Yeah, I like the way it sits and how it rides. I haven't had a problem with them yet. I got mine from Summit back in late 2014, early 2015. A lot of people claim they're too low, but I like them. If you're running 15" wheels with a tall tire you may have problems with rubbing when the tire flexes. My sidewall is pretty short so I don't have that problem. I may go to composite leafs in the future, but we'll see.
@72bluNblu, don't you have some AFCO springs from summit and don't they come in two different stiffnesses? The less stiff one may be better for the OP.
For $1200, I'd probably do MOOG offset bushing, welded in subframe connectors, Bilstein RCD shocks, and Hellwig sway bars front and rear. As mentioned before, your tires are your limiting factor.
