1. Hankrebel
    Hankrebel Well-Known Member
    211
    21
    Nov 28, 2014
    Long Beach,MS
    Local Time:
    8:47 PM
    Any ideas on getting a wheel/lug nut off with a spinning wheel stud?
    These are Cragar SS so I dont wont to ruin them.
  2. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    15,881
    4939
    Dec 7, 2006
    PLANT CITY FL. and PERRY GA.
    Local Time:
    9:47 PM
    Is it cross threaded? Have you tried an air gun to try and spin it off? Front or rear? Drum or disc?
  3. Hankrebel
    211
    21
    Nov 28, 2014
    Long Beach,MS
    Local Time:
    8:47 PM
    I dont think its cross threaded. Spins freely
    Rear drum 7 1/4
  4. SGBARRACUDA
    15,881
    4939
    Dec 7, 2006
    Local Time:
    9:47 PM
    Are you saying the stud is spinning or the nut on the stud is spinning?
  5. Hankrebel
    211
    21
    Nov 28, 2014
    Long Beach,MS
    Local Time:
    8:47 PM
    The stud is spinning.
  6. SGBARRACUDA
    15,881
    4939
    Dec 7, 2006
    Local Time:
    9:47 PM
    I think I would try a 1/2" impact. It is possible by cocking the stud while spinning at high speed it may back off.
    • Like Like x 1
    • clementine
      clementine Flight risk FABO Gold Member
      647
      319
      Jan 3, 2016
      Emerald city
      Local Time:
      6:47 PM
      If all the other nuts are off you may be able to cock the stud by cocking the wheel one way or another.....maybe hit it with some "break free blaster" first. Can you sneak a pry of some type in between the drum and the wheel on the backside of the wheel so if you ding it a little it will be not seen?
      • Like Like x 1
      • Agree Agree x 1
      • SGBARRACUDA
        15,881
        4939
        Dec 7, 2006
        Local Time:
        9:47 PM
        Good info above. If the others will come off, you may be able to pull out on the wheel while hitting it with the air gun.
        • Like Like x 1
        • Hankrebel
          211
          21
          Nov 28, 2014
          Long Beach,MS
          Local Time:
          8:47 PM
          Thanks. I will try these suggestions!
        • RustyRatRod
          RustyRatRod Weenie idiot loser. FABO Gold Member
          58,550
          28999
          Jun 7, 2010
          Georgia
          Local Time:
          9:47 PM
          What I would do is get a high speed impact as stated. Pull STRAIGHT OUT on the wheel to lock the stud up in the axle flange and the nut will come off as long as it's not cross threaded.
        • 4spdragtop
          4spdragtop Well-Known Member
          28,384
          8223
          Aug 28, 2009
          Wasting time here
          Local Time:
          8:47 PM
          Same thing happened to Dad n I. Cragars too lol. Took it to a shop and tack welded it in. Worked like a charm. We tried a few different things...sol lol
        • Tooljunkie
          Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
          13,207
          11922
          Jul 22, 2017
          Manitoba
          Local Time:
          8:47 PM
          Cant get at backside to weld stud.
          A good pilot drill and drill right straight into stud. Need a 7/16 or 1/2” to get it to let go.
          I had to do this recently after someone destroyed a gorilla nut.
          Big expensive wheel.
        • Dubob
          Dubob Well-Known Member
          1,242
          468
          Oct 28, 2011
          Ohio
          Local Time:
          9:47 PM
          7 1/4” ? Pull the access cover, remove the cross pin, push the axle in and pull the c clip and slide the axle, drum, and wheel out. There should be enough clearance between the drum and backing plate to allow the c clip to come off. Yes you may need to loosen the brake shoes and replace a seal and gear oil, but you’ll have all the access to the backside of the stud and won’t mess up the rim.
          • Like Like x 2
          • pauly
            pauly MOPAR or no car! FABO Gold Member
            1,864
            588
            Nov 1, 2012
            Holton, Michigan
            Local Time:
            8:47 PM
            Had one do that. Got ahold of the nut with vice grips and drilled a pilot hole back through the stud. Kept going larger until I could drive what was left of the stud backwards through the axle.
          • RedFish
            RedFish Well-Known Member
            23,894
            2598
            Sep 5, 2007
            Local Time:
            8:47 PM
            we were typing the same thing at the same time LOL Put a tong type vice grip on the nut to steady it. Center drill, then 1/8 drill, then 1/4 drill, then 3/8 drill, depth just beyond the length of the nut, then use a lug wrench with a piece of pipe/brother on it if needed to bend and break whats left of the stud.
            • Like Like x 1
            • Daves69
              Daves69 FABO Gold Member FABO Gold Member
              4,731
              2849
              Feb 20, 2011
              WestOfChi
              Local Time:
              8:47 PM
              A little work but as an alternative to vice grips maybe use a doaner deep well socket. Modify the drive end for needed drill size/sizes and weld an arm on it to control the lug spin.
            • MOPAR4Me
              MOPAR4Me FABO Gold Member FABO Gold Member
              888
              174
              Jun 29, 2012
              Orange County, CA
              Local Time:
              8:47 PM
              You can maybe also get a box wrench on it to keep from spinning for drilling, if angle does not allow, use open end.
              • Like Like x 2
