where do these wires go
Dennis Gerard
Florida/tenn
I have 2 wires not sure where they go
1. comes out of the flasher by e-brake handle.
2. comes out of wire harness , not sure where it goes does not seem to have power going to it?
1968 Barracuda 318 auto non a/c convertible
I believe the wire from the flasher goes to the emergency flasher switch.
The MyMopar aftermarket diagrams are not the best for this use, as they don't properly show the actual wire routing and connections
Better to consult the factory shop manual, and you can download some of those from the same place........MyMopar. SOME of those manuals come from the guys on here
The wire that looks pink with the female end looks just like the wire and connector that goes to one of the two connections above the emergency brake handle (see my pic).
That broken wire that looks orange looks like either fuse box, the steering column connector, or the plug to the left side of the back of the circuit board (as you are looking at it from the seat). Here is the best picture I have of the hornet's nest of wires. Note this is a 69 Dart, so I am not sure how much of this is the same.
