WheelWise
Chuter
Lexington, IN
I was looking at that one, too. I ended up getting mad at their AI (Artificial Ignorance) chatbot for not answering my question.
They also have a couple others set up for metric, going down to 100mm. That would probably be easier to modify, if it's even needed.
5 on 100mm is virtually THE SAME as 5 on 4 for your needs.
I wouldn't run 5x100 wheels on a sbp mopar.... but for a tool to check clearances and backspace, should be fine.
Has anyone used one of these?
https://www.speedwaymotors.com/Whee...Fit-Testing-Size-Measuring-Mockup,485869.html
My Barracuda is small bolt pattern, this has a minimum bolt circle of 4.5" It also says "universal fit, some modification may be required." I'm nervous about the accuracy after redrilling the 4.5" pattern to fit a 4" pattern. Or is there a simpler modification I'm missing?
I don't see enough material to redrill to 4" bolt circle. Just ask others what tires, wheels, and backspace fits on their cars.
I ended up ordering the metric version of the Wheelwise from Speedway. I'll let everyone how it works. I'm thinking it should be fine.
