Where’s this spring go
Brakes for your Classic Mopar
  1. 69moredoor
    69moredoor Well-Known Member
    67
    70
    May 5, 2019
    VA
    Local Time:
    7:05 AM
    Ran out of time yesterday. Trying to do my homework while at work.
    69 dart front drum
    Grinding
    Found this spring inside drum
    I believ it’s part of the self adjuster and can see it In The rock auto parts kit. Question is, so I don’t have to remove other side when I get home... orientation...and which hole. I believe it goes on the little hook on the top of the self adjuster plate to what shoe hole?
  2. 69moredoor
    67
    70
    May 5, 2019
    VA
    Local Time:
    7:05 AM
    Added colored arrows to make orientation of spring ends and where
  3. 69DartMatt
    69DartMatt Well-Known Member
    235
    122
    Jul 31, 2012
    Cumming, Georgia
    Local Time:
    7:05 AM
    It goes in the large holes in the bottom of the pads where you have the yellow arrow.
    • Agree Agree x 1
    • toolmanmike
      toolmanmike FABO Staff Staff Member FABO Gold Member
      40,932
      23868
      Jan 18, 2006
      Iowa
      Local Time:
      6:05 AM
      And that spring has a hook broken off one end. You need a new one.
      • Agree Agree x 3
      • 69moredoor
        67
        70
        May 5, 2019
        VA
        Local Time:
        7:05 AM
        Thanks guys. Love this site
      • krazykuda
        krazykuda Well-Known Member FABO Gold Member How-To Section Editor
        48,849
        13854
        Aug 20, 2007
        Orland Park, IL
        Local Time:
        6:05 AM
        That spring goes to one of the top positions... You have two springs with the long "arm" on them, when you should have one with the "long arm" and one like you have in your hand...
      • krazykuda
        48,849
        13854
        Aug 20, 2007
        Orland Park, IL
        Local Time:
        6:05 AM
        No, the one that goes between both shoes at the bottom where the star wheel is should be longer and smaller diameter coils...
        • Agree Agree x 3
        • Divenut
          Divenut Well-Known Member
          2,872
          1059
          Sep 22, 2011
          Naperville Illinois
          Local Time:
          6:05 AM
          Pop the other wheel off to peek at the setup if you need a reference. ;)
          Pat
          • Agree Agree x 1
          • krazykuda
            48,849
            13854
            Aug 20, 2007
            Orland Park, IL
            Local Time:
            6:05 AM
            Notice that the longer spring on top goes toward the self adjuster, and the one on the front pad is the shorter one as you have in your hand...
            The spring that goes on the bottom near the self adjuster is smaller diameter and longer...
            This picture is from the 69 service manual...
            • Like Like x 1
            • 69_340_GTS
              69_340_GTS Well-Known Member
              3,459
              1397
              Jul 11, 2014
              Torrington, CT
              Local Time:
              7:05 AM
              Did you also notice that your cable guide is misplaced? It must have come loose when the spring that holds the shoes together at the bottom broke, the self-adjuster was then free to rattle around in there taking the tension off of the cable.
            • leechris81
              leechris81 Well-Known Member
              70
              67
              Jan 1, 2018
              Monett, MO
              Local Time:
              6:05 AM
              What about the missing balance bar? Or did you already remove that before the photo?
            • 69moredoor
              67
              70
              May 5, 2019
              VA
              Local Time:
              7:05 AM
              Thanks for the cable guide as I did not notice. Looks like it is the lower shoe spring (yellow hole?) not one of the upper springs. Check out the Napa kit. Guess the squiggly side goes behind the self adjuster plate
              • Agree Agree x 1
              • 69moredoor
                67
                70
                May 5, 2019
                VA
                Local Time:
                7:05 AM
                I believe No balance bar on the front
                And I was trying to avoid pulling the other side to make the repair quick. I did t know it would spiral into this lol
              • 69_340_GTS
                3,459
                1397
                Jul 11, 2014
                Torrington, CT
                Local Time:
                7:05 AM
                Front ones don't have the balance bar (no e-brake, so not necessary).
                • Agree Agree x 2
                • leechris81
                  70
                  67
                  Jan 1, 2018
                  Monett, MO
                  Local Time:
                  6:05 AM
                  I knew that. I swear. I just didn’t look close enough to realize it was a front. I forget to think before speaking frequently.
                  • Like Like x 2
                  • Mattax
                    Mattax Just the facts, ma'am FABO Gold Member
                    7,138
                    4070
                    Feb 7, 2013
                    Phila. Pa
                    Local Time:
                    7:05 AM
                  • Mattax
                    7,138
                    4070
                    Feb 7, 2013
                    Phila. Pa
                    Local Time:
                    7:05 AM
                    9" brakes, 1969 Dodge Service Manual from mymopar
                    • Like Like x 1
                    • 69moredoor
                      67
                      70
                      May 5, 2019
                      VA
                      Local Time:
                      7:05 AM
                      That’s it. Automatic adjuster spring
                    • Mattax
                      7,138
                      4070
                      Feb 7, 2013
                      Phila. Pa
                      Local Time:
                      7:05 AM
                    • krazykuda
                      48,849
                      13854
                      Aug 20, 2007
                      Orland Park, IL
                      Local Time:
                      6:05 AM
                      • Like Like x 3
