what the men like.
chad72duster
Perdido, AL
this to complete Bretts thread, pics of my final engine before it goes in this weekend
once the bell housing is dialed in straight she id ready and the Craig should be here in time to help fire her up.
Uhh cwagf waoiATas canae7tsd tya[eps..
Sorry, had to wipe the drool of the keyboard. Nice lookin' motor!
Just trying to catch up with you jack, hurry up craig getting ready to set he in just put the clutch on and frech coat of paint on the bell housing.
new coat on the lakewood, and diff Chrysler Red to match the eng
Question what would be the easiest way for me to set this beast by myself/ I was thinking I would set the engine with the bell housing attached the stab the Trans from under on a trans jack. I can a damn soul to help me set it but you dan well can bet when the folks i know need something they will sure call me but those days are over they gonna pay from now on.
If you can angle the motor and you have the car up high enough you can put it in as an assembly, but if the crane does not lift high enough you may be better off putting the trans in after the engine is sitting in place.
Thats the prob I dont think I will be able to get it high enough to angle the trans in i think that the bell housing will go down which is the hardest part to bolt together and then i can stab the trans from the bottom with the clutch rod and throw out bearing.
Another delay, My trans that i had rebuilt at a cost of $525 is hung in first the first and second rod will not move at all nor the reverse the 3 and 4 move freely and suggestion before i take it back to the trans guy and beat $500 bucks out of his ***!!
Why cant folks just do it right the first time, he seems like a stand up guy just has some goof ball that work in the shop and they are killing his rep. he should can the lot of them and start new.
Hope you get the trans problem worked out. Looks like the earliest I can get there is in 2 weeks. I should have a definate date this weekend :wink:
that cool i should have it set before then but who know I am behind at work also. Just let me know when you have some dates.
Im taking the trans back today to the shop just hope i didnt get screwed.
Chad, I wouldn't advise putting that thing in as an assembly. It will never work. Remember you'll have your header's to deal with and if the bellhousing is attatched to the block you'll have a hell of a time getting the motor mounts in, plus you'll scratch the hell out of everything.
Drop the motor in, then put on the bellhousing and get everyhting else hooked up. It's a lot easier to work under there without the tranny in the way. Hooked up the Z Bar and rod, that way if you are restling the tranny you won't knock the clutch fork off the throw out bearing like I did. I did all this by myself and it's not hard. You can probably get that tranny in yourself, just have a jack handy. I would try and find another set of hands if you can.
One more thing I would do is use the federal mogul roller bearing for the input shaft instead of a bushing.
Chad, that is an awesome looking motor. I agree with Brett. Take it in steps and don 't try to overdue it all at one time. You don't want to scratch and nick that thing up as she looks to good. Certainly if I were closer I would lend my two hands in a heart beat. Hope all is goes well. When you gonna have the color contest for the exterior. Did I miss that?
YES!!!!!YES!!!!!!!!YES!!!!!!!! Or in the words of Homer;"Agggggggg-Biiiiggg eeeeennnnnngine, Aggggggg" :lol: :lol:
OK Brett i am paused, I will pull the bell housing I just think is going to be a ***** to get that thing bolted back up once its in the car and Im still going to have that scatter sheid banging around behind the fly wheel.
What bushing are you talking about? are you talking about the piolt bearing?? If its something that is going to improve my out put let me know.
I will do it your way Brett, Did you have hell with the scattershield when you put yours back in?? i knew I was going to have to stab the tranny from the bottom already and I had planed ahead incase i had to do it the hard way and bolt bellhousing studs so I will just have to slide it onto the studs.
Brett did you run your headers before you put the bell housing on or after??
I still havent had the vote for the color yet Steve I went and got it from the body shop on monday, now im in the market for a new paint and body. Been there and done that havent you Brett. I dont even know if i will be able to get it painted before I get out of El Paso, I hope so but its not looking good.
Yop can order the pilot bearing for a newer(94) ram truck with a 5.2L from DC and get a torrington bearing to replace the brass bushing in the crank. Works great especially if you have an input shaft with a little wear on the nose as the torrington does not ride in the same position as the bushing did.
Adam the final set up was
340 Over 40 KB Flat tops Rings file fit to .030 for drags top gland only.
Eagle I beams on the stock steel crank.
Total balance weight 1939.5 a little heavy but not bad for a stock Crank
Deck set with a +.018 on the piston and clearance checked to the head
comes out to about 9.9-1 compression by the math but who knows
Mildon High Flow oil pump and Morroso 8 QT oil pan and pick up
Comp Cam 236 @ 50 495 lift
P&P J heads with 2.02/ 1.60 valves
Comp Steel RR
Comp HI Tech Rods 7.750
Air gap with the BIGs 650 stage 3
Carter Mech street strip pump cleaned up and 6 AN fuel line
MSD with crane HI6 box and coil MSD 8.5 MM wires
powermaster light weight starter
High flow water pump
March Billet Pulleys
still plan on sticking a Alum radiator on it before she fires up that and a magnum Alternator Powder coated read and March Billet alt braket
So how do you think she will do?? with the 4 speed and 3.91s think it will get me in the 12s?? 8)
You should be able to hit the 12's easily, especially it you run some short tires with the 3.91. Maybe we could see for sure when I get there :D
Chad,I don't know what header's you have but you will need to set them in the engine compartment before you drop in the motor. Just tie them against the inner fender wells so they stay out of the way.
The bellhousing isn't as bad as you think. I put mine in by myself with no problem. I jusy set it up on the pins and put a couple bolt's in one handed. I finished assembling everything before I slid the tranny in. It's way easier. My header's were already bolted to the motor so I just worked around them.
The bearing I'm talking about replaces the pilot bushing. Your crank has a large opening on the end of it and then a smaller one where the pilot bushing goes. The bearing goes in the large opening and then you don't need the pilot bushing. I don't have the part number but it is a federal mogul part!
As far as the body work, just start ringing necks and breaking backs. Start with the wash boy and then get the office manager. By that time the body and paint guy's will get the message. You don't want to wreck them right away or you'll have to do the work yourself, which in my experience is the way to go but finding the time is the problem. I would still like to run into the guy who jacked me around and dot his eye. ZEATER has met him and will contest to the fact that this guy don't want me to grab ahold of him :evil: :evil: :evil: I would snap him like a brittle stick. :twisted: :twisted:
well i am not out much just time, I only gave him $500 bucks he did about that much work when i cam to get the car he wanted more cash and I kinda told him to eat shix and bark at the moon. I got the car and everything that went with it and he got squat.
Anybody got a part number for that bearing that replaces the pilot bushing??
