When was the last time you saw one of these (mystery race engine purchase)
The washers like things are nylon or something like it. No idea on the white goop. Most of the engine fastners will go to the scrap bin
Are you familiar with line 2 line coatings?
I had my pistons done after the rings butted
If your piston clearance is over loose have them coated. It was just about the price of 1.5 ross pistons when I had it done.
I'll have an idea on the PtW clearance later tonight when I remove piston/rods/crank. At that point I'll have enough info to choose a direction.
I was able to get the balancer off after an overnight soak in oil and a bit of my neighbor not being worried about breaking the puller or bolts. He fixes dump trucks for a living : D
The cam and lifters appear to have low run time.
If the PtW measures in spec I'll hit itcwith a light hone, re-ring and off we go.
Cool dude, looks like it will be good so far.
You gonna measure that broomstick and tell us what you got there?
That’s .616ish and .657ish with 1.5 and 1.6 rockers respectively. Not sure which cam that is. Hopefully someone with a catalog can look it up.
Yes on the BB 484 was the better cam, and the time slip showed it, dozens of times!
I ran that cam in a 440 that I built with Mopar template 906 (stock valves) bowl ported heads, 411 gears and a four speed. It was a great running motor and pulled hard in fourth gear!
In most typical bracket cars the 590 cam was a better option than the 620…….especially if the engine isn’t “high compression”.
The one engine I tested that used one was like 13:1.
I plotted out the cam, it was 283@.050.
With flat tops in a std stroke 440 and EZ-1 heads, I’d expect it to be kinda soft in the mid-range.
It’s fairly easy on parts though.
The only 590 vs 620 comparison I remember seeing:
It’s in a stroker SB-
https://www.hughesengines.com/Upload/TechArticles/Fading_Color_Article.pdf
MoPars purple cams are pretty good. While not taxing and hard core race cams, they do get the job done. I’d mic the lift at the rocker to see what you have in there. Adjust one rocker to zero lash for the test or add the lash in later.
If, for say, it’s a .590 cam, it is listed in the speed tips section for use in the 10 second bracket range. The vehicle weight and such being a big determining factor of course.
That EZ head is pretty good. Though I’d look into a good stiff rocker arm and check the valve spring pressures after sitting for a while.
I had one too
I still have one myself in my 360. It runs great. Idles really nice too!!
I had a chance to mic the pistons. All of them come in at 4.3693-4.3704 with the exception of #4 (4.3665) amd #3 (4.3674). I think I'll be good to go between .005-.006 PtW clearance.
The next step will be cylinder bore inspection using a dial bore gauge. Hopefully a few strokes of the hone, two pistons and a set of rings will take care of the short block.
Very cool
Measuring the cylinder bores tells you a bit of the story of an engine's life from the machinist to the operator. This block measures pretty darn good with respect to taper (.0005 max) and out of round (.0005 max). Judging by the consistency in the bores without the head bolted down I am going to assume this engine was bored without a torque plate on the head surfaces.
The bore measurement (4.3730-4.37250) is a bit tight for a 2618 piston. Wondering if whomever bored this block out assumed the pistons were 4032 because the clearance would be perfect. I should be able to get .005ish per cylinder with a quick hone job.
While I trust my old Sunnen dial bore gauge I broke out my economy unit to double check my measurements.
For those of us on a budget (hand raised, pb&j in lunch pail) the Shars 303-4746 2-6" cylinder gauge is a fantastic value. Up until last year the only extended dial bore gauge available aside from the prohibitively expensive Sunnen units available from Goodson, were economy units that utilize extensions that I don't not care for. This 17-in long dial-bore gauge fits the bill for measuring cylinder bores and main journals and is under $200. I can also squeak it into the cam tunnel on a big block. The only desire I have for the Shars is to replace the .0005 resolution indicator with a .0001 model.
Measuring the cylinder bores tells you a bit of the story of an engine's life from the machinist to the operator. This block measures pretty darn good with respect to taper (.0005 max) and out of round (.0005 max). Judging by the consistency in the bars without the head bolted down I am going to assume this engine was bored without a torque plate on the head surfaces.
For those of us on a budget (hand raised, pb&j in lunch pail) the Shars 303-4746 2-6" cylinder gauge is a fantastic value. Up until last year the only extended dial bore gauge available aside from the prohibitively expensive Sunnen units available from Goodson or economy units that utilize extensions that I don't not care for. This 17-in long dial-board gauge fits the bill for measuring cylinder bores and main journals and is under $200. I can also squeak it into the cam tunnel on a big block. The only desire I have for the Shars is to replace the .0005 resolution indicator with a .0001 model.
Depending on the thickness of the torque plate and the boring bar used the big block Chrysler rb can be to tall to fit, possibly the block was honed with a torque plate.
That's not a crack I see starting at the pin bore?
I did not know that. Aside from old school deck-mounted boring bars I am only familiar with the Sunnen ck10 and it's variants. This thing won't see north of 600hp so we should be good to go.
My plan is to use my last set of Stealths and maaaaaybe try some comp Evo hydraulic roller lifters. The only thing I am really lacking is an intake manifold. I was shooting for 525tq/525hp territory unless I get some sort of a sign lol
