Wheel bearing bad off the shelf?
Suspension, Steering and Chassis
  1. alpha13
    alpha13 Well-Known Member
    373
    15
    Jan 31, 2015
    Iowa
    Local Time:
    1:45 AM
    So, long story short. I get the whirring sound of a bad wheel bearing and I know it's in the front end. So I buy both if them because it sounds like both sides are making noise. I replace the passenger side and the other side is still making noise. I replace the drivers side the next weekend and it's still making noise, but the noise seems to be coming from the passenger side. So I warranty the passenger side bearing and install the new one and it's still making noise! When I turn left the noise gets very quiet and almost gone. When I turn right the sound gets louder. So my question is. Is it possible to be having bad wheel bearings off the shelf? It's getting hard to narrow this down the sound went away seems like on the drivers side. Should I just get the really expensive bearings and see if that fixes my problem? I'm using masterpro O'Reilly house brand parts. I've never had an issue before until now.
  2. 72bluNblu
    72bluNblu FABO Gold Member FABO Gold Member
    11,460
    6056
    Nov 28, 2008
    NorCal
    Local Time:
    11:45 PM
    Possible? Absolutely. Multiple bad bearings right off the shelf? Not likely.
    How are you adjusting them? And, are you sure it's the wheel bearings? Starting to sound like its something else.
  3. alpha13
    373
    15
    Jan 31, 2015
    Iowa
    Local Time:
    1:45 AM
    It's a hub assembly for a 07 dodge magnum. I started to suspect something else, but what else makes a whirring sound like a bad wheel bearing and stops when you turn left? Two wheel bearings in a row? Should I switched the sides and see if it changes? That's the only thing I can think of off hand.
  4. Lustle
    Lustle Well-Known Member
    1,391
    552
    Jul 26, 2015
    Lethbridge
    Local Time:
    12:45 AM
    I sell bearings everyday, wheel bearings included. The chance of having a bad wheel bearing is extremely low (depending on the quality, we sell Timken primarily for wheel bearings, the chance is next to zero). The chance of having two bad ones? Even if they are a chinese offshore? Next to zero. In fact not one of my wheel bearings has ever come back for any reason other than customer installed improperly. Something else is amiss, incorrect installation, or its some other part of the steering/hub assembly. I would start looking around it if you can. When you had it all apart did you notice any other oddly worn parts? Any odd wear pattern on the tires?
    • Agree Agree x 2
    • Yote
      Yote Well-Known Member
      1,165
      479
      Aug 30, 2015
      far eastern Colorado
      Local Time:
      12:45 AM
      I assume you replaced both inner and outer bearings And bearing races ???? In tightening a tapered roller bearing a little too tight is worse than very slightly loose.
      Yote
    • teringer
      teringer FABO Gold Member FABO Gold Member
      887
      230
      Feb 22, 2011
      kenly nc
      Local Time:
      1:45 AM
      I replaced both of mine and the drivers side is making noise after 1500 miles , mine have the abs sensor built in them so they don't put much grease in them when there made there afraid it might mess up the sensor . the factory ones only went 70000 miles and now I'm on my 3rd set at 190000 miles I feel your pain brother.
    • BIG-B-Barracuda
      BIG-B-Barracuda Well-Known Member
      1,144
      95
      Dec 25, 2011
      CALIFORNIA
      Local Time:
      1:45 AM
      More Grease (good grease) is better than just enough.
      also might be bearing on rear end sometimes it sounds like it might be coming from front.
      pvc valve? tires?
    • alpha13
      373
      15
      Jan 31, 2015
      Iowa
      Local Time:
      1:45 AM
      No, nothing arry at all. I know the tires make sound going down the road, but this sound is definitely a wheel bearing type sound. I don't see how you can fuck up a wheel hub bearing install. It's pretty strait forward. Take the spindle nut off, take old wheel bearing assembly off, seat the new hub assembly, tighten the spindle nut back down to 180 ft lbs, done. I suppose I will check the rear bearings too. Not enough grease in them? I've never heard of that. I should repack them then?
    • BIG-B-Barracuda
      1,144
      95
      Dec 25, 2011
      CALIFORNIA
      Local Time:
      1:45 AM
      180 FT? not sure how tight this is but sounds tighter than
      finger tight. which is what i did- finger tight
      #5 little loose is better and a little tight.
      pack them good. i even pack the dust cap.
      if your tires/wheels are maladjusted alignment, camber, toe, etc. it will make that noise too FYI . ask me how i know. haha
    • alpha13
      373
      15
      Jan 31, 2015
      Iowa
      Local Time:
      1:45 AM
      I don't think you read the post or any other part of the post. I've said hub assembly a few times already. I know how to assemble a tapered bearing and race. Tightening a tapered wheel bearing to 180ft lbs would be asinine. I'm not that stupid. So, one more time everyone. It's a WHEEL BEARING HUB ASSEMBLY we are talking about here.
    • BIG-B-Barracuda
      1,144
      95
      Dec 25, 2011
      CALIFORNIA
      Local Time:
      1:45 AM
      i understand.
      Im referencing the noise itself - more or so.
    • BIG-B-Barracuda
      1,144
      95
      Dec 25, 2011
      CALIFORNIA
      Local Time:
      1:45 AM
      ? i'm out.
    • alpha13
      373
      15
      Jan 31, 2015
      Iowa
      Local Time:
      1:45 AM
      Thank you for pointing out the alignment possibility. Although I don't understand why a little toe in would make bearings go on the Fritz. Don't all cars have a slight toe in from the factory?
    • BIG-B-Barracuda
      1,144
      95
      Dec 25, 2011
      CALIFORNIA
      Local Time:
      1:45 AM
      Like i said "just referring to noise" part of issue.
    • alpha13
      373
      15
      Jan 31, 2015
      Iowa
      Local Time:
      1:45 AM
      So no possibility of the bearings being bad off the shelf. Alright, well for the future readers I'm going to prove it right or wrong. Since I couldn't find a damn thing on Google search.
    • BIG-B-Barracuda
      1,144
      95
      Dec 25, 2011
      CALIFORNIA
      Local Time:
      1:45 AM
      HIGHLY unlikely - unless it is being installed incorrectly.
      which is asinine to even suggest . :poke:
    • alpha13
      373
      15
      Jan 31, 2015
      Iowa
      Local Time:
      1:45 AM
      Please take your antagonistic, underlying sarcasm somewhere else. You deem yourself cunning, however your playing a child's game. On a thread worthy note, it is unlikely multiples are found off the shelf bad, but still possible and I aim to prove or disprove my second bearing is bad off the shelf.
    • BIG-B-Barracuda
      1,144
      95
      Dec 25, 2011
      CALIFORNIA
      Local Time:
      1:45 AM
      you know bearings are not a bank breaking investment better not to buy the generic O'rillies brand go for the best one.
      there is a writer and a narrator.
      these are straight forward replies its up to you to give them meaning and "cunning and underlying sarcasm" or not. im sorry you feel i am being this way.
      maybe this is a case of poor attitude on your part?
      or maybe you think your self on a high horse of sorts that some suggestions or advice you deem unworthy of your time? making you the player of the child's games. ?
      thread worthy subject. Then use SEARCH button. for easy and quick answers.
    • alpha13
      373
      15
      Jan 31, 2015
      Iowa
      Local Time:
      1:45 AM
      Buying a more expensive bearing doesn't prove or disprove this one is bad from the get go. A less expensive bearing may or may not fail sooner than the expensive one, but it still shouldn't be bad off the shelf. Look, your not really producing anything positive here. So I'm just gonna ask that you quit replying. Leave space for people who might actually have some positive input pertaining to the overall question. If not, I'm just going to ignore you anyway.
    • BIG-B-Barracuda
      1,144
      95
      Dec 25, 2011
      CALIFORNIA
      Local Time:
      1:45 AM
      how old are you kid?
      earlier post i said i was out of here but you keep speaking to me.
    • alpha13
      373
      15
      Jan 31, 2015
      Iowa
      Local Time:
      1:45 AM
      Like I said, positive and contributing replies please. Thanks for understanding and not replying. I appreciate it.
    • BIG-B-Barracuda
      1,144
      95
      Dec 25, 2011
      CALIFORNIA
      Local Time:
      1:45 AM
      you're welcome.
    • 500 DUSTER
      500 DUSTER Well-Known Member
      62
      3
      Feb 11, 2013
      Decaturville, Tn
      Local Time:
      1:45 AM
      Can you hear the noise if you rotate the unit bearing by hand or just when driving? Did you feel any roughness in bearing after removal?
    • alpha13
      373
      15
      Jan 31, 2015
      Iowa
      Local Time:
      1:45 AM
      The first one felt like the bearing race was pitted. After I spun it by hand, I replaced it with this new one and it makes the same sound but I haven't spun it by hand yet. I'm gonna check it out tonight.
    • 500 DUSTER
      62
      3
      Feb 11, 2013
      Decaturville, Tn
      Local Time:
      1:45 AM
      Did it spin real easy? It is possible to receive one with little or no grease.
