Thank you for your reply. I ordered a drain kit for the car and what I got was two body plugs with small hoses running through the middle of them and I cannot find where to put them. The car just came out of the body shop. Some people have suggested these plugs would go in the trunk well. I just haven't been able to find any information on this. Any help would be greatly appreciated. Thank you! Skip ('68 Barracuda)This is a Dart (GTS), but the channel below the body lip is where the water runs that gets past the top. It runs down into the quarter panel and out through the drains in the seam. Barracuda is the same, but the shape of the dutchman panel is different.View attachment 1715238476
Toplscuda -Skip
Jim gave you a good look at the drain run from the inside and here is how it looks where it dumps inside the quarter itself. As for drain hoses and plugs I can't help with that because I haven't ever seen one with them.View attachment 1715238582
Yes... My error not in the qtr panel the trunk extensions.The only body plugs that I know of that have a vent/drain provision belong in the turned down or drop off portion of the trunk floor extensions. The plug has a small flat so it installs correctly.
