What To Look For In A Sailboat
General Discussion
  1. bobscuda67
    bobscuda67 Well-Known Member
    2,039
    301
    Aug 27, 2005
    Michigan
    Local Time:
    8:58 PM
    Don't flame me for asking about sailboats on a car site but I have been looking for a boat in the 30' range for a while.
    I half assed learned how to sail in 1977 so I'm not a total newbie at it. And I would take some ground classes to learn as much as I can too. The wife says there is no way possible she's getting on a boat with me again so I might have to work on her a while longer.
    Anyway, is there anything I should look for myself on a used boat before I pay for a survey on a boat? There's a lot of boats out there and the newest ones I could afford were built in the 1980's so they have a lot of use already.
  2. Mike69cuda
    Mike69cuda 66 is the new 17 FABO Gold Member
    2,520
    2047
    Jan 2, 2018
    Overland Park Kansas
    Local Time:
    7:58 PM
    One that is floating is good....haha
    • Like Like x 1
    • Cuda416
      Cuda416 FABO Gold Member FABO Gold Member
      2,171
      1821
      Jun 12, 2014
      South, TX
      Local Time:
      6:58 PM
      Lack of water... inside...
      Sorry, I tried to resist.. I really did...
      • Like Like x 1
      • Ron816
        Ron816 Well-Known Member
        466
        515
        Nov 15, 2019
        Quincy, MA
        Local Time:
        8:58 PM
        My only experience with blow boaters is they always think they have the right of way lost quite a few bluefin tuna because of them cutting across my stern and cutting my lines
      • Daves69
        Daves69 Well-Known Member
        6,034
        4555
        Feb 20, 2011
        WestOfChi
        Local Time:
        7:58 PM
        All seriousness aside, a couple things....
        Any signs of stringer rot like spongey or soft deck or flooring. Blackened plywood from rot and excessive odor. Raised or lower spots in the hull from possible repairs.
        • Like Like x 2
        • George Jets
          George Jets 1967 Dart 2 Door FABO Gold Member
          5,573
          7643
          Jan 18, 2019
          Farmington MN
          Local Time:
          7:58 PM
          Look for hull damage repair inside and out.
          Fiberglass boats are made of encapsulated wood. 1980 . . That is 40 years possibility of the backbone encapsulated wood being exposed to water and rotting. Most boats leak some into the hull, more leak than those that do not.
          Have put new floors and sub floor structures in 16 foot fiberglass runabouts, not a pretty sight when you pull up the soft floors.
          Lots of sail boats of size have an 18 hp diesel on board to propel the boat when the wind is not blowing. Want to make sure that is functional and not needing an overhaul. The 40 year old onboard diesel fuel tank is going to need a good cleaning out.
          In and out charges for getting the large boat into the water. Seasonal offseason storage fees.
          On the plus side you can live on the boat, no property taxes to pay.
          Although docking fees with hookups can be a cost concern.
          Have Fun
        • Brooks James
          Brooks James VET, CPT, Huey Medevac Pilot FABO Gold Member
          1,863
          931
          Dec 12, 2020
          Fruitland Park Fl
          Local Time:
          8:58 PM
          As a boat head for 50 years, see if you can find the original weight of the boat. The hull fiberglass will delaminates without you ever knowing about it and as a result the bilge waterwater will eventually seep up by capillary actionill action and be trapped between they layers of fiberglass and totally change the ballast the characteristics .You can do two things, weigh the now and find the original weight or find a crusty surveyor who has been doing it forever. The exact thing happened to a friend of mine the he was suspicious about the price hired a surveyor who said ok and after a few years it wouldn’t even get up on plane. If the surveyor doesn’t show up with a sharp ice send him packing. If you keep a decent tarp on it and change the propeller seal on the prop shaft on the aux motor
          You should be ok . Get a breathable cover I learned the hard way.
        • YY1
          YY1 Well-Known Member
          8,210
          3889
          Oct 11, 2011
          FL
          Local Time:
          8:58 PM
          The day he buys the boat...
          ...and the day he sells the boat.
          • Agree Agree x 3
          • bobscuda67
            2,039
            301
            Aug 27, 2005
            Michigan
            Local Time:
            8:58 PM
            Thanks for the replies guys.
            I was wondering about the difference on the salt water and fresh water boats if the salt water boats have more hidden issues.
            I want to take a whole summer and sail the great lakes at some point in my life before I get too old.
            My mid life crisis kicking in a little late.
            • Like Like x 1
            • RustyRatRod
              RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
              79,150
              57448
              Jun 7, 2010
              Georgia
              Local Time:
              8:58 PM
              Here's something I'd look for on a sailboat.
              • Like Like x 3
              • Agree Agree x 3
              • diymirage
                diymirage HP@idle > hondaHP@redline
                26,167
                24302
                Oct 12, 2012
                michigan
                Local Time:
                8:58 PM
                you realize that just double the price, right?
                • Like Like x 1
                • like_A_pike
                  like_A_pike or chain pickerel
                  606
                  767
                  Apr 22, 2011
                  Deep East Texas
                  Local Time:
                  7:58 PM
                  Are you planning on selling the house and living on this boat or just cruising the lakes? Look at thru hulls the number and shape of the plumbing inside and out. Movement of the keel and screw(s). Electronics especially wiring. If you think an old mopar has been fiddled with EXPECT a boat to have all sorts of wiring issues. Bad connections show up faster in a salty. Any abnormities around where the standing rigging is mounted and most models have a specific mast rake angle. Ask about what has been replaced and how much use is on things like the working rigging and sails. You will want to see into the bilge, anchor locker and everywhere something extends through the topsides like hatches, windows and even screws for decking. research you surveyor very thoroughly.
                  I did forest inventory on lots of islands all around the UP for a few years, I envy you my friend. Have fun!
                  • Thanks! Thanks! x 1
                  • bobscuda67
                    2,039
                    301
                    Aug 27, 2005
                    Michigan
                    Local Time:
                    8:58 PM
                  • straightlinespeed
                    straightlinespeed Sometimes I pretend to be normal FABO Gold Member
                    10,593
                    4207
                    Oct 21, 2012
                    Oakdale, MN
                    Local Time:
                    7:58 PM
                    Message me if you would like, I can help answer any questions you may have.
                  • bobscuda67
                    2,039
                    301
                    Aug 27, 2005
                    Michigan
                    Local Time:
                    8:58 PM
                    Hey thanks! I will take you up on that offer.
                    • Agree Agree x 1
                    • cojohnso
                      cojohnso Well-Known Member
                      361
                      431
                      Mar 25, 2019
                      Minneapolis, MN
                      Local Time:
                      7:58 PM
                      LEAKS! Look for LEAKS! Especially if she's on board? (I don't have the bodily control I once had?)
                    • diymirage
                      26,167
                      24302
                      Oct 12, 2012
                      michigan
                      Local Time:
                      8:58 PM
                      ESPECIALLY the serious ones
                    • famous bob
                      famous bob mopar misfit
                      19,857
                      8842
                      Aug 14, 2011
                      okla
                      Local Time:
                      7:58 PM
                      ONE THAT DOESN`T LEAK ------------Someone might have beat me to this , didnt read all the posts lol
                    • MOPARMAGA
                      MOPARMAGA FABO Gold Member FABO Gold Member
                      2,122
                      1519
                      Aug 20, 2019
                      Yakima Wa
                      Local Time:
                      5:58 PM
                      Sailboats....great anchors
                    • 999yards
                      999yards Well-Known Member
                      21,044
                      22493
                      Sep 15, 2013
                      eastern nc
                      Local Time:
                      8:58 PM
                      I literally grew up on a sailboat, lived aboard as a small kid traveling with my parents every summer. I had my Coast Guard Auxiliary Captains license at 15 through the Sea Cadets.
                      Best advice I've read here and agree with is find an experienced surveyor of sailboats. The guys here pointed out some really good things to look for but there's so much more. Get a professional to look it over.
                      Good luck.
                    • bobscuda67
                      2,039
                      301
                      Aug 27, 2005
                      Michigan
                      Local Time:
                      8:58 PM
                      Wow! Sounds like you had a good childhood. I definitely have the hull, engine and the rigging surveyed before making any purchase.
                    • halifaxhops
                      halifaxhops It's going to get stupid around here! FABO Gold Member
                      69,334
                      39668
                      Jan 20, 2014
                      Hoppyworld
                      Local Time:
                      8:58 PM
                      • Dicer
                        Dicer Back Bone beats Wish Bone all the time. FABO Gold Member
                        1,433
                        2049
                        Jan 12, 2016
                        Land of Lincoln
                        Local Time:
                        7:58 PM
                        "Ah, don't worry, they'll get out of the way"
                      • 999yards
                        21,044
                        22493
                        Sep 15, 2013
                        eastern nc
                        Local Time:
                        8:58 PM
                        It was nice but as a kid I didn't know any different. I appreciate it more now. Found memories of my little brother and I playing with GI Joe dolls on the deck while we were underway, visiting different marinas up down the coast and meeting new girls in the marinas as we grew older.
                        Lots of Chuck Mangioni, Neil Diamond, and Lionel Richie. Good memories.
                        Good luck and hopefully you don't end up being one of those Woodsers who's always working on their boat every weekend instead of anchored out at the cape somewhere. Unless that's what you want to do of course.
                        I wish you the very best.
                      • Daves69
                        6,034
                        4555
                        Feb 20, 2011
                        WestOfChi
                        Local Time:
                        7:58 PM
