ptbill
I'm replacing the front right wheel cylinder on my 65 Barracuda, do I have to bleed the whole system or just the line to the wheel cylinder I replaced?
Good time to replace both wheel cylinders.. Better yet, all four wheel cylinders...Good time to replace all of the brake fluid.
I've replaced all 4 but the right front seems to be not working properly.Good time to replace both wheel cylinders.. Better yet, all four wheel cylinders...
No. Just the right front wheel cylinder. I replaced all four and lines earlier but I don't feel this one was working correctlyDid you replace the RF flex hose?
Well I'll take it off and flush it out. ThanksIf it doesn't release right away there's a good chance your flex hose is full of crud.
Describe "not working properly"I've replaced all 4 but the right front seems to be not working properly
