drop in gear?
    • Agree Agree x 2
    • tony20110
      218
      16
      May 14, 2013
      Manassas Va
      Local Time:
      5:13 PM
      The cam
      • Disagree Disagree x 1
      • Mike 340
        Mike 340 Well-Known Member
        142
        41
        Jun 21, 2016
        Canada
        Local Time:
        5:13 PM
        I have the same cam. Idle in park is 850rpm and in gear 750 rpm. Sounds like you have timing or carb issues or both.
        • Agree Agree x 2
        • SIX225
          SIX225 Well-Known Member
          144
          71
          Jan 31, 2016
          Illinois
          Local Time:
          4:13 PM
          What are you using for a temp gauge? The one in my dash reads a lot hotter than it should, yet an infrared temperature gauge reads closer to normal. I've tried several different senders but no change. Might be worth looking into.
          • Like Like x 1
          • Agree Agree x 1
          • Yote
            Yote Well-Known Member
            1,165
            480
            Aug 30, 2015
            far eastern Colorado
            Local Time:
            3:13 PM
            Your temperature should be close to what your thermostat rating is unless the ambient temperature is extra hot or after a hard run.
            Yote
            • Thanks! Thanks! x 1
            • Agree Agree x 1
            • AJ/FormS
              AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
              20,987
              8308
              Jan 19, 2014
              South-Central Manitoba,Canada, 900ftelevation
              Local Time:
              4:13 PM
              The stat sets the minimum coolant temperature. The rest of the cooling system, sets the maximum temp. If the fans cannot pull enough air through the rad at idle then the temp will rise and rise and rise and then the rad cap will finally blow off, releasing the pressure, and then it starts all over.
              This does not usually happen over 30mph, cuz ram air thru the rad is usually sufficient to help the rad shed heat.
              Of course the pump has to be able to move the cooled water thru the engine.
              If you are asking what is a desirable minimum water temp to run, I think 205*F is a good number. Engines can and will make more power at a lower temp , but they will also wear out faster at that lower temp. Some say 195*or 185* is a reasonable compromise. My philosophy is that if you can spin the tires all the way thru first gear, you already have more power than the chassis can handle, so, how about giving up some power for long life. I have been running 205 since 1999 AND blowing the tires off to well past 50 or 60 mph.I call that a good compromise.
              I run fresh cold air into the carb.
              If your engine is sucking in hot underhood air, you may have to run a lower minimum temp to keep the engine out of detonation. Avoiding detonation is priority one.
              A high idle rpm creates a lot of underhood heat.You really need to get that lowered. I run a 276/286/110 cam, and my idle is 750 or less. It is a stick car, and I can pull the idle down to 650 or less with the clutch.I only idle it at 750 to ensure lots of oil is circulating.I'm not impressed with a lumpy idle.
              If you haven't already set the T-port sync, this should be at the top of your to-do list.
              • Agree Agree x 1
              • mopowers
                5,580
                2662
                Feb 15, 2006
                West Sacramento, CA
                Local Time:
                2:13 PM
                There's no reason that baby cam should need to idle so high. Give that thing more initial timing and work on the tune. That has a definite effect on running temp.
                • Agree Agree x 3
                • fishy68
                  fishy68 Tyr Fryr's Inc.
                  16,956
                  956
                  Jan 11, 2005
                  Central, IL (Hooterville)
                  Local Time:
                  4:13 PM
                  I run mine at 190* as it's more efficient there. Keeps the plugs cleaner and better fuel mileage (its' a 408 so I need all the fuel mileage I can get). I'd check with an infrared temp gun as SIX225 recommended. I installed an expensive Autometer temp gauge and right off the bat it was off 15 degrees. I never trust gauges until I verify them with my temp gun
                  I know this isn't related to your question but something isn't right cause that cam should idle decent at 700-750 in neutral. Did you recurve the distributor to give it more initial timing? If not you need to
                • mopowers
                  5,580
                  2662
                  Feb 15, 2006
                  West Sacramento, CA
                  Local Time:
                  2:13 PM
                  What thermostat do you use?
                • nm9stheham
                  nm9stheham Well-Known Member
                  12,090
                  3959
                  Dec 20, 2013
                  Waynesboro, VA
                  Local Time:
                  5:13 PM
                  From my sons' 340 experience with a very similar setup in a '65 Cuda, the OP's 22" rad and whole cooling setup is marginal and the temps will climb. I'm gonna put in a different rad (as the Champion's 3 row design tends to be marginal), and we will work on more airflow through the whole engine compartment. With the small engine compartment and the higher temps generated with higher CR's, the heat takes more airflow in and out to control. The openings for the headers may help the OP.
                • fishy68
                  16,956
                  956
                  Jan 11, 2005
                  Local Time:
                  4:13 PM
                  Mr. Gasket high flow
                  • mopowers
                    5,580
                    2662
                    Feb 15, 2006
                    West Sacramento, CA
                    Local Time:
                    2:13 PM
                    Does Mr. Gasket make a 190* thermostat? The only ones I see are 180 and 195.
                  • fishy68
                    16,956
                    956
                    Jan 11, 2005
                    Local Time:
                    4:13 PM
                    Maybe it is 195. It was 2011 when I put it in and my memory isn't perfect. With whatever is in it the temp runs 190-195 (verified by a good quality infrared temp gun). If I get in bad traffic for a long time it has crept up to 210. Never saw it above 210
                  • TrailBeast
                    TrailBeast AKA Mopars4us on Youtube
                    21,710
                    9538
                    Mar 11, 2011
                    Arizona
                    Local Time:
                    2:13 PM
                    Yep, I run a 195 and average between 190 and 210.
                    Fans come on at 210 and go off at 195.
                  • Yote
                    1,165
                    480
                    Aug 30, 2015
                    Local Time:
                    3:13 PM
                    If a thermostat has too high of opening temperature the coolant can circulate too fast not being allowed to cool in the radiator. The thermostat is constantly opening and closing regulating the temperature of the coolant. Therefore if you have a 195' thermostat the temperature will probably not get below that temperature. Like wise if the rating is too high the coolant will have to get to that temperature before it opens allowing flow to the radiator.
                    I had an engine once that constantly heated from the time it was new. Went to replace the thermostat and found it had none from the factory. Installed the correct thermostat and it never heated again.
                    Yote
                  • KnuckleDuster
                    KnuckleDuster Well-Known Member
                    1,768
                    756
                    Nov 9, 2005
                    Texas
                    Local Time:
                    5:13 PM
                    My .040 over 360 stroker runs 207° no matter what the weather is doing, idling in traffic or at WOT...
                    BTW, my Comp XE285HL idles about 850rpm in park and just under 800 in gear. You shouldn't have a 200rpm drop, and 1100 is pretty high. Even with the choke on fast idle mine is only at 975rpm.
