Where clutch rod runs through firewall
Discussion in 'Early A-Body Discussions' started by 65ChargerDart, May 14, 2018 at 9:46 PM.
  1. 65ChargerDart
    65ChargerDart 65ChargerDart FABO Gold Member
    165
    28
    Jun 25, 2005
    Fortson, GA
    View My Photos
    Local Time:
    10:06 AM
    Can anybody take pictures of this and tell which way it runs through the firewall. Thanks in advance.
    Lee
    moparlee received no responses from his query back in 2006, so 12 years later I'm asking again...
    I'm converting my 65 Dart from auto to 4speed and don't know if I need a different plate that the steering column goes through or can I just cut an oval using the rubber boot as a template. I'd rather not guess as to where to cut the oval.
  2. Jim Lusk
    Jim Lusk Well-Known Member
    3,705
    230
    Mar 8, 2006
    Fresno, CA
    View My Photos
    Local Time:
    7:06 AM
    Not sure about the early cars, but later A-bodies were all cut for the pedal rod and just had a body plug in the oval hole. You can see it here on my '67 Barracuda, to the right of the steering column. This was while I was replacing the inner fenderwell. P1012186.JPG
  3. Streetsboro Rick
    Streetsboro Rick Well-Known Member
    52
    20
    Apr 27, 2018
    Streetsboro Ohio
    Local Time:
    10:06 AM
    My 73 just has oval hole in fire wall it's a factory 4sp car
  4. 65ChargerDart
    165
    28
    Jun 25, 2005
    Fortson, GA
    View My Photos
    Local Time:
    10:06 AM
    Unfortunately, Early A's are different in that a large plate fits over a large opening and it's different on automatic and manual cars.
    I have a manual plate coming from Sweden, but it'll be a while before it arrives. 20180515_114104[1].jpg
  5. 66Dartdriver
    66Dartdriver Well-Known Member
    335
    64
    May 22, 2010
    Erie Pa.
    View My Photos
    Local Time:
    9:06 AM
    i converted my 66 and now my 65 from auto to 4 speed i just used the boot as a template it worked fine.
    • Thanks! Thanks! x 1
    • 66Dartdriver
      335
      64
      May 22, 2010
      Erie Pa.
      View My Photos
      Local Time:
      9:06 AM
      IMG_1640.JPG inside shot
      • Claydart
        Claydart Well-Known Member
        95
        7
        Mar 27, 2013
        Brockton, Ma.
        View My Photos
        Local Time:
        9:06 AM
        When I converted my 64 Dart GT to 4 speed the hole was there but had a plug in it.
      • clifcuda65
        clifcuda65 Old Mopar Geezer
        477
        234
        Aug 11, 2013
        Phoenix Arizona
        View My Photos
        Local Time:
        7:06 AM
        The "clutch rod" oval hole is in the "steering column plate" on my 65 A-body 20180515_171448.jpg
        • Like Like x 1
        • 65ChargerDart
          165
          28
          Jun 25, 2005
          Fortson, GA
          View My Photos
          Local Time:
          10:06 AM
          Mine has no hole or plug in it. I bought a plate from Ulf in Sweden that has the oval hole for a 4speed.
        • Jim Lusk
          3,705
          230
          Mar 8, 2006
          Fresno, CA
          View My Photos
          Local Time:
          7:06 AM
          My old '66. The rod comes through the firewall, not the column plate. Oct. 19, 1965 SPD...factroy four speed car. DW023901 cropped.jpg
          • Like Like x 1
          • 65ChargerDart
            165
            28
            Jun 25, 2005
            Fortson, GA
            View My Photos
            Local Time:
            10:06 AM
            20180515_steering column plates[1].jpg This how mine looks viewed as if from the passenger compartment.
          • 65ChargerDart
            165
            28
            Jun 25, 2005
            Fortson, GA
            View My Photos
            Local Time:
            10:06 AM
            I don't see the plate at all on that photo. Maybe the '66 were different than the '64 & '65 cars? 20180515_114104[1].jpg
            Note Old Mopar Geezer's photo. It's like mine only his plate has an oval hole for the clutch rod.
            • Like Like x 1
            • valiantpatrol
              valiantpatrol Well-Known Member
              581
              25
              Apr 21, 2009
              Tucson, AZ
              Local Time:
              8:06 AM
              Based on my experience, the firewall column plate is different all three years. '64 and '66 have the hole for the clutch rod in the firewall and '65 is unique in that the rod passes thru the column firewall plate as another poster indicated.
            • 65ChargerDart
              165
              28
              Jun 25, 2005
              Fortson, GA
              View My Photos
              Local Time:
              10:06 AM
              I have no experience with '64 or '66 so I'll defer to your greater experience.
